The line connector that conect the printer to the computer
  • 591 Answers
OK... AND WHAT???? it's called a PRINTER CABLE??? USB or PARALLEL???
Posted on Apr 10, 2011
How do i resolve missing developer unit for kyocera fs1370dn
you will need to check that the developing unit connector is in proper conection with the printer.
Also check that there is no dust or toner resedue on the connector.
Best regards,
Marius.
Nov 22, 2016 | Kyocera FS-1370DN
Printer jam ererr
If the jammed paper is removed and still show paper jam it means tiny piece of paper is left over in the printer you can use a low pressure vaccum or blower to remove the paper piece before using the blower remove the toner and remove the power plug and the usb connector after cleaning conect the power then the usb then power up printer then in computer click the printer icon in the task bar and remove all the contents then click start settings printer and make your printer default printer right click the default printer and click properties in printer properties click print a test page
Apr 01, 2011 | HP DeskJet F4280 All In One Printer InkJet
My Samsung printer is conected on other computer,and not printing
try to reinstall printer driver.
Be sure printer IP adres is correct.
Good Luck!
Jun 21, 2010 | Samsung ML-2251NP Laser Printer
Belkin router
The router normally goes between the Cable Modem (or DSL line) and the computer. Use a CAT-5 cable to connect modem to the WAN input connector on your router (the connector labelled "Internet), then another CAT-5 cable goes between any of the ports and your computer. Using your web browser, go to 192.168.1.1 and continue with the router setup, choose an SSID (what you name your network), followed by Wireless Security if your router supports wireless as well. I like WPA-PSK[TKIP] for its simplicity. Anyway, the router is now useaqble by other computers!
Nov 11, 2009 | Computers & Internet
I am trying to instal the mp210 printer to my new computer and it says "not conected to computer" I think I did not receive all the connector cords for this model... what do I need?
Most printers are not supplied with a USB lead that is normally required.
You need a USB A to USB B lead. One end looks square with two corners cut off & the other is rectangular.
Oct 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
How do you hook up altec lansing speakers to the computer
You have to set your speakers first.
Connect the cables between them, connect the subwoofer( if any)
Connect the speakers to the power.
Then conect the cable with the end green (pin male connector) to green hole in the back of your computer.
(ther are three holes in straight line, one is mic (pink) other is green (speaker) and the last one is blue (line in)
That't it.
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Computers & Internet
CANON IR 400 COPIER - ERROR - E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Sep 11, 2008 | Canon imageRUNNER 400S Copier
Conection
check the cable
check the usb connector (also try using anotherone)
when u power it up, does u;re system recognize that a new device is connected ? (if not, than the problem is the connection cables/conectors; if it does but doesn;t know what type of device is, than most probably one of the wires in the cable is broken ...) If it does find any new device, give more details (what did u try ... )
Mar 10, 2008 | Lexmark X1270 All-In-One InkJet Printer
Phone connection
Make sure your to use the phone wire provided by HP or remove two extra ones from regular phone wire.
Nov 24, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Printing to printer
What OS, is it a netwotk printer USB or parralle connection. Try connectors, check if priner is off line. Check printer on the computer see if user intervention required it might have gone off line there as well.
Oct 12, 2007 | Office Equipment & Supplies
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
