Question about Sony Playstation 3 (PS3) Console
Ps3 wont start up
When you turn on the game it say not correct hard drive, and it wont start
1) Have you tried reseating the hard drive?
2) Stand the ps3 on it's wide base, with the touch sensitive buttons facing you
3) Open the plastic cover on the left face of the machine (the narrow base when the machine is standing vertically)
4) You should see the HDD cradle and a blue screw which holds the HDD in place.
5) Remove the blue screw
6) lift up the metal u shaped tag, so it points towards you
7) Slide the HDD sideways by gripping the tag
8) Reverse the procedure to reseat the HDD.
If you are lucky this might work!
If not you could try replacing the HDD with a new one.
Posted on Aug 08, 2008
SOURCE:
My ps3 wont turn on and flashes red press once stops flashing pressed again and it starts to turn on (green light) then stops and beeps then flashes red
Hello
This is due to a hard drive fault.Try removing the hard drive and reinstalling it.
Also while it is out, use a can of compressed air to blow all dust from your ps3.
If the above does not work your going to need a new hard drive.
Oct 12, 2011 | Sony Playstation 3 (PS3) Console
My playstation 3 : everytime i turn it on it goes green then back to red and wont turn on? When it was working it just froze so i turned it off and since then it hasnt turned back on
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning .
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
My PS3 wont boot. Says "Correct hard drive not
I would suggest:
1) With PS3 off 2) Remove drive 3) Turn PS3 on 4) Let it complain about missing drive 5) Turn off PS3 6) Put drive back in 7) Turn on
If it still complains, try safe boot recovery mode again, choosing option 3, then again with option 4 -- If it still doesn't work, it's not looking good, bit hopefully those should sort it unless the drive really is kaput.
Dec 25, 2010 | Sony Playstation 3 (PS3) Console
Starting PS3
some how it can not read the drive... maybe you just need to push it in better .. or the drive is trashed.
May 09, 2010 | Sony Playstation 3 (PS3) Console
Putting old hard drive in new ps3 to get game saves error
You cannot switch a hard drive from an old ps3 and put it into the new one. The new ps3 will know that a new hard drive was inserted and offer to format it.
To get the games off the old hard drive, put it back into the old ps3. Insert a USB flash drive into a USB port on the PS3 and you should be able to copy saved games from the hard drive onto the USB flash drive. You can then plug the USB flash drive into your new ps3 and copy off the saved game info,
Mar 17, 2010 | Sony PlayStation® 3 (80GB) Console
Turn on. Message: ''Cannot start. The correct
you try reformatting hard drive or restoring ps3 ? do a search for this warning u will loose and saved data on console. photos musics etc...
Mar 06, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont come on loads up but just a black screen
This is usually how they boot up with no hard drive installed. See how it starts with the hard drive removed. Try after you reseat the hard drive. Try a different hard drive. Good Luck
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Ps3 says cannot find correct hard disc
The ps3 finds hard drives in a specific way. what you have to do is format the hard drive using the ps3 and then you should be fine
Feb 12, 2009 | Sony Playstation 3 (PS3) Console
My PS3 will not boot-up!
might have to reset the ps3
do a factory reset you will lose all the saved games
hard drive could be failing.
you might have to send it back to sony for replacement
call them to see if your console is under warrantee.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 15, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
75 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
