Question about Kenmore HE2 Plus Front Load Washer
Our kenmore washing machine front load is not working what happened was I put the clothes inside and I noticed only that the washing machine was not working when I saw the machine with door locked and add garment light, Then I turned off the machine to see what happened inside I saw the clothes was so wet and with lot of water inside. I tried to re washed again but that lights come up and it not running anymore. So pls help us because we need to use it asap. thanks for your immediate response.
    Brigadier General:
  • 6,277 Answers
(no promises but try this just in case!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Posted on Apr 10, 2011
I was given a kenmore quei pack 2 washing machine.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
best thing to do is put it on a boil wsh with castic soda in no clothes 90degrees wash ok good luck you can buy castic soda from any good diy outlet or even a chemist phamasy
Mar 26, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore top loading washing machine does not clean clothes well.
I would seriously consider getting a newer machine. A brown stain could be rust, or an oil leak. Either way it probably is not worth putting any money into. If this helps, please rate my answer. Thank you.
Jan 07, 2010 | Kenmore Washing Machines
My front load kenmore leaves faint dark streaks in
look carefully inside the tub, gasket, lid. There may be some debris of some sort stuck somewhere causing this problem.
Then run the machine adding only two cups of vinegar. this will clean it.
Aug 20, 2009 | Washing Machines
The washer does not spin during washing cycle or drain & spin cyc
I can a very simple part called the motor coupler...you can find the part at www.repairclinic.com. It costs 13.95. I am fixing my washing machine today, as this happened before and was the answer. Goodluck
Apr 11, 2009 | Kenmore 46462 Front Load Washer
Kenmore Elite front-load
you must remove bottom panel ,,in the center front you will find pump,,remove pump filter,,always unplug first..it has slugg,..than after you clean filter run your unit once a month with a pint of bleach and hot water only..also wipe your rubber gasket or bellows with a touch of bleach..
Dec 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore washer leaves dark streaks on light colored clothes
I suggest you first take a clean, white cloth wetted with a stronger solvent such as 'Oops,' carburator or brake cleaner (with these two, DON"T overspray, they will damage plastic and paint) and wipe the drum inside to make sure there is not some gunk adhering that is gradually depositing itself with each wash cycle.
If you have a shade-tree mechanic in the family, they may have gotten a gob of grease on clothing that transfered to the inside of your machine.
If you don't find enough on the cloth to have caused the problem, I think you have lost a seal on the drum-side of the transmission.
Jul 01, 2008 | Kenmore 43042 Front Load Washer
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
60 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
