Question about Navman GPS
Hi I have a MY55T Navman I connected to PC to charge battery and the screen came up with the PC / USB GPS connection I havent been able to get out of this screen since when you turn the unit on it defaults to this screen after sort of booting up it looks to try and start up then defaults to this screen is there a simple fix for this
  • siboias Apr 10, 2011
    I have done all those potential solutions however removing the battery isnt that straight forward, there isnt any reset button as mentioned and isnt refered to in the manual
    Genius:
  • 1,157 Answers
Hi siboias,
Just another thought about your concern, have you tried resetting the unit and restore it from factory defaults? You can restore the unit back to the factory defaults by going to the "settings" screen and press on the "restore factory defaults". You may also try the following steps for additional troubleshooting.
1. Take the SD CARD out, reset and turn on the Navman.
2. When the Navman loads, push in the SD CARD.
3. Now go to the "setting" screen and press on the "restore factory defaults".
Hope it helps.
Thank you for using FixYa.
Posted on Apr 10, 2011
  • 12,061 Answers
Hi, well hopefully all your unit may need is, to turn Off & On, if that doesn't work, then try a hard reset, have a look for a little hole, and inside the hole should be a button, the reset button, now press and hold that for 5 seconds or so, and let go, now try to restart, hopefully it should be OK.
The only other way is to remove the battery this too will reset it.
This message happens to allow you to chose what function you want.
Please obtain a manual, inside the manual it will show you how to reset, in case there is no hole etc, some models are different.
you support access below
www.navman.com.au/car-gps-devices/.../MY55T/Overview/
Navman MY75T was working fine for several weeks, but today it won't start up. Tried to reset several times, but no luck. It gets to the Safety Agreement screen, and when I press the "Accept"...
1. Connect Navman GPS to PC viamini-usb cable. 2. Go to 'Start' 3. Go to 'My Computer' 4. Open the 'Navman' folder 5. Open the 'Database' folder 6. Delete the following file only- 'dababase.db' 7. Close the folders 8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
Nov 02, 2010 | GPS
I havent used my navman for a while and now it will not charge up from the cigaret lighter connection although the connector does light up
Often the ni-Cad or LiFe cells get so flat they need a special charger with high current. They just will NOT charge up any other method, it may be best if you replace the battery, you need to open up the unit to do that. There is a "Pack" inside. You can get batteries fro,m manufacturer or eBay Craig's list Google etc. However now you would also have to reinstall the software again if not lucky. There are tutorial how to do what you want on the Navman web site
Mar 13, 2010 | Navman F20 GPS Receiver
Hi I am using Navman S30 car navigator. It has been giving me problems now. Every time I connect its charger, it turns on and gets stuck on the usb connection screen. I have changed its charger but I am...
Open your usb cable with a sharp knife; you'll find four different coloured cables inside: leave the red and black cable intact; cut the other two. Close your cable with some tape.
Your navman won't go into usb mode again, but it will charge your device
Dec 23, 2009 | Navman S30 Car GPS Receiver
Can I connect the wires from a car charger to the connections under the unit ?
An alternative is to use a navman P1 "hotshoe" This allows charging to be carried out through the bottom strip connector.
Available from Magicgadgetz at a cost of £20
Oct 22, 2008 | Navman F20 GPS Receiver
When I try to update my navman It says I'm not connected and I am?
Hi - yes it probably is a driver thing. Navman's install software apparently doesn't install the Windows driver - you have to do it manually.
I just found this how-to page on Navman's website, and it worked for me:
http://www.support.navman-europe.com/FAQs/Drivers/F-Series/
Good luck
Peter
Aug 12, 2008 | Navman F20 GPS Receiver
Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
May 11, 2008 | Navman iCN 520 GPS Receiver
Battery Charging Navman S90i
The problem is that most of the chargers have the output of 5V/0.5A. The charger for NAVMAN (C30 in my case) has 5V/1A. And that is causing the trouble. The GPS is undercharged and is switching off itself. Buy one which specify the output power: 5V/1A. Hope I solved your problem
Feb 04, 2008 | Navman F20 GPS Receiver
Can NavMan 520 charge via USB?
that is probably due to the battery being totaly dead,
try using a mobile phone charger (nokia),
usb is for data transfers.
Jan 04, 2008 | Navman iCN 520 GPS Receiver
Not responding......help
Low or flat battery. Connect to mains charger and fully charge.
May 27, 2007 | Navman PiN 570 GPS Receiver
GPS Logo
181 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
