Question about Black & Decker HS800 Flavor Scenter 4-Cup Rice Cooker
Where to put the water when making rice
I have never used this and there are no instruction. Where do I put the water and how long for rice.
    Problem Solver:
  • 4 Answers
Try this link -- the one above didn't work for me http://www.useandcaremanuals.com/pdf/HS80035.pdf
Posted on Jan 17, 2010
  • 718 Answers
Measuring rice cup. it reads at the top 160g. and instructions say 150g. Two make 4 to 5 cups of cooked rice do I fill the cup to the top, two times?
Its the most easiest to make with any measuring utensil..
Find anything like a coffee cup .. If you put one coffee cupp full of rice put two coffee cups of water place a lid on set stove. on med to highish and wait til u no longer hear water bubbling inside the pot or if your lid is clear no longer see water Never stir until u know for sure its tender and if its done on top part its done on bottom part...
1rice. 2water
2 rice. 4 water get it.
Apr 11, 2015 | Kitchen Appliances - Others
I just bought a rice cooker at a garage sale. It had no instruction manual
To make rice, remove the trivet if you have one as this is only for steaming food.
Wash rice to get rid of excess starch and put in pan. Then add the same amount of water as rice (2 cups water to 2 cups rice etc.) then shut lid and switch on and leave it.
Once it has switched off do not open the lid for a further 20 minutes (the machine will keep the rice warm do not worry) Stir rice and serve. Most rice cookers will keep the rice warm for a couple of hours.
If you find the rice is a bit dry then add a little bit more water, the amount of water really depends on the quality of rice used.
Sep 20, 2014 | Krups Kitchen Appliances - Others
Rice cooker manual
Not sure which type of Tefal rice cooker you have received.
You may want to go to the Tefal website and pick the manual for the one that could be your model.
http://www.tefal.com.au/Consumer+service/Use+Instructions/Download+User+Instructions.htm?DdlFamily=%7B0A5A8D23-12DD-457A-98D3-F880930BB33B%7D
Though there is not much to it if you are cooking rice. Take the pot out and wash it as any metal utensil. Put as many cups of rice you want to cook in a separate bowl using the measure that would have come with it. Otherwise take a 150ml measure. Wash it the rice thoroughly with water and drop it into the pot. Fill water to the level of number of the cups you have put in. Wipe the pot dry from outside and place in the cooker jacket. Put lid on. Turn the power on and press the Cook button. Once rice is cooked it will switch to keep warm and leave it there for about 5 minutes before you use the cooked rice.
Aug 21, 2014 | Tefal Kitchen Appliances - Others
Look for national rice-o-mat model SR-3F
I have this rice cooker (it's very small) and the original instruction booklet:
HOW TO USE
1. Measure rice with measuring cup. One cup of uncooked rice will make about 3 cups of cooked rice.
2. Wash rice 4 or 5 times with fresh water in another bowl. Wash until water becomes relatively clear.
3. Put rice and water into the pan. As a rule, add water to uncooked rice in the following standard proportions.
2 cups rice to 2 - 2 1/2 cups water
3 cups rice to 3 - 3 1/2 cups water
4. Place the pan directly on the internal heating plate, and make sure that the pan is properly located on the heating plate by turning it slightly to the right and left as shown. (see CAUTION) . Before placing the pan in the cooker, wipe off water and moisture from the outside (especially the bottom) of the pan.
5.Put on the lid.
6.Insert the plug end into a wall outlet.
7.Push the switch button to the "ON" position. Make sure the pilot lamp is on. When the rice is done, the switch will turn off automatically, the lamp will go out and a click will be heard.
8.Even after the switch is off, leave the lid on for at least 15 minutes more. During that period, the rice will be properly steamed to a fluffy character by the retained heat.
SOME HELPFUL HINTS
• Always tasty rice
With your National Automatic RICE•O•MAT you can have uniformly cooked rice ... you can even cook rice to your personal taste and preference. Taste and degree cooked depend upon the quality of the rice and the length of time it is soaked before being placed into the cooker. Add more water than specified for softer, more fluffy rice; less water for firmer rice.
• Rice may bubble over ...
If you use too much water or if the cooker is tilted, rice may bubble over. To prevent rice from bubbling over, add water using the cup included (refer to How to use, Item 3.)
HOW TO CLEAN THE COOKER
Do not immerse the body into water or spray water onto it. Wipe it clean with a wet dishcloth soaked in hot water.
Nov 21, 2012 | Kitchen Appliances - Others
I have just purchased a Russel Hobbs steamer (model 14453) A rice bowl is included but the instruction booklet doesn't tell me how to cook rice! Advice please. CG
Hahahaha!
Ask Asians to guide you to cook rice!
Every time you put rice and add water, level the rice under the water, measure the water by using ur FiNGER!
Use ur mid finger, make sure the first line in ur mid finger is the LEVEL of water.
Dip ur mid finger untill it touches the TOP of the RiCE, the water level must be in the first line of ur MiD FiNGER!
Then ur ready to cook the yummy rice!
Enjoy!
Nov 06, 2010 | Russell Hobbs Kitchen Appliances - Others
I actually have a 3 piece Comet Rice Cooker, My Mother passed recently and this was something she passed on to us. We tried to use it last night and didn't know what we were doing. Could someone help? The...
There are lines on the inside of the inner pot that show how much rice and water to put in. It is roughly 1 cup of rice and 2 cups of water. Put this inside the lower pot, put a cup or two of water in the lower pot and get it boiling, then turn it down with just enough heat to keep the water boiling. Just make sure the water doesn't boil away. The rice will be done in about 45 mins. The nice thing about this cooker is that you can't really overcook the rice. It will keep it warm and ready to serve for some time.
Oct 27, 2010 | Kitchen Appliances - Others
Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a fork...eat. If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Pat
Mar 09, 2009 | Kitchen Appliances - Others
Instructions/Manual needed
all rice cookers are the same 2:1 that is 2 cups water and 1 cup rice .... i like my rice fluffly so i allways add a 1/4 cup extra water . dont forget to put cover all the time its cooking and only open to stir
Feb 23, 2009 | Homesmart HRC-10 WI Rice Cooker
Lost my instruction book...want instructions to make rice in cooker...ratio of rice and water please
I have a Toastmaster 3 cup rice cooker but think the ratio would be the same.
Long grain white rice - 2 rice measuring cups - water to 2 cup line = 8 (1/2 cup) servings
3 rice measuring cups - water to 3 cup line = 12 (1/2 cup) servings
Long grain brown rice - 1 1/2 Rice measuring cups - water to 3 cup line - 6 (1/2 cup) servings
For fluffy rice: After cooker shuts off, allow rice to stand for approx. 15 minutes, covered, before serving.
Hope this helps
Oct 19, 2008 | Salton RA5 5-Cup Rice Cooker
Overboiling
On this rice cooker to make a perfect pot without overboiling....Use 2 cups of rice and 4 cups of water, When it starts to boil life the lid ONCE and stir and then put the lid back on pressing down to make a seal, The water should not boil over if you follow these instructions, I just made a pot :).....Oh and use the same measuring cup for the rice and the water, Just remeber....One cup of rice = two cups of water!
Jun 28, 2008 | Rival RC61 6-Cup Rice Cooker
Black & Decker HS800 Flavor Scenter 4-Cup Rice Cooker Logo
259 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
