My pav3300aww rev 12 will not spin or pump water out
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Posted on Apr 10, 2011
01 Audi tt quattro starts to overheat while idling but coils down after driving at higher speed, is it a thermostat or the fast relay switch
overheats at idle only are typically the fan system. Cars use the fan to pull air across the radiator for cooling. Any speed over 10 mph there is more than enough natural wind to do this without a fan. If the problem immediately goes away when you start moving, it is probably a malfunction or issue with the fan. I have on more than 1 occaision had a customer tell me they had the fan replaced and car was still overheating, and it ended up thje fan was spinning backwards or not turning on because of a fuse or relay issue.
If it doesnt cool down fully once speed is above 20mph for more than 30 seconds, there may be other issues like plugged radiator or weak water pump impellars. water pump is a fan that moves water instead of the air. if the blades wear, they still kinda work, but at idle they work poorly because the broken blades only move a little air at low speed, rev the engine up, they spin faster and work better. If the fan is functioning OK (Turns on and off by itself) and car still runs warmer at idle than at rev, water pump may be worth investigation.
May 08, 2015 | Audi Cars & Trucks
Classixx 1200 wfl2463gb/12
this can be one of two thing the pcb (circuit board) or could just be worn brushes that stops it
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 30, 2013 | Washing Machines
Why wont it spin and drain
if its a front load washer check the drain pump,if it cant drain the water it will not go into spin cycle,depending on make/model the pump can either be accessed from the lower front or rear areas under drum inside the machine
Feb 19, 2012 | Washing Machines
03 mk4 vw golf 1.6 petrol 143000kms new tbelt and water pump and thermostat fitted 12 months ago. Fans running full time when engine is running. Overheats when engine is running at low speed ok at high...
Water pump is bad because overheats when engine is running at low speed, and good at high rev. The water pump impeller can not push the coolant with the required pressure.
Apr 19, 2011 | Volkswagen Golf Cars & Trucks
Water does not empty all out on normal loads have to run quick rinse and spin to try and empty.
Check the filter, located behind the access door on the front lower left of the washer. If clear, replace pump motor. (did you know that you can turn the washer on and NOT select a cycle, but just touch the spin speed button, then start to get a 12 minute or so spin and pump only cycle, with no water fill?)
Feb 01, 2011 | LG WM-2277HW Front Load Washer
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Displaying error number F02
Hi there
OK i give you what you need to read so you know what it is. Hope this gets you in the right direction.
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Kenmore Elite 45986 Front Load Washer
Engine coolant not circulating
no thermostat sound like you have a ubstruction somewhere make sure the oil is not milky if it is you need to replace you impellar seal behinde the blade make sure your radiator grates are clean with a preasure washer
Jun 22, 2009 | 2003 kawasaki KX 125
Hoover Zodiac 12 that won't spin.
possible filter blockage, or the pump has failed/seized, machine CANNOT spin while it CONTAINS WATER, the door interlock will not open for the same reason,WATER in drum.
manually drain excess water into a bowl now
1 clean filter, 2 check pump for objects that prevent impeller working may still need pump if seized
Jun 12, 2009 | Washing Machines
My maytag washer model PAV3300AWW will not spin
Check the belt at the bottom of the machine. You can also remove the back panel. Either the belt has become stretched or broken and needs to be replaced
May 22, 2009 | Washing Machines
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
