Question about Philips 60PL9200D Projection Televisions
60PL9200D/37 philips projection tv is now black and white and does a humming sound
5 Suggested Answers
Ecollier2012
  • 3459 Answers
SOURCE: Projection Lamp for Philips 60PL9200D/37 TV
More than likely the problem is the CRT fluid and not the tube. Do a few google or fixya searches on CRT fluid and to get an idea of what it looks like when it gets cloudy.
Posted on Nov 18, 2008
eagle338
  • 4889 Answers
SOURCE: philips tv. model.# 60pl9200d/37. picture
Clear case of lamp failure. When was the last time you have replaced it?
Posted on Dec 27, 2010
taran_2005
  • 10515 Answers
SOURCE: Philips 60PL9200D/37 - dark picture for two weeks
There is a very good chance that we have a bad lamp here again. Which is about the best case for you.
I think the first thing we should do here is take it out and inspect it. We might find that it is shattered and know without a doubt that it needs to be replaced.
Also if you don't know about the lamps in these sets here is some information: These lamps are a "consumer replaceable item" meaning they are made for you to change. This is similar to changing a light bulb in a lamp but allot more expensive and a little more difficult. These lamps last on average anywhere from 1 to 3 years before they need to be changed. They also burn out based upon the number of hours the tv is on and the number of times the tv is turned on in its life. The more you watch the tv the faster the lamp will burn out, and the more you turn the tv on and off the faster it will burn out. There is really no way to prolong the life of a lamp other than not watch the tv, so most people don't worry about it to much and just expect for this to happen ever couple of years.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 03, 2011
SOURCE: how to replace the bulb in PHilips tv model
my tv flashes 6 times slow,pause,5 times fast but it dont power on
Posted on Aug 17, 2011
I have a Philips dlp60pl...the picture flickers and the color turn red to green then back to normal color, could this be the bulb.
No.Do the tv pictures colors back ground flashes black and white when this problems happen?Ur tv now make any humming sound or motor noises?Yes,than the tv colors wheel it is the causes and the problems.The tv colors wheel it is dying and starting to be worn out.The tv colors wheel itself it is starting to come out of the spinning motor axis.The tv colors wheel have to be replace to fix this problems.The tv colors wheel sit way back of the tv,must have to take out many mechanical parts before u can even come to the tv colors wheel itself to replace it.If u have no mechanical skills don't tries to replace the tv colors wheel ur self.Hire a tv Tech. to replace the tv colors wheel it is ur best bet.
Sep 24, 2011 | Philips 60PL9200D Projection Televisions
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
Why is the tv making humming sounds and showing only in black n white
What kind of cables are you using; red-white-yellow, component, hdmi? What source are you using?
Feb 27, 2011 | Philips 60PL9200D Projection Televisions
I have a philips tv model number is 60PL9200D/37. when i turn on my tv the blue power light flashes and the lights and fans cut on but not the actual screen. after a few seconds of blinking the lights and...
U hear alots of clinking too,when tv power on and the projection lamp tried to come on?Yes,tv have a problems with it board call the Ballast board also.This Ballast board only job is to help ignite the tv projection lamp.
Feb 03, 2011 | Philips 60PL9200D Projection Televisions
How to replace the bulb in PHilips tv model 60PL9200D/37 ?
Sep 23, 2010 | Philips 60PL9200D Projection Televisions
Philips 60pl9200D/37. Two Red lights on power button.
If the power button is displaying the bulb fault indicator AND overheat indicator lights at the same time, it indicates a faulty cooling fan. The television is smart enough to detect when either of the two cooling fans in the chassis have failed, or aren't spinning fast enough. To prevent overheating and damage, the set will not turn on if a fan is faulty. You'll need a replacement fan.
Jun 20, 2010 | Philips 60PL9200D Projection Televisions
How hard is it to change buld for 60PL9200D philip tv could my husband do it himself?
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 16, 2010 | Philips 60PL9200D Projection Televisions
Nov 12, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PL9200D Projection Televisions Logo
77 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
