Question about Fuji FinePix Z5fd Digital Camera
How do you plug the battery into the battery charger?! I dont get it!! Helppppp?!
  • 26 Answers
Look for arrows on your battery that correspond to symbols on the camera. If that doesn't work, peer in and take a look at where the contacts are inside the camera. Try to align the contacts on your battery to those when you insert it. Hope this works!
Posted on Apr 10, 2011
Navigon 70 charging trouble
The battery probably needs to be replaced.
Mar 04, 2014 | GPS
It keep giving me a message to plug in my charger because my battery is going dead so i bought a new dell charger the original one that goes with the netbook, and it worked for awhile, but now its telling...
it might be the battery, i had the same problem with my netbook the charger is ok but the battery died i can use it if it is plugged even if the battery is dead.you can tried taking the battery off the netbook if it turns on the charger is ok.
Sep 13, 2013 | Dell Inspiron Computers & Internet
Toshiba Satellite A45-S120 laptop battery does not charge
Sounds like you need a new battery. Try removing the battery and running the machine on mains power. If that works, you know the charger is ok. Its usual for batteries to deteriorate over a few years, so my money would go on a new one.
Mar 23, 2012 | Toshiba Satellite A45-S120 Notebook
Battery was dead and phone got switched off i charged it ,still i cannot switch it on
hi there!
if the battery was just drained, plug the phone with its original charger (to make sure that the charger is in good working condition too) directly on the wall (dont use power extensions for now) and dont turn it on yet. wait for 2-5 mins, see if the phone responds (lights on, or the battery bar on the right or top part is moving). make sure that the charger is plugged in all the way too. if your battery is more than a year old, and has been draining fast when you use it, its possible that you have to change batteries already.
just make sure that the charger you're using is working fine with phones too.
Apr 07, 2011 | Nokia E52 Smartphone
Chair dont take a charge
Get new batteries If your batteries are 2-3 years old its time for new ones. You can check the output of the charger by using a digital voltmeter Set the meter to 200 vdc and plug it into the two outter holes of the charger port with the charger plugged in you should read 27-30 volts. and with the charger unpluged you can aslo read the voltage of your batteries. fully charged they should read 25 -27 volts. If when charging you don't read 27-30 volts then the charger isn't working and you can get an offboard charger cheaper than the onboard just charge thru the charger port on the joystick. Hope this helps
Feb 03, 2011 | Jet 3 Ultra Power Chair
Plugged in to charge battery, red light flashing, no green light on, charged all night still flat, what could be the problem.
Hi. Sounds like there is no connection between the charger and the batteries. The charger uses the voltage in the batteries to regulate the charge. If the charger is not connected then the charger will not operate at all.
The fault can be a broken wire in the charger plug, or faulty charger socket on the scooter. Can be caused by faulty battery connectors, or wiring from the charger socket to the batteries.
Try moving the charger plug in the socket while the charger is operating. These sockets sometimes wear and dont contact properly.
The best way is get someone with a multi-meter and try and trace the fault for you.
Good luck. Neil.
May 28, 2010 | Pride Mobility Products Hurricane PMV...
Although tradesman moterhomde plugged into electrical, engine's battery loses power, any suggestions as to why?
I am assuning you have an operation (read "working") isolation switch in your system. Such a switch (mechanical or electronic) will isolate your coach battery from your chassis batery. If you dont drive the vehicle often, it is possible for your chassis battery to go dead while the coach battery remains in tip top condition. (Coach is always on "charge". Im going to guess your chassis battery is not new.
Of course when you drive, you charge the chassis battery and in some installations, you also charge the coach battery. You dont want the coach battery to run the chassis - think about it and you will understand why. Other installations provide a switch that will allow you to start the vehicle with the coach battery if required.
If you dont go out often, consider a small trickle charger for your chassis battery. Since you keep your motor home plugged in, you have 110 V AC power available in the coach. Just plug your small trickle charger into the motor home and charge your chassis battery. Remember to disconnect the charger before you start the coach.
Safe travels. Let me know if this helps.
A
Sep 21, 2009 | Measuring Tools & Sensors
Optio a10 charger
if you don't see a light on the charger lite up its the charger, or the internal batteries are no longer excepting the charger. my first guess is the charger itself.
Sep 25, 2008 | Cameras
Fuji FinePix Z5fd Digital Camera Logo
13 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
