Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
My computer will not recognize the external harddrive so I can't access it
    Brigadier General:
  • 10,406 Answers
Connect it to a different computer. If it is not recognized, then it has a problem.
If it is recognized, then your computer has a problem recognizing it.
Posted on Apr 10, 2011
abdiasdad74
SOURCE: power is present, usb is
I just had the same problem with my simpletech 500GB. Was working fine and then all of a sudden it wouldn't show up. I was trippin out thinking I might lose everything. After reading up and looking for answers nothing worked no where. So I prayed and asked God to help me figure this out because I had put all of our family pictures in the hard drive and would lose them all if it no longer worked or I would have to re format. Long story short, a few minutes after praying to the Lord Jesus, I got a thought in my head to follow the instructions on the box about installing it. Unplugged everything and then proceeded with the 1,2,3. Plugged in the usb to the hard drive, plugged it to the computer and then I plugged the power box in and low and behold the external hard drive showed up as when I first did it a few days ago. Thank you Jesus for the simple answer on the simpletech. I hope this is helpful to someone out there who is pulling there hair out like I was for a few hours. God Bless all and may the Love of Jesus impact and save your life. HE'S COMING SOON! Be ready
Posted on Apr 24, 2009
JongCur
  • 88 Answers
SOURCE: dropped my external harddrive
Here are some suggestions that might work in a knocked up drive: First,put your drive in a freezer for a day. Place the drive in a sealed bag and get as much air out or vacuum seal if need be. After freezing, quickly insert the drive into your computer. This seems to temporarily reset the heads in the hard drive to allow you to recover and copy some of your important files for a short period. Second, take it to a data recovery service center. They will retrieve the data for you but I would like to warn this will be a bit expensive.
Posted on Apr 23, 2008
  • 3 Answers
SOURCE: acomdata external harddrive is not recognize on vista
I had a similar issue with windows 2008 and windows 7. the drive lost all its info and had to be reinitialized under both of those O.S.'s..
You can try that as long as it doesn't have any data you need.. Once you do that the drive will work and you can start using it. The file system under vista and above is slightly different than xp.
Posted on Apr 21, 2009
greg_margo
  • 1959 Answers
SOURCE: Maxtor Basics 320 GB external harddrive cant be recognized
There's a good chance the shop you bought the drive from didn't have SP3 installed. For some reason, SP3 has an issue with USB peripheral devices. Windows has created a patch to rectify the problem. Click on the link below and install the "Fixit" patch to enable your PC to recognize your HD. Best of luck.
Greg
http://support.microsoft.com/kb/925196#fixit4me
Posted on Jun 18, 2009
  • 4 Answers
SOURCE: Maddog External Harddrive Enclosure not recognized by computer
I realize the above questions are almost a year old but someone may try to research this at a later time so I thought I'd throw in my two cents.I have the Maddog Multimedia USB2.0/eSATA external harddrive enclosure which I connected to my computer last night but could only get it to appear as a "USB device" to my computer (in control Panel-System-Device Manager). It would not appear under Computer management so I could not force a drive letter on it and it would not appear in Windows Explorer. I removed the Seagate 1TB drive from the enclosure and connected it to my computer without an enclosure using an IDE/SATA interface I bought for another purpose. The drive worked fine. Today I took another look at the situation - I was going to try another drive in the MadDog enclosure to see if that worked but instead decided to reinstall the Seagate 1TB into the enclosure and try again. Same result until...I started reading through the comments above which forced me to look closer at the back of the device. That's when I remembered the device has a physical switch in the back for eSATA vs USB. I hadn't used this device in many months and my eSATA card has never worked on external drives so I forgot about it. sure enough I powered down the drive, flipped the switch to USB an powered up again. Problem solved. I am not new to this stuff but even experienced users can make a silly mistake. I only hope your issues are as easily solved.
Posted on Apr 29, 2010
My computer cannot detect my external hard disk... when i insert my usb cable to connect to my pc my hd does blink..but when i open the explorer there is no sign of my hd is detect..
Hi..
Is it a new harddrive in a external case..if so i have the same prblems and i have to remove the harddrive and insert it into my computer and format it 1st...then place it back into my external case...
If you have used it before,then the best thing to do is try it on an other computer,if that doesn,t recognize then try a different usb cable,if still no go...then the harddrive might be either virused up...then you will have to put it in your computer to virus scan.or your harddrive may be faulty...
Or the last thing...if it is a new external google your motherboard because if it is a old computer your trying to use it on..it may not regonize the harddrive if the capacity is to large..
Hope this helps..if so please take the time to rate it,and if i can be anymore help.
Regards
Apr 02, 2011 | Computers & Internet
My sata external usb western digital 320 gb drive only shows up as an unknown USB device. Is there any way to get my computer to recognize it. I have a laptop using windows xp. Ive tried unplugging...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jun 25, 2010 | Western Digital 320GB MyBook External USB...
Why won't my computer recognize my removable device
then check.
May 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
External hard drive is not being recognized by any computer
then check.
Thanks for using FixYa.
Apr 27, 2010 | Western Digital Passport 320GB External...
Why can't I access anything that was copied onto my Toshiba 500G external harddrive. The computer doesn't recognize the program that made any of it, even though it's the same computer.
It is very possible the voltage on your computer's USB port is not handling the load. I would buy a "powered" USB 2.0 hub, plug it into your computer's usb port and plug the harddrive into the powered hub.
Apr 18, 2010 | Toshiba 120GB USB 2.0 Portable External...
Locked out, boot password
I recently had a similar problem. I could no longer access my external hard drive and was unable to take admin permission of the drive. I wanted to get my files off the drive before I formatted it, especially five years worth of photographs. The solution was simple. I downloaded and burned Ubuntu (Linux) onto a bootable cd and ran Linux on my computer. Linux doesnt recognize Windows Admin privalges. I was easily able to access my external harddrive and copy my files onto my desktop. I restarted my computer with Windows and re-formatted my hardrive. The last step was simply to cut and paste my files back into my external drive. Everything works perfectly after I formatted the drive and I was able to keep my files.
Jan 26, 2010 | Panasonic ToughBook 52 Notebook
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
Unrecognizable USB External Harddrive
dear jpaws check your computers device manager. ithink you need drivers please install a driver.
Feb 25, 2008 | Computers & Internet
Acomdata external harddrive gone blank.
dont copy any data from or too the disk then use recover software. like Recover My Files, and if you copy any data to that disk it will damage the data you want.
Jan 06, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
1,189 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
