This is usually caused by either a bad door switch, a loose door switch mount, or a misaligned door.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door
switch or mount trouble can be caused by slamming the door or by
opening the door while it's cooking without hitting the Stop pad first.
There
are plastic mounts inside the microwave which hold the door switches
and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes
it's a broken tab on the switch holder, allowing the switch to rotate
just out of position. This tab
can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or
handle as you try to start it. If it works or tries to work, then it's
a door switch mount or door alignment issue.
If
you or someone you know decide to look into it, we have critical
information on safety, disassembly and door switches at our site, and
our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
SOURCE: frigidaire won't run
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: timer will run, but won't cook
SOURCE: will not run
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Please reply back if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Fan & Turntable start when door is opened.
sounds like there is a switch that is bad. you can go buy a new MW for about 200$ and in yours if there is a major problem then i would just go buy a new one but might be worth a repair man to come check it out
pleas do not poke around in the microwave as it carries a charge of 5000volts and can kill you even if not plugged in DON'T TOUCH THE WIRES WITH BRAIDS ON THE OUT SIDE if you must get inside of the unit
SOURCE: Timer counts down but turntable won't spin and fan
I had the exact same problem this week. $80.00 service call and a door microswitch ($28.00) later - It works!
It is the bottom microswitch!
