Question about Yard Machines Garden
I need to know how much oil to put in my tiller
    Scholar:
  • 143 Answers
You should have a fill port on the side of the motor the cap should have two litle pegs that stick up open it up and you should fill it till you can see the oil hit just about to the edge of the threads that should only be 1 and 1/2 quarts not to much in those small engines . and do not use synthetic . just use regular oil 10 w 30 weight
Posted on Apr 10, 2011
I need to know what brand and type of oil to put in my cub cadet rt 65 tiller
As 1st option,It would be best to call the manufacturer Cub Cadet,or their Authorized Repair Center,and ask them directly.
Refer to the manual that came with the tiller.
As 2nd option, a general small engine repair shop can be helpful too.
Have a nice day.
Apr 23, 2016 | Horizontal Ohc Engine 190cc,gc...
Need to know oil / petrol mix for Mantis 2 stoke Tiller
it is a 50:1 gas:oil mix. I'd also strongly recommend adding a fuel stabilizer to the mix, as a tiller has a tendency to sit for long periods without being used. Good luck!
Nov 17, 2012 | Mantis 2-Cycle Tiller
Don't know where to put the gear oil in the tiller. There isn't a gear oil plug.
if a troybilt there are two places to fill screw the t handel out(holds the handle on) and the other is front of the tine cover
Mar 13, 2011 | Garden
Tiller starts, runs for 2 minutes, then engine slowly sputters and dies. In checking the engine oil, discovered gasoline mixed in with oil. Why would this happen? Solutions?
Other than knowing you have a tiller,sounds like you have a float type carb. and the float did not shut the fuel off and fuel ends up in the crank case with the oil
Your problem sounds like you need to address the carb. area starting with removing the float bowl and inspect the float needle valve and needle valve seat mainly for dirt and functioning freely. If you have a metal float shake it to see if has fuel in it? if it does get a new one. Drain the oil when you fix the problem and put new in
May 09, 2010 | Garden
My neighbor let us use his troy built tiller and it needs oil but he doesn't know what type of oil to put in the transmition. please help
The recommended lube for a Troy Bilt transmission is 140 Gear Lube. It's tough to find. If you use lighter oil, the trans seals will likely start to leak.
Jun 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Need a downloadable copy of owners manuals.
my 17 in dual tine tiller fouls up the air filter with oil and the spark plug. The prefilter, I can't tell if I put it in backwards or not. Also, the manual says to "fill the oil reservoir almost to overflowing." I don't believe that was right, because I am not sure if that is the reason oil is entering the filter box or not, but I am not going to do that again. I don't know how much oil to add, but it certainly won't be to overflow level. I am going to reverse the prefilter(screen/foam) in the filter chamber and pray that the oil does not foul up the spark plug and filter chamber again. Does anyone agree or disagree?
Apr 22, 2009 | Craftsman Garden
What engine oil do I need for a gasoline Tiller CT2067 - 6.5HP
Find what type engine, go to that engine site, they should have specs.
Mar 27, 2009 | Garden
Garden Logo
235 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
