Question about Ovens
I have a kenmore mark 1 oven in my apartment and the oven temperature says 1-9 instead of going in degrees such as 100, 350 etc. I am wondering which number stands for which heat?
    President:
  • 1,082 Answers
This Conversion table is from the old Gas Mark scale
I'm thinking it should be right or at least pretty close.
You could also get a cheap ($5-7) oven thermometer from local grocery store.
Put it inside oven to check actual temp achieved.
Gas mark Fahrenheit Celsius
1⁄4 225° 107°
1⁄2 250° 121°
1 275° 135°
2 300° 149°
3 325° 163°
4 350° 177°
5 375° 191°
6 400° 204°
7 425° 218°
8 450° 232°
9 475° 246°
Posted on Apr 10, 2011
Need manual for self cleaning, please?
Hello Mary;
You can get a user manual at the following website.
Locate your oven model number. It is located on a label either on the face of the oven when you open the door or on the side of the door. Put he model number into the website and you will get diagrams, component part numbers and manuals.
http://www.searspastsdirect.com/
I suspect the user manual is not going to help you. Tell me the model number and what is going on.
Manufacturers offer the self cleaning feature on ovens because customers like this feature and the ovens sell. Yet, the manufacturers engineers have not been able to provide a design that will protect all of the components from self cleaning temperature of 900-1,000 degree F.
When you go into the self cleaning model, the door will lock when you reach 500-550 Degree F. The oven temperature will raise to 900-1,000 degrees F. The oven door will not open until the oven temperature drops to 500 degree F after the self cleaning cycle is completed.
Now, You have a high temperature limit switch in your oven. If this switch fails, you will loose power to your control board and you will not be able to open the oven door.
If you have never used your self cleaning feature, the high temperature limit switch may have failed.
Do to the problems involved with the self cleaning feature, knocking out the control board from heat, additional heating element failure, and other components; It is in my professional recommendation as well as my fellow technicians not to use the self cleaning feature. If you do, do not run it for more than 1 hour instead for the manual 4 hours.
Mar 14, 2016 | Ovens
I just had my igniter replaced on my Kenmore oven, now the temperature foal won't go above 260°, the oven is heating very hot, but the dial won't go higher. Can this be reset?
Your oven is probably in Celcius mode - try holding bake (or broil) for 3 seconds (after cancel) to toggle. If not, the owners manual will tell you how to switch back to degrees F.
Sep 16, 2015 | Kenmore Ovens
When baking the oven doesn't bake evenly and always bakes quicker than the time on recipes. Items burn and the middle is raw. Can the oven be recalculated to work better?? John
Electric ovens are always different from gas ovens. You have to set the temperature on average 10-15 degrees lower and watch out 15 minutes earlier if you are baking cakes, 5 mins for cookies etc. Always bake in the centre of the oven. use a metal bowl of water in another tray which may help balance out the temperature
Jan 01, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
My Kenmore oven will only go up to 375 degrees. If I set a higher temperature, the preheat indicator won't go off, but it clicks, just doesn't make it to the higher temperature. Please help.
Sorry to read about your problem, I hope this helps you out.
you have a defective temp probe or heat control knob
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Kenmore 30169 Electric Single Oven
Kenmore Electric Double Oven Mod 9114832592992 got F2 code in middle of selfclean what do I need to fix?
Hi, i found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC)
OR....
F2 Oven temperature sensor shorted Replace oven temperature sensor
OR
F2 Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
Oct 26, 2010 | Kenmore Ovens
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
Oven doesn't go on.
Hi.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
If the part that is not heating is only one element, then you may need to replace the element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
In this case, selecting only baking or only broiling (depending on what element is faulty), the oven will work normally.
If the oven is a gas oven, then you have no element. In that case if the oven burners are working, replace the temperature sensor.
If replacing the temperature sensor does not help, then replace the oven electronic control.
Mar 04, 2010 | GE Ovens
Self-cleaning oven F2 error message
Well I found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
OR....
OR
Feb 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My oven temperature is 100 degrees hotter than it should be
It will be the sensor inside the oven compartment that is causing the problem.
A new sensor should cure the prob, certainley cheaoer than buying a new oven.
Hope my advice helps you.
Dec 15, 2009 | Kenmore Ovens
Stove won't go below 170
The lowest temperture that the oven will control is 170 degrees. You would have to place a suitable thermometer in the oven and manually control the temperature if you want a lower temperature.
May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
136 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
