Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
This modification in not allowes beacuse the section is looked my loptop is new from other country
I want to idm key 6.05
Posted on Apr 10, 2011
I have no wireless
To what Wi-Fi are you trying to connect? Is this your personal Wi-Fi router in your home? Or is this the Wi-Fi at the local coffee shop?
There is a huge amount of information you have excluded that is needed to fix your problem.
Answer these questions:
What kind of 'loptop' do you have?
What is the operating system of your 'loptop'?
Please go to the 'Help' section in your 'loptop' and check there for answers. You might find it right away.
Of the bazillions of Wi-Fi signals out there, and the thousands of bazillions of different kinds of 'loptops' out there, you must be so much more specific with what you are trying to do that I can't help you now. I need input!
The more information you provide, the better chance you have of someone rescuing you. Be smart, share all you know, then add some more, and maybe we can help you. Your "loptop" is only as smart as the information you put into it.
That is the 1st rule of computing.
Aug 18, 2014 | Computers & Internet
I need to create a lock for my settings menu on my loptop
you need to create group policies and you need to define what you allow standard users to do on the laptop
you could also create a new account and put it as special instead of administrator
lock it down so they cant make changes
Mar 30, 2013 | HP Computers & Internet
My suzuki gsxr 1000 k3 will start then cut out six times before it runs properly on its own in the cold
Instructions
  1. Take Down
    • 1 Park the motorcycle on the kickstand or center stand and allow the exhaust pipes to cool completely.
    • 2 Refer to your Suzuki service manual and organize the metric tools needed to remove the baffle. On newer models, it may be necessary to remove the tailpipe section to modify the baffle. On older models, you may be directed to remove a bolt that secures the baffle in the tailpipe.
    • Follow the procedure given in the manual and remove the tailpipe section or slide-in baffle using the appropriate tools. Save any brackets or bolts. Place the tailpipe or baffle on a workbench.
    Tailpipe Baffles
    • 4 Hold one end the tailpipe up to a light and look inside the other end. Depending on the baffle, you may see very little light or none at all. Modifying the baffle is a matter of opening up areas in the baffle.
    • 5 Chuck a 1/4-inch drill bit in an electric drill. Use a bit extension if necessary to reach deep into the tailpipe with the drill bit.
    • 6 Place the tailpipe on a workbench. Use a towel or rags to prevent scratching the finish. Insert the tip of the drill bit into the tailpipe and drill a 1/4-inch hole in the baffle.
    • 7 Hold the tailpipe up to the light again. Determine the number of additional holes you want based on the purpose of the modification. Drill additional holes in the baffle if needed.
    • 8 Stand the tailpipe on end and tap it on the workbench to clear the debris from drilling out of the baffle. Make sure all debris is cleared out before reinstalling the tailpipe on the motorcycle.
    Slide-In Baffles
    • 9 Secure the outer end of the baffle in a bench vise with the baffle extending to one side. The outer end has the threaded hole where the bolt was removed to take the baffle out of the exhaust pipe.
    • 10 Measure the length of the baffle and divide it by four. You modify a slide-in baffle by cutting off a one-quarter section at a time using a hacksaw. Mark the baffle at the one-quarter point and cut the first section off the end.
    • 11 Reinstall the baffle in the exhaust pipe using the saved bolt and the metric tool.
      Start the motorcycle and determine if the modification produced the desired result.
    • 12 Allow the exhaust pipe to cool completely before removing the baffle for further modification. Most likely, cutting one or two quarter sections will give you the result you want. Avoid cutting too much off the baffle, or it will be useless.
Jan 17, 2013 | Motorcycles
Are the outer forks the same on a gsx 1400 k4 as. K5 ?
Instructions
  1. Take Down
    • 3 Follow the procedure given in the manual and remove the tailpipe section or slide-in baffle using the appropriate tools. Save any brackets or bolts. Place the tailpipe or baffle on a workbench.
    Tailpipe Baffles
    Slide-In Baffles
Jan 15, 2013 | Suzuki GSX 1400 Motorcycles
What if i forgot my email and i have a new number its not the one i sign into facebook with
Face book retains details of account members until requested to make modifications either as new credentials attained. For example, acquiring new phone numbers, emails addresses requires to logon to daybook with the old or default member credential. The member area within face book allows making modification changes to recapture new effects.
Feb 25, 2011 | Facebook Social Network
I want to register my new acer loptop in acer
Is so easy, just go to acer.com- select your local country-and touch over Product Registration
Dec 14, 2010 | Computers & Internet
I cant play my moovies it will say region error how come?
Some DVD players have region coding only allowing discs to play specific to that country (or region) only . If you lucky you might find region hack online to re-program your player - just type <model number> region hack into Google. The alternative is internal modification which can be expensive - buying a region-free player would be cheaper.
Jul 10, 2009 | Toshiba SD-V394 DVD Player/VCR
I can't use M.Word2003-2007
its because ur trial version as expired and its in reduce functionality mode ....... you need purchase office from Microsoft to use all the features .......
May 06, 2009 | Microsoft Office Professional 2007 Full...
This modification is not allowed because the selection is locked.
hello sir i have an problem in Microsoft office 2007 when i type any word the the msg comes "the modification is not allowed the selection is locked" how can i solved this problem plz give me any solution
Mar 28, 2009 | Microsoft Office Word 2007 Full Version...
Printer instalation
Hi, Most of the time the manufacturer of the printer will have the drivers on the home page of their web site,(as long as the printer isn't too old:-) you might have to do some looking around, but most of the time it's not to hard to find the right printer driver. Good luck.
Aug 27, 2007 | Office Equipment & Supplies
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
21 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
