Question about Esker VSI-FAX
I am using VSI fax on a server running Windows Server 2003 and I have recently had problems with the modem loosing connection with the com2 port. Is this a problem that occurs with vsi fax? Also, my modem being used is made by Mulit-Tech.
Iv had the same problem also with a multi-tech comm modem, only way i'v found to get the problem fixed is to restart the server and run command vfxserver start
Posted on Oct 31, 2011
Everyone can can connect to my Remote desktop on my server, also they can view activity on port:80 so my website's but when they want to connect to a game very very few people just get timed out? how is...
Allowing multiple access to a server desktop is a large security issue !
Port 80 is a common port used for a variety of applications so common access would be possible from multiple clients.
However games have a different set of ports that are required. Using port 80 for games is asking for problems.
You should set the security policy for the ports your game actually requires.
The firewall will also have to be configured.
Router configuration is another key area for running any form of game server again with the correct port forwarding set up for the game in question
I have a WHS server fo rbackup and media streaming and an SBS 2003 regular server for games (Halo) I followed the guide that came with the server component of the game to fully understand what was required for the ports etc.
Ideally you should also be on a fixed IP from your ISP too.
If your ISP does not allow servers you may find that high traffic is throttled by the ISP end.
With a 5mb x 800k high speed connection I can sustain 8 computers internal and another 10 external before lag issues kick in. My ISP does support servers and I am on a fixed IP with COGENT pipe as primary
Note also that I have to ensure than none of the internal computers are running bandwidth intensive apps such as torrents toolbars etc. All internal machines are also CLEAN with regular security scans and such as any machine having a security issue could be prone to extra bandwidth usage.
As you are running a server the info above should not be too confusing and easy to follow.
Feb 15, 2011 | Microsoft Windows Server 2003 Enterprise...
I need driver of us robotics fax modem model 5633
For Windows 2000, Windows XP, Windows Server 2003, and Vista 32 bit Click HERE.
For Windows XP 64bit Edition (Rare), Windows Vista 64bit Edition (Not Rare) and Windows Server 2003 Click HERE
For a link to the Download page click HERE
Hope this helps.
Brad Wieland
Nov 13, 2009 | HP Computers & Internet
Usb modem driver
there are other peripherals that conflicts with this modem. try to plug this usb modem alone without other peripherals connected and check. if the problem persists then the modem itself has a problem
Nov 05, 2009 | Hiro (H50113) Analog Modem
I have a zyxel p600 series modem connected to a Belkin wireless router. I am trying to run a web server on port 80. The modem was using port 80 for access to the internal settings. I changed that to...
Your setup looks correct to me. It might very well be that your ISP is blocking port 80. Go here and check from your server if port 80 is accessible.
If you are the only one that wants to connect to you server, you can simply choose another port to use, i.e. www.myserver.com:801. Set port forwarding form port 80 to 801 in your router.
TCP&UDP - from 801 - to 80 - [serverIP] - [Webserver]
The better way is to use a service like DynDNS.com or No-IP.com. You can register a DNS name (like myserver.dyn.com), which redirects to your public IP. The trick is to update your IP address, so even if you have a dynamic IP assigned from your ISP, the redirect will point always to your server. Most routers have the ability to set up with DynDNS, so the process runs in the background and you don't have to update manually - check your router manual.
The second part of this beauty is the redirect to a different port. So even if your port 80 (and 25 for that matter) are blocked, you don't have to have an arbitrary number in your URL (http;//myserver.com:801). You can find more detailed information here.
For a quick check, change your webserver to run on port 801, enter the redirect in your router and see if you can get to your server from the outside (internet). If you still can't access the webserver, the problem is not a blocked port.
Hope this helps, but if you have any more questions, just come back here and leave a comment - I'm happy to help you figuring this out.
Oct 23, 2009 | Computers & Internet
Remote access for 3com firewall network
dial in using the vpn to the windows 2003 server network and call the remote desktopof the server using the netbios name or using the local ip address
Aug 17, 2009 | 3Com OfficeConnect VPN Firewall - Firewall...
We recently experienced a power outage and unable to log ont
In most cases you just have to reset your modem and/or router, to do this just unplug the modem for the mains for 2 minutes, plug it back in and wait another 2 minutes for it to settle down, then you can try to reconnect to the server.
Regards.
Jul 14, 2009 | Microsoft Windows Server Standard 2003 for...
I have an IPhone that was purchased recently. It has been fully updated through ITunes. I am trying to connect to a Windows SBS SP2 server. I can connect to other sbs servers just fine. I have compared all...
You have SP2? Is that for Exchange Server or the SBS 2003 OS or both? Make sure you have the latest Service Packs installed for both. I think that's SP2. Exchange Server has to be updated to work with the iPhone. Check that the settings in IIS are the same for Security, Authentication where to use SSL (although different certificate for each server) etc. for OMA, OWA, Exchange etc.
Mar 30, 2009 | Apple iPhone Smartphone
My Dell PowerEdge 2500 has 2 configurable com ports which are setup as Com1 IRQ-4, and Com2 IRQ-3. My problem is that everything seems to say that they are there and active, but my software only can talk...
That "in-op" COM port is in fact, probably defective. Had many cases where 1 works/1 doesn't. Buy a cheap, PCI COM port board, install the software, and plug away!
Cheers,
gurutim
Mar 19, 2009 | Dell PowerEdge 2500 Server
Driver not found for server 2003
when you do not find the drivers for windows server 2003, try using the drivers for Windows XP.
Most drivers for XP work on windows server 2003
Canon Download page is Official Canon Drivers and Software
Follow istructions, insert model and install drivers.
Start driver setup with scanner USB unplugged.
Sep 26, 2008 | Canon FAX-L350 Plain Paper Laser
Internet connectio
Vista is 64 bit OS, server 2003 standard is 32 bit. Change Server 2003 to Server 2003 R to get compatible. See Microsoft website. May suggest Server 2008.
Good luck.
Feb 13, 2008 | Microsoft Windows Server 2003 Web Edition...
Computers & Internet Logo
218 people viewed this question
Top Esker Computers & Internet Experts
David Payne
David Payne
Are you an Esker Computer and Internet Expert? Answer questions, earn points and help others
