Question about Garden
Have cleaned carburetor and need to know the proper way to adjust the carburetor now
  • 2,239 Answers
You did not say what machine this is, however most carbs will run on a basic setting of 1 1/4 on the L and 1 on the H screw, now start the saw and warm up, start screwing the L screw in, the revs will increase as the mixture weakens, when the saw reaches its peak and starts to die because its too weak turn the screw out 15 minutes on a clock face, check the saw accelerates well with no flat spot, if need be turn out a little more until it does, now adjust the idle screw so as it idles well without the chain moving around the bar, the H screw is a govener so the more you screw it in the faster it goes, you realy need to check this with a tachometer it should nor exceed 12500 rpm
Posted on Apr 10, 2011
Trx350tm2002model, runs fine after carburetor cleaning but is dying soon as rpm is increased What adjustments can I make to carburetor since I lost the adjustment setting to the fuel intake needle valve.
The carburetor actually is a mixing place for the air and fuel. If the mixture is not in appropriate proportions this issues surfaces. Many a times as the carburetor gets old, the jet, idling valve etc., may not function properly. My suggestion would be to replace the carburetor unit itself or try adjusting the air intake valve or air filter adjustment.
Dec 20, 2017 | Motorcycles
Proper adjustment for carburetor
A proper adjustment of a carburetor can only made IF ....
The seals on the crankshaft are good , no leaking gaskets and a good clean fuel line (and no tankairiation problem) and the cillinder compression is good and also a clean airfilter on the carburetor if you adjust .
Then if thats good then only you can trust on the L + H and trottle adjustment
Echo PB 755T Operator Manual Carburetor Adjustment
Jul 19, 2016 | Echo Garden
What is the float adjustment on the carb I know how I just need the measurement on it
Search Results
    Adjusting Carburetor Float Level - YouTube
    ? 2:06
    https://www.youtube.com/watch?v=aiexehn33kg
    Oct 9, 2013 - Uploaded by Mike Nixon
    How to adjust a carburetor's float level. ... Motorcycle Mikuni CV Carburetor Cleaning for Suzuki, Honda, Yamaha Tutorial - Duration: 30:56.
    Motorcycle Carburetors ' Float Height Setting ' Fix.com
    https://www.fix.com/blog/motorcycle-carburetor-float-height-adjustment/
    Oct 17, 2014 - Learn about carburetor parts, how they work, and how to adjust thefloat height to fix your bike from running rich or lean.
Jan 11, 2016 | UM Motorcycles
I need to know the proper tuning of ucal mikuni carburetor with mixture adjusting screw on bottom of cabr (beneath float bowl), an idle adjust screw and pilot screw (hopefully pilot fuel screw since s
Why did you need to clean the carb? Routine servicing of the aircleaner would keep the carb clean for life. The pilot screw should be 1.5 turns out approx. with a small adjustment either way. Idle speed is set to a smooth low idle.If this doesn't fix it have you got something in the carb not replaced correctly? The float needle/float assy? How did you clean it? Have you introduced fluff/dirt into the carb and did you blow it clean with an airline?
Oct 09, 2014 | Motorcycles
My RPM is not stable because my carburator is not clean...i want to clean it but i dont know how..will you please give me an instructions to clean my carburator?my car is honda vti 96 model. thank you
As i understand, all VTi´s had injected engines, but in case your particular model is carburated, my advice is: Take it to have it cleaned by a mechanic that knows carburetors. Have in mind that carburetors have a myriad of screws, jets and wires that might get lost or switched during reassembly. Furthermore, the jets, butterfly openings, floats and other devices require detailed, minute adjustments for proper functioning. All those adjustments are lost when disassembled for cleaning. Also, some rubber / plastic parts and seals will not withstand the acid bath, so a new kit must be included as well.
Jun 23, 2011 | 1996 Honda Civic
I have a John Deere Riding lawn mower which starts
Hello roobar2009:
>>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
>>If you have Changed the Filter and the Gas and the Problem is Still happening, then
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 17, 2009 | Garden
Toro lawnmower starts then cuts off. It appears to be leaking fu
If there is a fuel leak causing this problem it could be from the line going to the carburetor or the float bowl. If no leak is present there, could be flooding or a sticking needle in the carburetor allowing fuel to enter constantly.
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
No start
Hello djb4297:
Not knowing the Make or Model of the Engine; I am Sending a Basic File for Checking the Carburetor.
>>The Following is a Basic Instruction File I made for Checking the Carburetor Solenoid. Any Input is Appreciated.
>>**Check for Current/Voltage (10.5 VDC Minimum) to the Carburetor Shut Off Solenoid. If the Carburetor Shut Off Solenoid has Current, then On Some Solenoids you can Remove the Needle and Replace the Solenoid to Test them.
>>****PLEASE DO NOT OPERATE THE MOWER WITH THE SOLENOID BYPASSED IN THIS MANNER. THIS IS "ONLY" FOR TESTING.****
>>For Others, Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 1/2" to 3/4" Long for the Horizontal Mount Solenoids and 1/4" to 1/2" Long for the Vertical Mount Solenoids. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid.
>>***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES***
>>Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jet Properly.** **Use 440 Wet Dry Sand Paper and Engine Oil to Clean the Pin. Wet the Sand Paper with Oil Until it is Flexible and then Lightly Polish the Pin. There is Some Slop/Free Play in the Solenoid Pin. Usually the Electromagnet is Simply Not Pulling the Pin as it Should or there is a Small Bur on the Pin. Use 440 Wet Dry Sand Paper and Engine Oil to Clean the Pin. Wet the Sand Paper with Oil Until it is Flexible and then Lightly Polish the Pin. Clean and Lightly Oil the Pin before Inserting it Back into the Solenoid. Just a Film of Oil is All it Takes.**
If No Carburetor Solenoid, then the Carbureotor Float Needle Valve is Sticking and I Suggest you Soak and Clean the Carburetor.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Mtd Garden
Tooo much fuel pull cord fuel expels through exhast.
Hello aurora12104:
The Carburetor Float Needle Valve is Not Seating Properly and is Causing the Engine to Flood or the Head Gasket is Blown between the Push Tube Galley and Cylinder and the Head Gasket Requires Replacing.
Check the Oil and Make Sure it has Not become Contaminated with Gas. Change Oil if it has a Gas Smell or the Crankcase is Over Filled.
Soak and Clean the Carburetor and Replace the Float Needle Valve.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Garden
Carb needs cleaning
You actually have 4 carburetors on that bike. Remove the bodywork, the seat, and I think the fuel tank has to come off, then you should see the four carbs. Best bet, take it to a dealer and have them do a tune up, they will clean and adjust the carbs as part of the service.
Nov 27, 2008 | 1997 kawasaki ZX-6R Ninja
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
