Question about Plumbing
Pump with pressure control ONGA SMH45, fails to start up occasionally. The fault light comes on and I have to restart - which then most of the time works...
4 Suggested Answers
  • 832 Answers
SOURCE: onga smh45 tripping rcd
Check the electrical connection for grounded wires or
loose electrical connections. Use wire nut for all electrical connnection and tape it properly. This should
correct the 20 ohms earth leakage. Send you e-mail comments for further assistance.;
Posted on Oct 27, 2009
  • 760 Answers
SOURCE: I have an Onga smh45
This could be your problem. Make sure it isn't running dry.
D.R.O.P (Dry Running Over-Temperature Protection)
The Onga SMH series of pumps (excluding the SMH35) are fitted with the internationally patented D.R.O.P system which protects the hydraulic parts from possible damage that can be caused by overheating of the liquid inside
the pump casing. The overheating can be the result of external causes (outside the pump) or occurs because the pump stops priming and as water is pumped out the
pump runs dry.The D.R.O.P system is reset using the switch located on the condenser.
If you have access to an amp meter, measure the curring when pumping full load, and be sure it is less than the full load amperage listed on motor.
Posted on Aug 10, 2010
  • 126 Answers
SOURCE: how to adjust pressure switch onga pump.
your pump should have a 20lb seperation ie. pump turns on at 20lb and off at 40lb or on at 50lb off at 70lb. under the cover of the switch theres two screws with springs under them.dont mess with the small one.the large one if you screw it down (right) will increase the pressure while maintaining the 20lb separation. one thing to keep in mind its fine to adjust the pressure BUT at the same time the air pressure in the tank needs to be adjusted to two lbs below the cut in pressure of the pump.
Posted on Jan 18, 2011
The Onga pump turns on and off.
that pump has a pressure switch that turns it on and off
which onga model
whats the actual fault ?
Sep 10, 2016 | Plumbing
My bathmaster v2 onga pump has a flashing red light on control pad that flashers 3 times with 1 sec intervals pump does not work please help
if the controller is flashing it means that there is no water to pump
check water supply to the pump
Jun 01, 2016 | Cars & Trucks
What means i50 for a AEG Dishwasher?
Fault is associated with cylcling pump which pumps the water during washing. It sounds like it is only happening occasionally which could mean that the control board for cycling pump is faulty. If happening every time then pump may be faulty. This parts can be pretty pricey so if its only happening occasionally then you may want to consider living with it until it gets worse.
Aug 31, 2014 | AEG Dishwashers
2007 GMC Canyon ABS Fault - Originally ABS Fault started when making a sharp right turn. (ABS Fault light only). Stopping and restarting would clear 'fault' until next hard right. Later, occasional metal...
id check your caliper to see if the piston is compressing all the way if not check your fluid it should be clean not brown or if you have been through large amounts of water if it has gotten into the brake system and check your bleeder valve to check if it has rotted or come lose or if you have a break in the lines or air, most likely your caliper is failing to compress.
Nov 05, 2013 | 2007 GMC Canyon Crew
Onga js120. Wont hold pressure
I assume the pump runs when switched on until a preset pressure is reached in the outlet when it cuts off, remaining on standby until the pressure falls due to a demand for water when it automatically restarts.
To achieve that automatic function there must be a pressure switch in the outlet side of the pump and that or the associated circuitry is where the fault must be as the pump seems to run ok when reset is pressed.
If it is modern it is likely electronics are involved and it would seem more likely those are at fault than a faulty pressure switch which could be expected to remain faulty all the time.
Another possibility is the motor is overheating due to a fault or due to the duty cycle being exceeded and the safety cut-out must be manually reset.
Jun 26, 2017 | Northern Tool 12 Room Purple Martin House
I have an Onga smh45 which keeps tripping out and you have to push the reset button. I have had it in to two repairers and they say they can't find anything wrong with it. Any assistance would be...
Aug 10, 2010 | Plumbing
New onga JS120 pump worked fine for 4 months bringing water from tank up to house then suddenly stopped.We undid the pipe and reconnected it,the pump worked again but stopped again after a few...
a number of possibilities like insufficient pressure in the bell or pressure leak 'or pump motor dying
but i'd be looking at a warranty claim
May 11, 2010 | Plumbing
Onga smh45 tripping rcd - about 20 ohms earth leakage - occassionally runs for about 10 secs -
Oct 19, 2009 | Plumbing
Fisher & paykel smartdrive MW095AU wont spin
press start cold water starts then stops and starts about 3 times followed by error which stops machine to protect it ?
Dec 28, 2007 | Fisher Paykel EcoSmart GWL15
Plumbing Logo
1,211 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
