During shutdown and startup I get a message telling me an application is not being displayed because winscard.dll cannot be found, and advising me that re-installing the application may fix the problem. I do not know exactly what it is referring to, but I have recently lost the ability to burn DVDs that will play in my DVD player. I suspect there is a connection. I am frustrated.
    Problem Solver:
  • 25 Answers
The easiest way to solve this problem is to restore your pc back before the problem started. (Go to Start | All Programs | Accessories | System Tools | System Restore to bring up the screen in Figure 1. Click the System Restore Settings link on the left side of the screen).
2nd. reboot pc with your windows cd, boot into recovery console, at the command prompt type chkdsk /r
Posted on Aug 06, 2008
I have this error message that pops up when I start my computer "There was a problem starting c:\users\focusconstruction\appdata\roaming\qufvc.dll the specified module could not be found
Go to Search and type MSConfig. At the startup tab uncheck anything relating back to that application. Not to worry if you are not sure. You can uncheck till you find it, or all.
Feb 06, 2013 | Dell Computers & Internet
Tip
Xpcom_core.dll file error
The xpcom_core.dll is included with Mozilla (Firefox) enables the Mozilla program to be an actual framework. The xpcom_core.dll module provides a development environment that includes file abstraction, component management, memory management and object message passing for software developers.This DLL allows for the access of components that can be contacted from a web browser or scripted from any application from Mozilla.
If you're having an issue with your xpcom_core.dll file, the exact message displayed will vary. A few examples are listed below:
  • "The dynamic link library xpcom_core.dll could not be found in the specified path"
  • "Missing component xpcom_core.dll"
  • "This application has failed to start because xpcom_core.dll was not found"
  • "xpcom_core.dll is not loaded"
This dll file can be downloaded by clicking here
on Apr 25, 2010 | Microsoft Windows XP Professional SP2
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
What does this message on my pc mean?Error in c: windows \ system32 \ spool\ drivers \ w32x86\3\dlcd time. Dll missing entry: run dll entry
Time.dll was probably installed along with some software that came with the HP printer.
As time.dll is shared with other applications HP may have removed it during the uninstalling process and either some oter application is looking for it or a command to open it has been left behind.
As you say the Dell printer is working well so have alook in your StartUp folder (Documents and Settings/User/Start Menu/Programs?StartUp) and delete any reference to that file of HP Printer.
Also look under StartUp by Clicking Start > Run and typing msconfig and uncheck andy reference to HP or the file.
If it turns out another pallication needs the file then reinstall that application.
Jan 29, 2012 | Dell Computers & Internet
I recieve this message at startup. AirGCFG.exe-Entry point not found. Aps Searchinterface could not be located in the Dynamic Link library wlanapi.dll
Try unloading some of the applications that load at start-up. You can do this by running (win+r) msconfig, and then select startup.
You'll see a list of startup items.
Remember, you should keep only the ones that you need like AV software, driver related.
Feb 01, 2011 | Computers & Internet
When i start my computer i get two error loading messages: c:\windows\kep2at.dll and c;\windowsewaxoxiw.dll and they both say "the specidied module could not be found" i looked in regedit and didn't find...
go to start, run, type in msconfig and press enter. msconfig is the command to run an application to control startup items. Go to the startup tab at the top of this window, and uncheck any unnecessary items so they won't startup at reboot. If you are unsure what a process is, just google the name and it should give you details as to what application it belongs to, and you can make judgement if you need it or not. I would uncheck anything I wouldn't recognize.
Sep 04, 2010 | Computers & Internet
This is message error appear during I install canofile : RNBOVDD.DLL An installation virtual device drive failed initialization choose.'close' to terminate the application
The RNBOVDD.DLL is a Device Driver used for DOS and Windows 16-bit...so needs to be removed hence follow the steps listed below.
Run the Registry Editor by typing in regedit in the run search bar and Select the HKEY_LOCAL_MACHINE window.
Double click on SYSTEM. Double click on CURRENT CONTROL SET. Double click on
CONTROL. Select VIRTUAL DEVICE DRIVERS.
Double click on VDD:.......RNBOVDD.DLL line on the right side of the window.
Delete RNBOVDD.DLL. Confirm by pressing OK.
Shutdown and restart Windows.
ALL THE BEST...................
Feb 21, 2010 | Canon Canofile 2.01 Full Version for PC
AegisE5.dll was not found.
hi,
http://www.fix-all-dll-errors.com/aegise5.dll/
u can go to this site...
as I registered few dll's from this site...worked in my case :)
Jan 03, 2009 | Televison & Video
Error message on startup
PRISMSVR.EXE is a process related to the PRISM Wireless lan hardware.. Reinstallig the lan cards software should solve it )though you might have to configure it all over again - take note of your current settings).
As for SSLEYA32.dll, if it was the spyware version of this file, it was problably deleted by your antivirus, but the registry call to startup is still there. In MSCONFIG you should be able to take care of that.
On the other hand, this file might be related to OpenSSL Toolkit from The OpenSSL Project. If you are not using this, then be glad it disappeared.
Oct 24, 2008 | Dell Dimension 4600 PC Desktop
M3plugin.dll
When I start My PC the RUNDLL error occursError loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.  Solve my this problem as soon as possible.
Aug 26, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
