Question about Toshiba Computers & Internet
My Lafayette Satellite L505D works very good until it works for about 15 minutes. then it turn off intermediately. if I turn it again it works good for about 30 seconds and then turn off again. is not a battery problem because it did the same connected to ha Ac cable.
  • Toshiba Master
  • 6,771 Answers
The processor ic is getting to hot, the bottom of the laptop needs to be removed to check the cooling fan is running, dirt will need to be removed from the heat sink fins and fan. The heat sink should be removed to clean off the old thermal conductive paste including the ic, then fresh applied to improve heat dissipation. In most cases this will cure the problem.
Posted on Apr 10, 2011
HOW DO I RESET MY TOSHIBA SATELLITES BIOS PASSWORD AFTER I FORGOT IT?
take out the internal cmos battery for a while. or there are jumpers close to it or by memory u can short. failing that but up from cd if poss and use cmos reset software
Jan 02, 2016 | Toshiba Satellite L505D-S5983,...
How do I do the factory reset on the Toshiba laptop Satellite L505D-GS6000
press and hold f8 and press power button. hold f8 key till you see the recovery menu. select factory reset.
Mar 04, 2015 | Toshiba Satellite PSLV6U-01F009...
Toshiba Satellite L505D-S5983 black screen
Hold the power button down until the unit shuts off, wait 10 seconds then turn it on again.
Upon restarting, make sure to choose Start Normally if the startup failure menu comes up.
Apr 13, 2014 | Toshiba Satellite Computers & Internet
Usb not working for toshiba satellite l505d-es5025
If none of the ports are not working, simply go to the Toshiba Service center for the best possible guidance and suggestions.
Regards, Mrityunjay.
Jun 20, 2012 | Toshiba Satellite L505D Notebook
My battery won't charge
There's not much that can be done except return the adapter for replacement. But first, are you sure your car's cigarette lighter works ?
Mar 28, 2011 | Toshiba Satellite L505D-S5983,...
Toshiba l505d reset bios i pulled the small battery for a day and when i put it back together it say press F1 continue or F2 FOR setup when i press either F1 or F2 it goes back to asking me for the...
It's very Easy.. remove ram cover near the ram u can see small jumper short the jumper for 15 second with flat screw driver.. if same ..do again but keep short jumper and turn on laptop for 15 second .... Thanks if okie give me vote
Sep 15, 2010 | Toshiba Satellite L505D Notebook
Toshiba satellite l505d
unplug laptop and remove battery. Take out both memory sticks and locate on the motherboard under sticks two points marked with ***. Replace one memory stick, plug ac adapter back up and while jumping the two points at the *** (use paperclip, flathead screwdriver or other metal object to connect the points) power up computer. This, if done properly, will reset bios, removing password.
Jul 21, 2010 | Toshiba Satellite L505D Notebook
I have a Toshiba Satellite L505D-S5983
Try a different mouse, that would prove where the problem lies. Looks to me like the mouse is failing.
Jul 16, 2010 | Toshiba Computers & Internet
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
Computers & Internet Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
