Question about Samsung HT-Z320T Theater System
Hi, I have a problem with my Sansung HT-Z320T Home Theater. When I turn on, sounds like 20 seconds and gives me the message (FRANCHK) and then turns itself off.
techman
  • 3130 Answers
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
Posted on Oct 15, 2007
djnick989
  • 1067 Answers
SOURCE: fan check issue
ya need to get fan fixed is safe mode cuse they genrate alot of heat have to have it in well vented area on a nice power strip like monster
Posted on Jan 09, 2008
SOURCE: Durabrand Home Theater Manual
Go to www.800customersupport.com You should be able to find a link to your manual there.
Posted on May 15, 2008
ginko
  • 19396 Answers
SOURCE: Protection Problem on Samsung Digital Home Theater
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
How to fix my samsung ht -z320t?
Please let us know the reason that the player does not work or make direct contact avsystemparts.com
Oct 06, 2013 | Audio Players & Recorders
It cannot stay on .
Please contact with avsystemparts.com and describe more about troubleshooting. avsystemparts.com
Oct 06, 2013 | Samsung HT-Z320T Theater System
Samsung HT-THX25 sound problem
I had the same problem. How i fixed ? I unplugged HT and I kept pressed the power button from DVD for a few seconds. Repeat it, put it in socket and turn it on. It happens from condensation or voltage variations.
Sep 19, 2012 | Audio Players & Recorders
Samsung home theater model ht z320t xaa wont turn on and light is blinking?
make sure none of the wires on the back of the reciever or speakers are touching one another. I have a sony surround system and was doing the same thing, come to find out my postive and negative wires where touching causing the system not turn on.
Aug 23, 2012 | Audio Players & Recorders
Back ground sound is so high you can't hear the dialog ,meaning having \r\nto turning ssound up way too high
This can mean only one thing. Your center channel is not working. Either you have a damaged center speaker of you have a damaged center amplifier. You can confirm by first turning down the volume to normal levels and disconnect any one of the speakers and connect it to the center channel output. If you can hear the dialog the center speaker is defective.
Another way to hear the dialog is to change the surround setting to PL II music or just disable surround and chose Stereo mode.
Mar 28, 2011 | Samsung HT-Z320T Theater System
I keep getting the 'rear check' message on the tower panel display and all cables are connected what could this be this is on my new HT-TXQ120 DVD HOME THEATER SYSTEM
With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
Note: You can release the REMAIN button when the POWER LED blinks blue.
With the wireless module turned on, use a ball point pen to press the RESET button on the back of the wireless module. The POWER LED in the front of the home theater blinks two times.
Turn on the home theater. The LINK LED on the front of the SWA-3000 changes from red to blue, indicating the wireless module has connected to the home theater.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 29, 2009 | Samsung HT-TXQ120 Home Theater System...
Rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
Nov 19, 2008 | Samsung HT-TXQ120 Home Theater System...
Samsung HT-Z320T Theater System Logo
156 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
