Question about Belkin Play N600 Wireless Dual Band Router (722868807453)
Can not get into settings stuck on access point
  • 51 Answers
Pug the router in bto the box and go to routerlogin.net and set it up
Posted on Apr 10, 2011
I have just bought an acer iconia w3-810. When starting the set up process I can't connect to the Internet. It says I have no connection to internet. Tried setting up a network and it can't find my...
try connecting to another location like the public library. it could be that your router security setting may be set too high.
http://brandzone.bz/files/catalog/upload/5/8/planshet-acer-iconia-w3-en.pdf
Wireless networks - 29
Installation speed and simplicity Installing a wireless LAN system can be fast and easy and eliminates the need to pull cables through walls and ceilings. Components of a wireless LAN To set up your Wireless network at home you need to have the following:
Access point (router)
Access points (routers) are two-way transceivers that broadcast data into the surrounding environment. Access points act as a mediator between wired and wireless network. Most routers have a built-in DSL modem that will allow you access to a high speed DSL internet connection. The ISP (Internet Service Provider) you have chosen normally supplies a modem/router with the subscription to their services. Read carefully the documentation supplied
with your Access point/router for detailed setup instructions
Feb 03, 2015 | Tablets & eReaders
Tip
How to set up the PS3 Internet Connection
This setting is available only on PS3 systems that are equipped with the wireless LAN feature.
The following procedure describes a typical setup when connecting to the Internet wirelessly.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Confirm that an Ethernet cable is not connected to the PS3™ system.
3.
Select (Settings) > (Network Settings).
4.
Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
5.
Select [Easy].
6.
Select [Wireless].
7.
Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option Automatic. Select Automatic when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
8.
Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
9.
Check the SSID for the access point.
10.
Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
11.
Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
12.
Save your settings
13.
Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
14.
Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
on Mar 09, 2010 | Video Game Consoles & Games
Cannot change transmission rate of Linksys WRT160N
1.With an online-capable game inserted into your Nintendo DS, turn on your system and access the game's main menu.
2.Access the Nintendo Wi-Fi Connection settings.
-These settings are typically found by selecting "Nintendo WFC" from the game's main menu. For detailed directions, consult the manual for the game.
3.At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
entryscreen3-cwz5mha2srvvin44vycqgk0s-3-2.jpg 4.Tap a connection file labeled "None."
emptyconnections4-cwz5mha2srvvin44vycqgk0s-3-5.jpg -If no empty connection files are available, select "Erase Settings" followed by "OK" to create an empty connection file.
5.Tap on "Search for an Access Point."
connection1settings-cwz5mha2srvvin44vycqgk0s-3-9.jpg 6.The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
oIf you receive the error message "No Compatible Access Points Within Range," click here.
7.Tap on the name of your wireless router or access point.
oIf there is a gray padlock next to the name of the wireless access point you wish to connect with, this indicates your router is using a security type incompatible with the Nintendo DS.
If prompted, use the keyboard on the bottom screen to enter the password for your wireless router or access point.
enter_wep1-cwz5mha2srvvin44vycqgk0s-3-14.png 8.Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test.
9.The connection test was successful - Your Nintendo DS is now connected online.
Situation Not Resolved:
If the connection test was not successful, you will receive an error code:
·Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
Apr 21, 2017 | Linksys WRT160N Wireless Router
How to activate gprs on nokia 6300
here is a simple instruction for you to activate your nokia 6300 phone:
1. Go to Menu > Settings > Configuration
2. Choose Personal configuration settings
3. Press Options
4. Select Add new and Access point
5. Fill in a Account name
6. Select Access point settings
7. Set Data bearer to GPRS
8. Select Bearer settings
9. Enter GPRS access point (APN);check your settings.
10. Set Authentication type to Normal
11. Enter User name and Password if requested
12. Back * 3
13. Choose Options and Activate
14. Go Back
15. Set Preferred access point to the access point you just made.
16. Set Default configuration settings to Personal configuration.
17. Select Activate default in all applications and Yes
Nov 08, 2010 | Nokia 6300 Cell Phone
Panasonic dmrez27 dvd recorder stuck on dvd2 setting
If you point the remote towards sensor, simultaneously hold down the number (1, 2, etc) you want AND the enter button for 5 or more seconds it should switch to the number pressed. Remember if you have a second one, make sure it's off or put towel over its remote sensor. Sue
Feb 20, 2010 | Panasonic DMREZ27 DVD Recorder
How do I set an access point for my multimedia messages(NokiaN70)
access point setting doesnt cost u anything....neither receving a multimedia message...only if u sent a multimedia message costs u depending on operator tariff
u can set up an acces point by 2 ways
1.manually...if only u know ur access point..then u need to go in multimedia settings and enter access point
2. ask ur operator they will sent u the multimedia settings with access point..via text message n u can save that automatically
Sep 21, 2009 | Nokia N70 Cellular Phone
Wap setting for nokia n70
Go to Menu��Settings��Configuration��Personal Configuration Settings��Option->Add New.
Enter details for the following parameters:
�� Connection name: myGlobe GPRS
�� Homepage: http://www.globe.com.ph/globe.asp
�� Access Point Name: www.globe.com.ph
�� Username: <blank>
�� Password: <blank>
�� Used preferred access point:<No>
�� Access point settings:
�� Proxy: Enable
�� Proxy address: 203.177.42.214
�� Proxy Port: 8080
�� Data bearer: Packet Data
�� Bearer Settings
�� Packet data access point: www.globe.com.ph
�� Authentication type: Normal
�� Username: <none>
�� Password: <none>
for mms :
Go to Menu��Settings��Configuration Settings��Personal Configuration Settings��Add new.
�� Account name: myGlobe MMS
�� Server Address: http://192.40.100.22:10021/mmsc
�� Use preferred access point: No
�� Proxy: Enable
�� Proxy address: 192.40.100.20
�� Proxy port: 8080
�� Bearer Settings
�� Packet data access point: mms.globe.com.ph
�� Authentication Type: Normal
�� Username: none
�� Password: none
Mar 27, 2009 | Nokia N70 Cellular Phone
Psp
The following items are generally required to set up to connect to a network.
  • A WLAN access point or a wireless broadband router
  • Settings for the access point (SSID, WEP key, WPA key, etc. as specified when the access point was configured)
  • A network device, such as an ADSL/DSL modem or a cable modem.
  • An account with an Internet service provider
Hints
  • An access point is a device used to connect wirelessly to a network.
  • A router is necessary if a PC and the PSP™ system will be connected to the Internet at the same time. A router is a device that enables multiple devices to be connected to one Internet line.
  • SSID, WEP and WPA keys are types of wireless network information. This information may be required when connecting to an access point or a router.
  • User is responsible for Internet service fees.
Example of a network configuration Network equipment connection and setup methods vary depending on the equipment used.
require001.gif Common settings hr1.gif You can create network settings for use in connecting to the Internet through an access point and save them on the PSP™ system. You can save up to 10 connections.
Setting methods may vary depending on usage conditions. The following is an example of commonly used settings.
1.
Check that there is an access point connected to a network with Internet service near the PSP™ system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings).
3.
Select [Infrastructure Mode].
4.
Select [New Connection].
5.
Select [Scan].
The system searches for nearby access points.
Depending on the model of PSP™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
standard001.jpg 6.
SSID is an identifier assigned to an access point. If you do not know the SSID or the SSID is not displayed, contact the person who set up or maintains the access point.
standard002.jpg 7.
Select the type of security that you will use.
The type of security settings required vary depending on the access point. For details on what type to use, contact the person who set up or maintains the access point.
standard003.jpg 8.
Enter the encryption key for the security settings.
The encryption key field displays eight asterisks no matter how many characters you enter as the key. For information on the encryption key, contact the person who set up or maintains the access point.
standard004.jpg 9.
Select [Easy].
Basic settings are set automatically.
standard005.jpg 10.
Enter a name for the connection.
You can choose any name for the connection.
11.
Check the list of settings.
standard006.jpg 12.
Save the settings.
13.
If you select [Test Connection], the system will connect to the selected access point.
14.
If the connection is successful, information about the network connection is displayed.
Hints
  • If the connection test fails, follow the on-screen instructions to check the settings. Network settings for the connection can be changed from the options menu. For additional information, refer to the instructions supplied with the network device and by your Internet service provider.
  • Depending on the access point settings, you may need to enter the system's MAC address to connect to the network. The system's MAC address can be checked under in_setting.gif (Settings) > in_pspset.gif (System Settings) > [System Information].
Jul 12, 2008 | Sony PlayStation Portable (PSP) Console
Belkin Play N600 Wireless Dual Band Router (722868807453) Logo
89 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
