Question about Panasonic DVD-S54 DVD Player
DVD S54 player. The tray won't open. Turning the unit on and off does nothing, no whirring noise, no noise at all. It stills says hello and off but nothing else.
  • Panasonic Master
  • 467 Answers
Does the player's display still read 'HELLO' and won't show 'NO DISC' after that? If so, it's likely to be a workshop repair. This cannot be fixed by the consumer. If the player does go beyond 'HELLO' to 'NO DISC' but the drive tray won't open, then it would be a fault between the drive itself and its digital control circuit, which in this model would be part of the motherboard. Assuming the power supply has no problems of its own, then the only course of action you would really have here is to submit the unit to an authorised service centre, get a quote on any repair cost(s) involved, along with a second opinion. (the second opinion will give you minimal details of the exact nature of the fault(s) and allow you to make a decision as to whether it is worth fixing or to buy a new one, since it is not a recorder).
I hope the DVD drive itself is not the primary fault area, but rather the circuit controlling it - easier to determine by a qualified technician.
The decision is yours, and your course of action is based on the age of your existing player. If it is still relatively new and under some warranty, you might be able to get this fixed at no cost to you. If it is not, it will be expensive/uneconomical.
Posted on Apr 10, 2011
Pioneer dv-2010 dvd player makes a whirring noise
That's because the lazer on the tray is trying to read the disc. Does this happen to other discs? When the lazer can't read the file, the drive spins up the disc to help it read it.
Dec 09, 2013 | Televison & Video
JVC DR-MV80B display says hello then shuts itself off.
On electric board you need to change the STR,and work fine.....
Sep 09, 2012 | JVC DR-MV80B DVD Recorder / VCR Combo
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
The tray on player won't stay closed therefore I can't play a dvd.HELP
It sounds like there is something inside the dvd player, that isn't supposed to be there, that is keeping the tray from retracting fully. Try unplugging the unit and gently turning it upside down and giving it a little shake. Not too hard. This might jar the item loose, you will hear it knocking around. If you do knock something loose turn the unit so the front is pointing up and let the foreign object fall to the back of the unit where it hopefully won't interfere with the operation of the mechanisms inside. If you don't hear something come loose, remove the screws on the bottom, sides and back of the unit to remove the top cover. Make sure you have unplugged the power before you do this. take a look and see if you can find something jammed in the track or the gears for the tray. If you do gently remove the item with your fingers or a pair of needle nose pliers. Once removed replace the cover and away you go. If there is nothing blocking the tray and the mechanism, you probably have a gear system to close the tray. At some point someone must have pulled fairly hard on the tray causing the gear teeth to jump, check and make sure they aren't damaged or stripped. You are going to have to them either remove one of the gears (or pull it up so it can turn without turning any other gears) push the tray back into the fully closed position and replace the gear. Once you have done this you will want to test to make sure the tray will function properly. Place the top cover back on, but don't secure it with the holding screws in case you need to open it back up again, plug the unit in and test the tray. If it works unplug it and secure all the screws for the cover and away you go. Otherwise you are going to have to play with the gears till it is back in the proper starting position. If your hearing some strange noises and its not working, then the gears are probably badly stripped. You can contact the manufacturer and see if they can sell you some spare parts or direct you to someone who can replace it. Though at this point simply replacing the unit may be less expensive.
Jul 26, 2011 | Zenith XBV243 DVD Player/VCR
The tray on my DVD player won't open. When I press open/close, it just makes a whirring sound.
Failure of the loading mechanism, possible that the drive is struck or the belt is worn out ,. You will need to remove the tray mechanism to check and confirm. The motor seems to work as there is noise but the drive is not working , possible belt slipping or gear slipping.
Feb 21, 2011 | Televison & Video
Unlock region free?
1. Remove any DVD discs from the tray/unit.
2. Switch off the DVD player and unplug the power cord.
3. Wait 30 seconds, then reconnect the power cord.
4. Turn on the DVD player with the supplied Samsung remote and wait for player to finish loading and display 'no disc' or the Samsung logo before you do anything else.
5. Press Enter on remote. (There will be no on-screen response to you doing this.)
6. Press the following numbers in sequence using the supplied Samsung remote unit's keypad -
8 4 2 6 9
(Again, there will be no on-screen response to this action.)
7. Press Enter on the remote. The DVD Player will automatically shut off.
8. Now, turn the DVD player on.
9. When it is on and showing the "no disc" or Samsung logo, turn it off again.
10. Repeat this action by turning the DVD player on, then off again.
11. The DVD Player should now be Region-free.
Sep 29, 2010 | Panasonic DVD-S54 DVD Player
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
Disc Tray Won't Open
Sounds like a belt is slipping.
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 25, 2008 | Pioneer DVL-909 DVD Player
Panasonic DVD-S54 DVD Player Logo
236 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
