Question about David White white 45 8926 AL8 26 Automatic Level
Need user manual for David White AL8-26 level
I need user manuel for this model
Hi David,
have a look here they offer free manuals for flat panel TV's: http://www.mbtvelectronics.co.uk/home-shop-style-1/lcd-led-and-plasma-television-user-manuals-microwave-user-manuals
Jan 26, 2016 | Televison & Video
How to fix crooked cross hairs on David White transit level
don't believe that is a consumer fix . has to be sent in to them
Apr 27, 2015 | David White 44 8834 1 22x Level Transit...
Where can I download or how can I get the manual for this total station?
David White has gone trough a lot of changes. A number of years ago it was bought by CST (Chicago Steel Tape). CST was bought by Stanley tools around 2007ish. Stanley sold CST to Bosch in 2010ish. Bosch has kept CST but shut down David White, as well as all parts.
If you call the old CST office in Chicago 815.432.9200 • 800.435.1859 they might be willing to share an old manual.
Feb 01, 2014 | David White DTS05 Electronic Total Station
I can't get my david white matrix 54 to shoot a beam in any direction. The lights on top just flasah.
This sounds like it is out of level. Self leveling lasers are only self leveling to a point. If they go past that they can not compensate and generally flash to let you know.
Jun 14, 2011 | David White 48 MATRX54 Matrix54 Multi...
How to adjust a David White transit level
I just assisted a friend "re-calibrate" his D.W. L6-20 Level Transit. Follow the following steps.
1. Set up the tripod & transit in the garage. Get the platform with the protractor, close to level.
2. Position the telescope at "0". The telescope should be over 2 of the adjusting screws.
3. Adjust the screws to get the top bubble close to level. Adjust with a screwdriver the spring loaded screw to get the bubble closer to center.
4. Rotate the scope 180 degrees. Note the difference in the bubble position. Split the difference from the first bubble location by adjusting the same top screw.
5. Rotate back to 0. Adjust the same top screw to split the difference in bubble position.
6. Rotate back to 180 degrees. The bubble should be off by the same amount. Adjust the 2 bottom screw to place the level in the center.
7. Rotate back to 0. The bubble should not move.
8. Rotate to 90 degrees and adjust the 2 bottom screws to place the bubble in the center.
9. Rotate to 270 degrees. The bubble should be centered.
10. From this point on, all you need to do is place the level on the tripod and position it over your reference point with a plumb bob. Adjust the bottom 2 screws at 0 and again at 90. The level is set to use.
Sep 05, 2009 | David White 44 8834 1 22x Level Transit...
David White white 45 8926 AL8 26 Automatic Level Logo
172 people viewed this question
Top David Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a David Measuring Tool and Sensor Expert? Answer questions, earn points and help others
