Question about Gateway Desktop / Intel Pentium Processor / 6GB Memory / 1TB Hard Drive (SX285109E)
I just bought a gateway sx2851-09e computer. It runs fine, but would like to install a pci video card for online gaming. Most cards require at least 300 watts of power, unfortunately, this pc only has 220 watts. What model power supply can i put in there that would fit? ( PC is rather slim) I would like to get up to about 500 watts if possible -Shane
  • Gateway Master
  • 11,800 Answers
This system uses a custom size psu - you cannot replace it. But you can buy a simple case and move everything in it - the present case would not support the heating coming from the new video card anyway.
Posted on Apr 12, 2011
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
What type of graphic card are compatable with emachines T3624 Pc's
Hello here are the homepage:
http://support.gateway.com/us/en/emac/product/default.aspx?modelId=1581
This mainboard has the PCI-e graphic card socket, and a AGP graphic card will not fit and run on it.
A PCI-E graphic card, can be bought in a computer store or online.
Does the pc boot at all ???
If not try to renew the power supply.
Good luck
Mar 31, 2013 | E-Machines EMA IMPERIAL GV (845GV) TG3...
My son saved up and bought a Gateway SX2855-UB12P. We have upgraded to 8MB of RAM and now are looking to upgrade the video card which currently is a PCI Express x16 Graphics. Given his machine is a en
Hope you mean upgraded ram to 8 GB 8 mb is not much ram to run a computer.
To upgrade your computer's graphics card, unfortunately you can't just simply purchase a card and install it to your computer. Before purchasing a card, you must first confirm what is compatible with your motherboard. Graphics cards use either AGP or PCI Express technology. Many older computers use AGP. AGP cards can vary in version and bandwidth, whereas PCI Express cards can vary based on their lane . Moreover, the card itself is not your only consideration when looking to upgrade your computer's graphics. You must also consider the strength of your computer's power supply as well, since most newer cards use a lot of power. Download, install and run SiSoftware's Sandra (see link Below) to find out information on your motherboard. http://download.cnet.com/SiSoftware-Sandra/3000-2086_4-10556571.html Click the "Mainboard Information" icon, then write down the information next to "Manufacturer" and "Model." Navigate to the motherboard manufacturer's website. If you are not sure of the website's URL, enter the manufacturer's name into a search engine to find the company's website. Go to the support page and enter your motherboard's model. Download the motherboard's manual or review the specifications. Search the manual or specifications for "Expansion slot," "AGP" or "PCI Express." If the expansion slot uses AGP, note the version (AGP comes in 1.0, 2.0 and 3.0), as well as the bandwidth (1x, 2x, 4x or 8x). If the expansion slot uses PCI Express, note the amount of lanes (x1, x4, x8 or x16). Search the manual or specifications for "Power," "PSU" or "Power Supply." Write down the power supply's voltage (3.3V, 5V or 12V) and amp rating (designated by "A"). Not all manufacturers list the amp rating in their documentation, so you may need to contact the manufacturer for more assistance. Compare the graphics card you want to buy to the motherboard's expansion slot. AGP cards won't work in motherboards using PCI Express, and vice versa. Similarly, AGP 3.0 cards won't work in motherboards using AGP 1.0. A PCI Express x8 card will not fit in a PCI Express x1 slot. Check the voltage and amperage of the video card to the voltage and amperage on your motherboard. A video card that requires a higher amp rating requires a powerful PSU. Hope this helps.
b>
Dec 24, 2012 | Computers & Internet
Which video card i can get for gaming on this computer the vgc-rb53 vaio sony computer please help!!
You can fit any PCI Express X16 graphics card into your computer. The biggest issue that you may run into is power requirements. However, the majority of inexpensive graphics cards - ranging in prices under $80 - should be capable of gaming very well. If you're looking to go all out and make an investment in PC gaming, replacing the power supply will make the machine capable of using any video card. 1000 watt power supplies can be found online for around $100.
Feb 26, 2011 | Sony VAIO VGC-RB53 PC Desktop
What video card are compatable with SR1620NX ? The graphics card is not working right anymore and I need a compatable video card.
A PCI Express graphics card.
Doesn't matter if the PCI Express graphics card uses the PCI Express 2.0 technology, or the PCI Express 2.1 technology.
The PCI Express graphics card, will insert into the PCI Express x16 expansion slot on the motherboard.
Supporting data;
1) View of the motherboard in an illustration,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00378480&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=1127351
Scroll down the page to view the motherboard illustration.
A) Looking at the illustration, view the BATT. (CMOS Battery)
To the left of the CMOS Battery (BATT) are three white PCI slots.
Above them is a longer expansion slot. This is the PCI Express x16 slot.
Above it is marked > PCIX16X1 (PCI x16 times 1 slot)
NOTE* When installing the PCI Express graphics card, lift up gently on the Lock 'handle'.
It looks as though you should push down on it, but you need to lift up on it instead.
Also go above the motherboard illustration, and read to the right of the heading > Internal Connectors
In the list you will see > One PCI Express x16 graphics slot.
WHEN installing a graphics card, ALWAYS install the software from the CD disk provided, First!
Computer on, and Windows running, insert the graphics card's Installation disk, (CD) into the optical drive tray.
Install the software by following the directions.
THEN shut the computer down normally, and unplug the computer from power.
OBSERVE Anti-Static Precautions.
Install the graphics card.
Close the computer case, and plug the monitor into the graphics card.
Turn the computer on.
When you install a device (Such as a graphics card for example), Windows will try to find compatible drivers.
IF, THE driver is not installed First, Windows will match up one of it's thousands of generic drivers.
This = No.
You want THE driver installed first, so that Windows will find it, and Not try to match on of it's generic drivers.
NOTE 2*
It DOESN'T MATTER what graphics ram memory the graphics card has.
The graphics card's Processor and Ram Memory operates independent of the system resources.
Example:
The computer uses DDR Sdram ram memory.
The graphics card uses GDDR5 graphics ram memory.
It will work just fine.
NOTE 3*
It does NOT matter if your computer uses the PCI Express 1.1 technology, and the graphics card uses the PCI Express 2.0, or 2.1 technology.
PCI Express 2.0, and 2.1 technology is Backward Compatible with PCI Express 1.1 technology.
Will you get the full capability of the PCI Express 2.0, or 2.1 graphics card?
NO
Will you notice?
NO
What you need to look at it, is how much power will the graphics card use. Look at the system requirements for the graphics card, and be sure your Power Supply has enough power for that graphics card.
Also, IF, the graphics card requires additional power cables from the Power Supply, make sure your Power Supply has the required power cable, or power cables.
IF the Power Supply does not, use a power adapter cable.
NOTE 4*
Graphics card manufacturer's base the power needed for the graphics card, Not just on the graphics card itself, but on an entire computer system, AND the graphics card.
The graphics card manufacturers use a test computer system, that is a powerful computer system.
Gamer motherboard, Dual Core, or Quad Core processor, 4GB of ram memory, and at least two harddrives, and two optical drives, PLUS the graphics card in question.
This complete computer system uses a LOT more power than just the graphics card by itself.
There isn't a single graphics card out there, that uses more than 150 Watts by itself.
Recommendations for a graphics card that is compatible, with a Compaq Presario SR1620nx desktop computer?
Budget to medium:
Good enough to watch videos, older games, and some newer games.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4675217&CatId=3670
Medium:
Higher level games, and large screen monitors,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6642574&CatId=3669
For questions post in a Comment.
Regards,
joecoolvette
Dec 18, 2010 | HP Compaq Presario SR1620NX...
Gateway 838GM Video Card?
Hi i'm Rain.
Ok lets put it this way. You get what you pay for. If you want quality video you have to be willing to pay the asking price. Yes you can find it cheaper ,..But look at the word cheaper.
Yes the Express x16 HDCP will work with your system .
If i had to solve the issue i would have said get the PCIE.
All you are looking for is a video card with high speed .
I hope i have been helpful in this problem.
Jan 28, 2010 | Gateway 838GM (RB838GM) PC Desktop
I want a compatible video card for my pc
This sounds like your computer may be several years old and the hardware a little outdated. It will depend on the game since today's latest games require not only 3d-acceleration but super fast acceleration as given by "NVIDIA" or "ATI"'s latest graphic cards.
If you are running a relatively simple game, you need to see if your computer uses which type of graphic card connector.
In the old days it was PCI, then came AGP and later PCI Express.
What the above will tell you is which 3d graphic card type to buy. You can get a graphic card at newegg.com or lots of other places varying in speed and capacity.
Aug 11, 2009 | 3dfx Voodoo2 1000 (12 MB) Graphic Card
I own a Dell Inspiron 531S. I'd like to get a new graphics card. I currently have a NVIDIA GeForce 6150SE nForce 430. I don't want to spend too much for this but I'd like to run my Second Life game with...
When you install a new video card you must disable the onboard video card by going into the bios setup. Below I have listed the requirements of Second life game. e 531 does come with PCI-E slots so make sure you buy a VIDEO card with PCI-E Walmart sells some pretty decent priced Graphics cards. pretty much any pci-e card you buy new in walmart these days will be fine for this game.
PC Minimum System Recommendations:
* Internet Connection*: Cable or DSL
* Computer Processor: 1.6GHz Pentium 4 or Athlon 2000+ or better
* Computer Memory: 512MB or better
* Video/Graphics Card**:
o nVidia GeForce FX 5600, GeForce 6600, or better
o OR ATI Radeon 9600, X600, or better
M
Jan 02, 2009 | Computers & Internet
Gt5520 video card
Is this a PCI-E card? I will work on the assumption that it is. Unless you are running two video cards in SLI remove the old card, they make great paper weights. Be sure to only add/remove hardware while the machine is turned off.
Dec 20, 2008 | Gateway GT5220 PC Desktop
Gateway Desktop / Intel Pentium Processor / 6GB Memory / 1TB Hard Drive (SX285109E) Logo
309 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
