Question about Car Audio & Video
Sony wx gt78ui how do you open front panel problem
2 Suggested Answers
  • 158 Answers
SOURCE: hi there ,,, hello,,, i would like
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
Posted on Feb 23, 2011
I need a schematic for the Cobra 18 wx st. I see them for the st 2 but not the plain version. I have no receive on CB position. I have resoldered all the vertical connections and tried a different mic. ...
start unsoldering you final , check it for proper voltage. then do the same for the driver. Check the voltage regulator. make sure you have the proper out put voltage in the vco section before doing anything. Also make sure you are on frequency.you more then likely have a short somewhere in the receive section and you are just going to have to break it down area by area , transistor to ICs .Its going to be painstaking but you will find it.
Aug 05, 2013 | Cobra 18 WX ST 40-Channels Base CB Radio
I need to put a new volume switch onto my Sony wx-c570r radio. I seem that I can get the part, but I have no idea how it fixes to the radio. Do I need lots of skill?, or is it OK if I am not experienced in...
If you have no experience unsoldering and soldering it is probably not something you can handle. Especially if the switch is what is refered to as surface mounted. A surface mount refers to the fact that there are no pins going to the other side of the board to be soldered there. It takes a bit more skill to solder on a surface mount part than a through hole part.
Jul 28, 2011 | Sony WX-C570R
On the sony WX-c570, when we try to play a CD it displays E-04.
Are you trying to play cheap burned cd's. If you are I would try a real store bought cd see if it works if it does then you may just need to step up to a better cdr cheaper is not always better car cd players least older or stock ones have read problems with the cheaper more transparent cdrs.
May 04, 2011 | Sony WX-C570 CD Changer
Loaction of reset button on sony wx-c570r cannot
the reset button is located just above and slightly left of the volume knob.it is very tiny,you will need a pin to depress it.
Mar 08, 2011 | Sony WX-C570R
Hi there ,,, hello,,, i would like to know what all the coloured wires are for on the back of my radio i just bought,, sony wx-gt78ui
Feb 23, 2011 | Car Audio & Video
I have a sony cd player wx-gt78ui can you tell me please were the illumination wire grts hooked into
If you car does not have an illumination wire don't worry just cut and tape it you don't need to hook it up
Jan 31, 2010 | Car Audio & Video
Cobra 75 wx st everything seems to work eccept receiving signal meter will spike on trx and it seems to receive but no sound there is sound in wx mode
WX is for weather. If you put it on WX, and you do not hear anything, then you need to change the weather station it is on. in wx mode, you change weather channels by pressing channel up and down. To communicate with 2 way, press the cb/wx button so it is on CB mode.
Sep 28, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Compatable cd changer
any uni-link changer will work
Nov 23, 2008 | Sony WX-C570 CD Changer
Car Audio & Video Logo
147 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
