I receive hp catridge error when i refill the catridge and install in my printer.
    Guru:
  • 352 Answers
Is it a 4 Cartridge printer or two cartridge printer?? Depending on the model of printer you own most cartridges will not re-set the ink levels after being refilled, This will cause a error message regarding the cartridge being empty but you are able to continue to print by following the instructions on the screen.
HP Printers that take the 02 Range of cartridges (6 separate colours) Can not be refilled. The printer simply stops working if it thinks there is an empty cartridge and there is no way to reset the OEM Cartridges. Refillable cartridges and compatible cartridges are available though.
If the Error is relating to recognizing the cartridge try simply cleaning the contacts on the front of the cartridge and also inside the printers cartridge holder. Some ink may have leaked and worked its way between the cartridge and printer.
Hope this helps Regards GM
Posted on Apr 10, 2011
    Guru:
  • 89 Answers
Check if cartridge is genuine
check if it is really a brand new one or fake
power cycle the printer
check if it has an alignment option,align the cartridge with new inks
check if it has a clean utility automatic cleaning
or you can manually clean the contacts on printheads which detects the inks the you inserted
reset the unit if you know how to
different printer has specific way of resetting
most probably you are just getting a rejection error try using theold one if that fixes the issue it means there must be an issue with brand new inks
hope it helps you
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
I receive the hp catridge print error message when I refilled both the catridges. Thank you.
So now you need to download the utilities from www.hp.com......the one you will need is the printer printing utilities ...this helps clear printing errors.....(Drivers and support should be what you looking for...)
Apr 06, 2011 | HP Deskjet F335 All-In-One InkJet Printer
Refill cartridge, then the monitor scanner to light an inscription error Sñanner 20
just remove the catridge and install the original catridges and check.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 27, 2010 | HP LaserJet M1005 Printer
Catridge error message when printer on,hp5610
hi
you need to replace one or both of your cartridges with new ones
if you have the old you can check , what cartridge couse the error and you can refill the old one like this
if i helped you pls vote
Jul 20, 2010 | HP Officejet 5610 All-In-One InkJet...
Ink catridge error after replacing my ink catrigdes
you need hp 22 and not hp 57
you can still refill the old one
check here how
Jul 14, 2010 | HP Officejet 5610 All-In-One InkJet...
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
Doesn't read new black cartridge
HP Laserjet 3055 - New Black Catridge.
Solution :
01. First remove all catridges from the Printer.
02. Clean the printer with Cleaning liquid in the catridge seating cover.
03. Re install the catridges gently and assure that it is properly seated.
04. Always use only genuine HP original catridges which will give longer life for the printer.
05. Refilled or Reinked ribbons will cause lot of damages to the printer.
06. Better to have the regular servicing for this printer.
If the problem continues, please call local authorized HP Printer service engineer.
Jul 17, 2009 | HP LaserJet 3055 All-In-One Printer
I have refilled my black ink catridge in HP PSC 1410 . now my printer does not print any pages . i have cleaned my printer catridges, still it's not printing any pages . plz tell me the detailed steps to...
Sounds like the printer thinks the cartridge is empty. Old PSC units had a 3 cartridge memory - you kept 3 cartridges and cycled them to trick the printer into thinking it had just received a brand new cartridge, rather than a refilled one.
Jun 16, 2009 | HP PSC 1410 All-In-One InkJet Printer
Error on my printer - Ink Cartridge not properly installed ...
well, for starters you did install the cartridges correctly. Try turning off the printer then reboot the system, then turn on the printer again. if that doesn't work you should consider buying a new ink cartridge chances are most printer models may not accept refilled ink cartridges.
Hope this helps:)
Oct 18, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
100 people viewed this question
jasbo
jasbo
