Question about Delta 10"Hybrid Tablesaw with 30"Unifence
I need a aftermarket unifence for a delta 34-670 10"table saw that I just bought. Any suggestions?
rowdy45176
  • 2176 Answers
SOURCE: looking for unifence manual
Go to Dewaltservicenet.com and in the middle of the page at the bottom type in your model number and on the second page you will get a list of the various models with type numbers you can either download a breakdown or an owmers manual for this tool. This is all I can find.
Posted on Feb 23, 2009
efs_perpends
  • 1996 Answers
SOURCE: Dado blade installation
Yes. normally an eight inch stack dado set is used on a 10 inch saw. You will also have to purchase or fabricate a special throat plate (non-metallic) to accomodate the extra thickness of the dado set.
The number of blades used, and therefore the thickness, varies depending upon the task at hand.
Make sure to use the factory supplied nut and washer to capture and tighten the dado set securely on the arbor.
Be very cautious in the use of dados. Do not raise the set higher than 1/4" or so until you are familiar with the use of a dado set. Try to avoid so-called "wobble" dado sets. They are IMHO more prone to dangerous kickbacks and harder to adjust than a stack dado set with dado shims.
Posted on Mar 24, 2009
  • 62 Answers
SOURCE: Motor not working on Delta table saw: I just got a
Ok, the motor turns, but throws sparks on the brushes. This is normal to an extent for universal motors used on that type of equipment.
Try reassembling the saw, and put a blade on it, then try it. If it runs, try cutting a piece of scrap 1x, both crosscut & rip. If the motor can't hold the load, you may still have to replace it.
Posted on Apr 18, 2009
  • 9 Answers
SOURCE: Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Posted on Jun 22, 2009
SRF518
  • 232 Answers
SOURCE: I have an old Delta
go to tool parts direct and search for your tool. there are exploded diagrams and parts lists.
Posted on Oct 16, 2009
N eed a better manual or some help on putting my table together 36-681
http://www.ereplacementparts.com/delta-parts-c-3275.html
Apr 09, 2012 | Delta U30 30' Unifence
"..... 52" unifence When turned on, the tablesaw
Hi, have you considered that the brushes on the motor could be needing replacement? Hope this helps.
Nov 15, 2010 | Delta 10"Hybrid Tablesaw with 30"Unifence
Where can i buy a new motor for delta table saw model no; 36-525 and how much or is it cheaper to buy a new one
Buy the motor from Sears, Tractor Supplies, Northern Tool, some large ACE stores, and some home improvement stores.
Sep 18, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Jun 21, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Motor not working on Delta table saw: I just got a used Delta table saw for free, the previous owner said the motor wasn't working. I wonder if it could just be a switch... how could I check that? I also...
Apr 16, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Lost Owner's Manual
click this link to download your owners manual -->click here<--
Please take the time to give this solution a "Fix Ya" rating.
Thanks for using Fix Ya
Jan 31, 2009 | Delta X5 3Hp Left Titl Unisaw with...
Looking for unifence manual
Jan 30, 2009 | Delta U30 30' Unifence
Delta 10"Hybrid Tablesaw with 30"Unifence Logo
113 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Delta Saw Expert? Answer questions, earn points and help others
