Speedometer,Trip Meter, Fuel Guage, Oil Preassure Guage,heat guage, Volt meter, all quit at the same time. Fuzes seem to be fine. Lights on dash work turn signals-ok
  • geo22252 Apr 10, 2011
    Turning lamps, headlights, brights, and brake lights all work, Is that what you refer to as the Multi-function switch? The Truck runs fine otherwise. Where is the ABS module located? I have the dash out now, also traded it out w/anouther used one, I drove from Michigan (cold weather) to Florida (Hot) ended driving it back w/no Instramentation
    1995 Ford Ranger---ABS was ok i think Reseated it---Maybe a ground? Where?
  • 1,940 Answers
If all gauges and lights quit at the same time, your Instrument Cluster is either faulty, or the fuse for your instrument cluster has blown. I would check all fuses, then remove the Instrument Cluster. Check the terminals on the back of the instrument cluster, and try reseating the Cluster to see if the problem goes away. You may have to replace the Instrument Cluster if it doesn't start working again after reseating the Cluster.
Depending on what vehicle you have, this could also be linked to a faulty Multi-Function Switch (check your turning lamps, headlights, brights, and brake lights, if any don't work, fix the problem), or a faulty ECM, faulty ABS module, etc.
Posted on Apr 10, 2011
  • Jeremy Moore
    Jeremy Moore Apr 10, 2011
    Did you have an ABS light on when the Instrument Cluster was working? If not, this is probably not the problem. I would pull the Instrument Cluster, check the terminals and solder joints. Reseat the Cluster and see if it starts working. What is the Year, Make and Model of the Truck?
  • Jeremy Moore
    The Fuse for the Instrument Cluster is inside the vehicle. It is listed as fuse 11, which is 10a, in the factory service manual. From this fuse, power is sent to the Instrument Cluster through a Red/Yellow wire. It is possible that your Instrument Cluster Gauge Amplifier has gone bad. It is located on the backside of the Instrument Cluster. The instrument cluster gauge amplifier is a printed circuit board assembly located at the end on the rear of the instrument cluster. Carefully depress the retaining clip with thumb on the component side of the board, and pull the board assembly out of the instrument cluster back plate. To check the Cluster Ground: Turn ignition switch to OFF position. Partially remove instrument cluster as outlined. Using an ohmmeter connected to a known good ground, connect second lead to Circuit 57 (BK) at Connector C1, Pins 8 and 10. Measure resistance. If the resistance is not 5 ohms or less, SERVICE Circuit 57 (BK) for open. If the resistance is 5 ohms or less, turn ignition switch to RUN position. Using a test lamp check CIrcuit 640 (R/Y) at Connector C1. If the test lamp illuminates, REPLACE instrument cluster printed circuit. RESTORE vehicle. RETEST system. If not, SERVICE Circuit 640 (R/Y) for open.
Trip meter quit working after reseting
replace guage your speedometer is on its way to failing too your lucky its only the trip right now
Nov 09, 2013 | 1994 Honda Accord
Broken trip gauge on 1999 chevy blazer
There may be a blown fuse causing the trip meter failure and quite possibly the gauge reading failure. since you didnt say if they went out at the same same it is hard to say but checking the fuses is a likely culprit for the first problem. it is entirely possibly that you fuel guage just stopped sending the signal up to your guage. this is known to happen usually only remedied by replacing the fuel pump as it is part of the wiring on the pump itself. that is unless that fuse is the reason it is bad. the other thing is the possibility of a broken/shorted wire that provides the signal from the pump to the guage good luck
Feb 12, 2013 | 1999 Chevrolet Blazer
Lights or fuse for my speed odemeter guage and heater/air conditioning system
These lights for the dash are controlled by a rheostat instrument control dimmer switch next to the main light switch for the headlights, it is either turned off (have seen this dozens of times) or it is defective. Below is a picture of the switch assembly I speak of. The thumb wheel next to the knob is the dimmer control.
Feb 13, 2012 | 2000 GMC Yukon XL
I just bought a 1988 chevy k/1500 4-wd truck. the temp guae volt meter oil pressure guage in the cluster all worked the rest did not. I found a replacement at a local scrap yard. now the temp volt and oil...
first we will start will the fuel gauge most likely you are correct chevys and 1995 and older jeep wranglers had this problem the sending units failed very commonly. you could have possibly gotton another bad cluster but most likely the speed sensor has worn out. it has a plastic gear being turned by a metal gear and is located near the tail of the transmission. hope this helps
Jan 30, 2011 | 1988 Chevrolet K1500
My brother has leant me his 1993 Ford fairmont EB11. A red light is flashing intermiitanly it looks like a fan in some kind of cylinder. Could someone tell me what it is?
  • Full instrumentation pack (four ancillary guages plus tachometer) - with volt meter & oil pressure guage.
  • Speedometer, odometer, tripmeter, fuel guage & water temperature guage standard in addition to the above.
  • WARNING LIGHTS: High beam, rear window demist on, turn signal / hazard light, alternator fail, lights on, park-brake on, washer fluid low, radiator coolant low, cruise control indicator and low oil pressure.
  • AUDIBLE WARNING CHIMES: low fuel, lights on, low alternator charge, low oil pressure, high coolant temperature and brake failure.
  • Trip Computer standard featuring fuel consumption figures, distance to empty, average speed & time display.
I found this site, no mention of the fan in a cylinder, but I'll let you figure it out. Hope this helps.
http://www.trueblueford.com/ed_pages/EDfalcon_fairmont.html
May 31, 2010 | 1983 Ford Fairmont
GAS GUAGE AND OIL PRESSURE GUAGE DONT WORK.
look and see if you blew a fuse if not you'll have to remove the cluster and make sure it is plugged in if all this is right the cluster is possibly bad it happens.
Aug 25, 2009 | 2000 Pontiac Bonneville
Odometer / trip meter not working speedometer does work help
The dash cluster is bad. It's a mechanically driven part in the dash & it's easy to just replace the guage assembly.
Jun 27, 2009 | Dodge Dynasty Cars & Trucks
Speedometer and Tachometer not working
check the vehicle speed sensor located on the transmission housing.
Apr 11, 2009 | 1992 Oldsmobile Custom Cruiser
Instrument panel guages don't read accuratly
I have a chevy cav 03 and my problem is just in the gas guage and temp guage now i cant seem to figure out how to fix it but for a quick fix i have jut been pulling out the instrument panel fuse and putting it back in it seems to fix t
Feb 26, 2009 | 2000 Chevrolet Cavalier
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
