Question about Jura Capresso Impressa Z5 Espresso/Coffee Maker
My Jura Capresso, Z5 is leaking water from the bottom - appears right side - of the machine. The valve from the water container appears to be in working order. Also - where could I find a diagram of the interior components?
    Brigadier General:
  • 3,917 Answers
Hi
The connectors on capresso machines are very tricky. The reason for the leaking could be to do with the seals. Take it apart and make sure all the rings and pressing clamps are in the right place. Also take a good look and on your hot water tank, and the pressure relief valve in back of machine.
Also it is recommended that the Jura coffee machines to be serviced every 2 years.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 10, 2011
Where do you add a tablet to the Jura Impressa Z5
Decalsifying tablets are diluted in the water. Cleaning tablet is added in the Ground coffee area.
May 27, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
Water in disposed coffee container jura impressa z5
You may have to clean the unit using cleaning tablets, also there is a flap in the bay (remove the tray and use flashlight, sometimes it cakes up and moisture collects. Final thought is you may need to send it in to Capresso/Jura for service. Mike
Mar 08, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
Just got a Jura x5 from a friend who has not used it in 3 years. Plugged in, set up, and display reads "system fills" but no water is released from the water reservoir. Machine makes a sound, like the...
Message :Fill System
Causes/Troubleshooting:
Leaks in the fluid system-localize the leaks and seal them.
Blockage in the fluid system, no water can be fed - Localize blockage and replace blocked components (valves, heater, tubes) if necessary.
Flow meter-count error - Open the floow meter by a quarter turn and clean it, replace if necessary.
Oct 01, 2013 | Jura Capresso Impressa Z5 Espresso/Coffee...
Where can I send my Jura z5 for repair?
Which part of the world are you based? Go to www.jura.com, select which part of the world you are based, and it will take you to a local agent.
Otherwise google it
Aug 20, 2012 | Jura Capresso Impressa Z5 Espresso/Coffee...
How do I fix our Jura Impress Z5 coffee machine. It says "System Fill"
Press the button to the right of the function wheel that should be lit, this will then purge air from the water pipes and fill the boilers, the unit should then operate as normal.
Apr 29, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
Water will only dispense out of the frother.
It could be several soutions to this problem. First of all, try to clean the sieve in the brew unit, it may be clogged. Take out the tray, in between the 2 brown "lips" inside you can put your finger up and clean out all the old coffeegrounds stuck up there. Then put everything back in place and run a Rinse machine operation.
If this is not helping, listen out when you start up the machine; You should hear that the valve is turning 3 times, if it doesn`t it can be a problem with this valve not opening in right position. Then all the water would go out in the tray, and not into the brew unit. That maybe can be solved by changing this Multi ceramic valve or the Main Electronic board. Then it`s a job for a sertified Jura technician.
Jul 04, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
My jura capresso says system fill...it makes a lot of noise
System fill is usually when the machine auto solenoid fill valve is putting water into the boiler. If it is making noise then the solenoid is clogged or there is no water getting to the solenoid.
Jun 16, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura capresso z5 not working
Call Nick or Anthony at Style Cafe on 0844 2279229 they have a wealth of knowledge on these machines and can Service them if required
Jun 11, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Capresso Impressa Z5 Espresso/Coffee Maker Logo
423 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
