Question about Schwinn Meridian Adult 26-Inch 3-Wheel Bike
Where can I purchase the bearings and axel? also is there a parts list available?
    Brigadier General:
  • 8,546 Answers
Http://www.schwinnbikes.com/media/uploads/blog/files/Schwinn-Meridian-Manual_Mar2011.pdf
They don't get int o the details but a reputable bicycle shop would be able to assist you with the bearings.
Schwinn probably has a way to get the axle.
http://www.schwinnbikes.com/
http://www.schwinnbikes.com/contacts
Posted on Apr 10, 2011
My 1990 ford bronco 4x4 starts vibrating at 40 and gets worse the faster I go till I let off the accelerator then it stops till I hit the accelerator again then it starts vibrating again
engine/tranny moutings , suspension/steering components /wheel balance/bearings sorry there are a few things that could do that so check the easy stuff first steering etc and work your way through the list
May 06, 2014 | Cars & Trucks
I have a Mongoose Dual Suspension Mountain Bicycle 26 inch that I purchased approx. 2007 and I need the rear wheel axel and bearing assembly. Where would I be able to purchase these parts?
It's prabably easier to buy a whole new hub. And for ablout another $20 you get a whole new tire. You should do that. Have a bike shop do it because it can be tricky.
Jul 24, 2011 | Mongoose Domain Dual Suspension Mountain...
Cam shaft bearings are seized in Dewalt DPD3100 presure washer. does anyone know where to purchase the roller bearings. can not find a part number, do not want to purchase new pump
hi there perrinex22x
here is web site for parts
http://www.ereplacementparts.com/dewalt-dpd3100-pressure-washer-parts-c-1009_7440_7445.html
from diagram looks like not listed as seperate part
may need to remove them and see if your local bearing/ belt store distributor in your area may be able to source them
from list pt number N001194 pump assy is 505 $
sorry
here is another web site that may help for needle roller brgs - give a try
http://www.locateballbearings.com/roller-bearing-suppliers.html
cheers hope it helps pauly46
Jun 07, 2011 | Dewalt DPD3100 Gas Pressure Washer
Passenger side at end of axle losse inside rotor is loose on bearing and flopping inside with wheel off will just a bearing fix this
most likely it will be just the bearing, unless someone has driven it this way for prolonged time in this case it might need other parts as well such as a new axel, or even a rotor. if it has been the case then the axel nut that holds the axel in the bearing has gotten so hot the chances of loosining it up will be verry slim and verry hard to remove, thus damaging the axel nut threads. if nit is this loose, I would expect to replace the bearing and the axel.
Dec 31, 2010 | 2001 Hyundai Accent
I have 2001 Chev Tracker, Oil started to run out of the Right side break drum. Removed Drum and foud oil all over the breaks. Tried to remove the Axel by removing the four nuts off of the backing plate,...
fror fixing the brakesw take the other rear wheel off and duplicate what u see. to get the axel out u must first remove diff cover in center of rearend then u will see a clip for each side axel remove clip and axel will slide out. good luck fron 1 to 5 being difficult its a 3
Jul 21, 2010 | 2002 Chevrolet Tracker
Hello I'm looking for a tub bearing for a bosch washer. WFMC3200UC
Hello, The part you are asking for is available, but it can only be purchased with the entire polinox tub assembly. Part # 245703 and retails around $375 - $475 or more at most places, but ( check out searspartsditect.com they list it now for $204.89...that is an amazing deal ! ) this includes the entire kit. B/S/H ( bosch) does not make available just the bearing. If the bearing is worn, than so is the basket spline, bearing & seal, so they figure the proper repair is the entire tub. I agree, in my experience everything else is just half measures and more work down the road, and I've seen a lot of them. Hope this answer's your question and moves you forward. Let me know if you require further assistance and I'll see what I can do. Thank you for choosing "fixya" for your inquiries. Please take a moment and rate the info I provided here today. Thanks again and good luck. Macmarkus :)
Mar 23, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
1995 chevrolet tahoe 4x4 posi rearend axel bearing replacement how do i remove the posi unit to get the axels out?
You don't. Ever work on a rear axle. Remove cover,one bolt,pull pin and axle clip.Then pull axle, and off to auto parts store, to press on new bearing.
Feb 13, 2010 | 1995 Chevrolet Tahoe
How to remove front wheel bearings on a 2000 mountineer
remove the caliper and the axel nut and there are 3 bolts on the back of the contol
arm near axel and 1 wiring harness for abs these bearing assemblies are like $150 each from advance auto parts you may want to go to the website and look at the picture to see the bearing ? its not hard to change about .5 each side ?
Aug 29, 2009 | 2000 Mercury Mountaineer
Car was driving fine, then suddenly it started roaring
if you know the bearings r good ..[check first] look at the axel, boots and bearings these are the only moving parts in the front end but to me i bet it is the bearing/axel
Jul 27, 2009 | 2001 Dodge Stratus
Replace rear axel bearing on 4x4 5.3 Litre gas engine
Loosen differential cover and let oil drain. Remove cover, remove U lock from axel. Pull axel out. Remove bearing seal then bearing. Install new bearing, seal and reinstall axel. Reinstall U lock and new cover gasket. Fill with 75-90wt gear oil. Now I know that sound pretty straight forward. But there are some things to remember. The U lock can be difficult to remove sometimes. The most important thing is the seal, you will need to make sure it gets seated correctly and not torn when installing axel.
Jul 12, 2008 | 2000 GMC New Sierra 1500
Schwinn Meridian Adult 26-Inch 3-Wheel Bike Logo
118 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
