Question about Sharp Audio Players & Recorders
I have a sharp 3 disc cd player that says error 306
3 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: My sharp cd player is showing error 11. door will
dismantle your cd player and set it up back and it will automatically reset itself. if does not then have a tech repair it as your aduio output is damage or the momory chip needs to be replaced.
Posted on Apr 18, 2009
  • 86 Answers
SOURCE: Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Posted on Oct 09, 2009
Microboard error code 306
The 306 Error Code is generated when any corresponding process or operation could not be completed successfully by the application.
error 306 may prevent the user from performing the required action or may the application will close unconditionally.
Technical (Deep) Description of Error Code 306:
This is a full Description of ERROR 306:
ERROR 306: MCIERR_DEVICE_NOT_INSTALLED.This error is due to .The default facility code
ERROR 306: EVENT_APPMGMT_UPGRADE_COMPLETE.This error is due to Application %1 from policy %2 successfully upgraded application %3 from policy %4..The default facility code
ERROR 306: SQL_306_severity_16.This error is due to The text ntext and image data types cannot be compared or sorted except when using IS NULL or LIKE operator..The default facility code
ERROR 306: ERROR_SECURITY_STREAM_IS_INCONSISTENT.This error is due to The security stream for the given volume is in an inconsistent state. Please run CHKDSK on the volume..The default facility code
ERROR 306: CO_E_LOOKUPACCNAMEFAILED.This error is due to The system function LookupAccountName failed .The source of the error code is an RPC subsystem.
ERROR 306: STATUS_LOGON_SERVER_CONFLICT.This error is due to The Netlogon service cannot start because another Netlogon service running in the domain conflicts with the specified role. .The default facility code
Fixing Error 306 manually is a difficult process and it is not recommend unless you are an expert in this field.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Jul 13, 2012 | MicroBoards CFD-USB-15 1 Read,15-Port USB...
Disc rejection
Try using a DVD / CD cleaner disc in the unit - this might fix the problem - I had the same format error on a Toshiba unit using Sony and VBerbatim discs - once cleaned the unit worked fine
Mar 25, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Selective playing of DVD's on Sharp DVD Recorder
Given that the machine will read disks it has written itself but not play regular discs, I suspect the lens assembly is slightly out of alignment and needs adjusting. This is not normally something you can do at home unless you have the correct test gear. It will need to go to a repair shop. One thing you can try before that is to clean the lens. Buy a quality (Scotch 3M, Philips ) cleaning disc and try it. Could be it's only a speck of dust on the lens.....
Aug 01, 2007 | NAD C541 CD Player
Car CD player won't load Cd's - Peugeot 306
Yeah, the sensor that detects the presence of the disc is knackered - probably broken off. The eject will always eject the disc. Just press the button with no disc and you will hear it try. Look at ebay for a replacement - theyre dirt cheap!
Jul 13, 2009 | 2006 Peugeot 505
Apr 18, 2009 | Sharp Audio Players & Recorders
Sharp cd-dp2400 suitable remote contols
i have a sharp cd player and the speakers hook up to the cd player and they light up but when i plug in the speakers to play they wont play what should i do
Sep 03, 2008 | Audio Players & Recorders
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Error code 6 & error code 4
Error 6 & 4 it means laser is not reading the disc and unforutunally you need to replace the pick up laser assy.
You can get it from pacparts.com,but I reccomend you to take to a proffessional tech because this is a "static sensitive" item.
Dec 08, 2007 | Clarion DX-515 CD Player
CD Player not working
Since the unit was in storage for a while dust may have settled on the lens.Try cleaning the lens.
Dec 17, 2006 | Sharp CD-XP120 CD Shelf System
ERR 308
Open and check. Could be a mechanical problem - a jammed disc, or broken drive belts.
Oct 02, 2006 | Sharp CD-BA120 Shelf System
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
