Question about Maytag Dishwasher
12 year old GE Potscrubber, water leaking from bottom .....what now?
  • Maytag Master
  • 3,053 Answers
Hello, hunebe
I was trying to help you out here. I am not sure if this well help you? But here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting on most common dishwashers. If you go to this link and click around, I am sure you will find out so much about your Dishwasher, you will know more that the company that made it.If you already solved the problem this is good for future problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please if this helps you at all, and if you can find the time to rate my help and some kind words written would be appreciated for my free help. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Ge potscrubber 940 dishwasher
My GE potscrubber, model GSH942 (very old) is not working, as one of its part was fumed (burned). Though the dishwasher is old, it was doing perfect job. Kindly advise whether there is any hope to save it. picture of damaged part is attached.
664ecbc5-d293-4bf8-9a26-d4eb60b56c88.jpg 3afc25c1-d149-45c7-8546-1d01d256fcd6.jpg 2ffcde17-d805-44d2-865f-843483703dd0.jpg
Aug 10, 2013 | Dishwashers
GE potscrubber 940 isnt cleaning properly. Glasses cloudy, some dishes still dirty. Is there a filter that can be checked?
You need to add some vinegar. Depending on your water as much as 4-5 cups per load. I have had a Potscrubber for close to 10 years and discovered that they clean beautifully as long as you don't skip the vinegar.
Mar 01, 2011 | Dishwashers
When I turn on the GE PotScrubber dishwasher with water, water is leaking out from disher please advise. According from one repair guy, it is related to pump issue please adivse
first try to look and see where the water is coming from,,,the bottom of the unit,,,,or the front of the unit...remember the door has a seal all the way around it and it has to seal correct and make sure the latch is all the way in lock postion
Feb 19, 2011 | Maytag Dishwasher
I have a GE Potscrubber dishwasher which is about 13 years old. I recently experienced a problem when I ran the dishwasher I had water leaking onto my floor. In addition, the cycle had not used all the...
The pump seal may be the problem. There are a number of places on the net where you can get step by steps and the the parts to replace the seal. Some recommend just getting a new motor pump housing which is 150. I just purchased the impeller assembly (it has all you need) and it cost $25 with shipping. Only thing is I did not realize I also had a leak in the solenoid stem valve. Let me know if you need the link I was talking about.
Dec 08, 2010 | GE Dishwashers
Sink dishwater intrusion
Hello- Find drain hose from dishwasher under sink. Should have gooseneck ~ in hose run to keep water from getting back into dwshr. Does full sink drained all at once push water into tub? Sometimes stuff not disposalled yet blocks drainage. Older motors can tend to become weak with age, not pumping as much water out of tub as it used to.Anyway- Hope this helps- ED
Mar 01, 2010 | GE Dishwashers
GE Potscrubber disher - water leaks out while filling
I would try removing the cover and make sure the float isn't sticking. On mine the float pushes on a rod that goes through the tub to a micro switch. When you hit it, it probably frees it up for a while. Hope that helps.
Jan 21, 2010 | GE Dishwashers
My GE dishwasher is leaking water from the bottom of the machine
first check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
Jul 01, 2009 | GE 24 in. GLD6200L Built-in Dishwasher
I have a GE Potscrubber dishwasher that only hums, won't run
I have a portable that had the same problem. I called a repairman and he turned a fan blade on the motor. Mine is located on the right side about 12" in. It gets hung up when it is run often enough. If your problem is the same is mine all you have to do is turn the blade and it works like a charm. Hope this helps.
Feb 18, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
GE potscrubber 700
upc leaks when dishwasher is emptying
May 12, 2008 | GE Dishwashers
Dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Jun 18, 2007 | GE 24 in. GSD2600GBB Built-in Dishwasher
Maytag Dishwasher Logo
110 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
