Question about Brother HL-2150N Laser Printer
Brother Printer 2150N, toner is on and toner is Ok, but printer not working
    Master:
  • Brother Master
  • 956 Answers
Don't waste your time.
Uninstall printer prog, reinstall latest update from brother website.
Posted on May 26, 2011
Drum and error light
The drum unit has exceeded its programmed life. You can either rplace teh drum unit with a new one or if the print quality is still ok and paper jams have not been a problem, you can re-set the drum counter and clear the error lights. To re-set the drum counter, open the front of the printer where you access the toner/drum then press and hold the Go button until all lights come on in turn then go off. Release the go button and close the front of the printer.
Dec 16, 2015 | Brother HL-2150N Laser Printer
OPC-Life over error. How to fixit
If the print quality is still acceptable you may be able to perform a reset on the drum counter. If print quality is bad you will need a new drum. Reset instructions at this site.
Brother HL 2150N Drum Unit Reset Instructions
May 26, 2015 | Brother HL-2150N Laser Printer
Check toner level on brother mfc9320cw machine
On the Brother MFC-9320CW you can check the toner settings through the printer directly. Go to your printer and press the "Menu" button (located in the center, slightly under & to the left of the screen). Then arrow down and click on "6. Print Reports." Select "Ok." Then arrow down and click on "5. User Settings". Select "Ok". Press "Start" to print the report. On the last printed page will be a list of toners and the bar will show you how much toner is left. Hope this helps.
Mar 21, 2012 | Brother MFC9320CW All-In-One Printer
Brother HL - 2150N Paper is jammed inside printer; how do I remove it ? URGENT - business printer... thank you!!
Open the front cover, remove the toner/drum cartridge.
Open the rear cover, look for a jam lever you can press down then remove the paper from the back.
If you try to pull the paper out through the front you can damage the gear system.
Use both hands to try and limit the possibility of tearing the paper.
Jun 14, 2011 | Brother HL 2140 Laser Printer
Hi when I turn on the Brother HL 2150N the yellow toner light stays on & I can't print
Silly question I know, is the toner new install if not could have run out.?
Would you by chance have a replacement to insert, to see if problem perstists?
May 26, 2011 | Brother HL-2150N Laser Printer
Cannot get at paper jammed in printer. How do I do this
You this manual to clear your paper jam.
Directly go to page No. 91 it explains how to open the door and paper tray to clear the paper jam.
http://static.globalcomputer.com/pdf/Brother-HL-2140-Mono-Laser-Printer-Manual.pdf
Regards
Rudra.
Oct 11, 2010 | Brother HL-2150N Laser Printer
We've replaced the toner on a Brother HL-2150n with a brand new shop bought cartridge and the only thing lit is the Toner light, nothing will print. We've opened it up, shook the toner, took the toner out,...
Most Brother printers need manually reseting when either the drum or toner is replaced. Sometimes it doesn't need it and sometimes it does. Don't ask me why because I have no clue lol. What you do is open the Front Panel button that corresponds on the top with the blue botton. If you hold it from the inside of the printer until all the lights flash ontop of the pritner, then you let go and close the door. This should reset the printer. I hope this helps and I explained myself well lol
Jun 11, 2010 | Brother HL-2150N Laser Printer
Drum light flashing
We have just changed our drum unit but the drum light is still flashing. The printer is printing though. Any suggestions?
Apr 12, 2010 | Brother HL-2150N Laser Printer
Brother Printer 2150N - toner light has come on & toner is OK
Bought a 2150 in 2007. In 2008 toner light came on. Bought a new toner cartridge and installed. Light would not go off. Called Brother. They had us do the following:
1) Turn power off
2) Open front cover
3) Press white button (left side) 2 times and hold
4) Turn power on
5) Press white button 6 times and hold. All 3 lights should come on.
6) Close cover
7) Press blue button 3 times. Should print demo page.
We took the new cartridge out and saved it. The original is still working fine.
Feb 24, 2010 | Brother HL-2150N Laser Printer
Brother HL-2150N Laser Printer Logo
211 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
