Question about Sewing Machines
My mother"ssewing machine willnot pick
  • Sewing Machines Master
  • 1,133 Answers
I saw Nelco on this website http://www.sewusa.com/Sewing_Machine_Manuals/Nelco_Sewing_Machines.htm
purchasing /obtaining a manual is always very helpful when working with a sewing machine.
However, simple stuff to check, is the needle in the right way, with the scarf (groove) to the back?
Is the needle new and the right type of needle for this machine? Sorry, I don't know a lot about Nelco however, most machines use 130/705H system needles, but there is always the exception, especially with something 40+ years old so it pays to check it out.
And lastly timing, the needle needs to be down at the lowest point as the rotary hook comes around to catch the thread. If this isn't happening, then it could be that the timing is out on the machine. It's never happened to me but it can happen. But I'd suggest you try changing needle, check threading path and bobbin firstly.
Good luck.
Posted on Apr 10, 2011
I cannnot get my Mother's old Singer Stylinst 416 sewing machince's bobbin to turn. What am I doing wrong?
Your mechanical machine could probably benefit from a professional service. Sounds like it has seized due to old oil that has dried. I've successfully used the following method to resurrect some older seized machines. In addition, the machine may have been knocked out of time when the needle broke. This can be corrected during general service or you can search for "sewing machine timing."
Wheel on right side that controls the needle up and down is very tight...
Singer Stylist 416 Instructions Manual Page 4
Jul 31, 2017 | Singer Sewing Machines
Does any one know anything about a sewing machine model 217-APP no 457. Think it may be a singer, have just found it in late mother-in-laws shed. It won't pick up the bobbin thread but runs ok
not picking up the bobbin thread is an indication of needle / hook timing
thread tension problems appear as a mess of stitches under the cloth
the timing can be checked by having the needle full down and the hook of the bobbin case should be at the needle just above the eye of the needle
if it is too early or late then it is not in position to get the thread
May 13, 2015 | Sewing Machines
Riccar stretch 500fa Needle won't pick up thread from bobbin
Check to make sure you are using the correct needle for the machine, that it is a brand-new needle, and that is installed facing the correct direction. Other than that, it's quite possible the machine was knocked out of time and needs service.
Apr 07, 2017 | Sewing Machines
My sisters singers brand new Athena sewing machine she just started jusing about 5 or 6 times just stopped picking up the bobbin thread and sewing thread in the material. It is just leaving holes in
Needs a new needle right way around, most likely. And check the threading on both bobbin and top of the machine. It makes a big difference which way the bobbin turns in the bobbin case.
Jan 14, 2014 | Brother CS-8150 Computerized Sewing...
Needle thread wrapping around bobbin case.
Hello Crystal, I also have had problems in the past with drop-in bobbins . I had to experiment with different model bobbins . The cause I found was due to the bobbin was not tall enough in the drop-in bobbin case. When sewing , the bobbin would rock in the bobbin case and the top thread would get caught on the bobbin instead of going over the top of the bobbin, causing the rats nest that you described. I would recommend finding a taller bobbin to fit in the bobbin case. There are about five different bobbins that will fit in there, but only one that will work properly. Knowing the exact model number of your machine would be a great help to finding the correct bobbin.
Oct 08, 2012 | Kenmore Drop-In Bobbin 16231 Mechanical...
Thread on sewing machine won't pick up bobbin thread
the bobbin case does not move, just the bobbin.. if the machine is still under warrenty, I would take it back & get another sewing machine,, and probably not from them
Feb 26, 2012 | Sewing Machines
Bobbin thread tangles
when this happens have you check to see if the thread has come off the thread take up lever?
Feb 09, 2012 | Brother CE5000 Computerized Sewing Machine
Needle cannot pick up bobbin thread
Remove the needle plate and watch for the hook to come around. You want to see were the hook meets the needle. it should intersect just a bove the eye. I posted a tip on checking your sewing machine timing, check it out.
Jun 02, 2010 | Kenmore 11206 / 11306 / 11506 / 11606
Brother computerized c s6000i will not pic up bobbin thread
Have you got the bobbin in the correct way around, also have you put the needle in correct with the groove in the front of you.Are you using the correct bobbins,if yes to all these your machine has thrown it timing out in the bobbin.and needs to be looked at.
Jan 16, 2009 | Brother CS6000i Computerized Sewing...
Ssewing machine consew model 99 - thread in bobbin too loose I tighten screw as far as it can go - did not help also need to verify how to thread machine - this machine was given to me with the wrong...
Dear Sir / Madam,
You will need to remove the screw and the tension plate as there is a lint build up behind the spring.
If there is no lint then just gently bend the spring so it fits a little tighter on to the bobbin case.
Kindest Regards,
Richard.
Jul 17, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
186 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
