Question about John Deere Garden
Please advise what the valve clearance on a L111 John Deere 20HO OHV is? Thanks Stephanie
  • 608 Answers
8thou on exhaust and 6 thou on inlet valve
Posted on Apr 10, 2011
Have john deere d120 ride single cyl B&S 21hp they are prone to head gasket failure after 50 hrs.Would having the head retensioned reduce this happening would valve clearances need rechecking. Thanks
has the head gasket failed already or are you surmising that it will happen soon
having the head studs re-tensioned would help reduce the possibility of it happening as the studs are small in diameter and can stretch and loose tension
it would be advisable to check the valve clearance as B&S valves tend to stretch and that makes start when hot difficult
Dec 01, 2017 | John Deere Garden
Whats valve clearance for john deere D130 ride on mower, vee twin motor
Bring number 1 piston to top dead center, the valve clearance for both the intake and exhaust is 0.005" cold, once the valve clearance is set tighten the lock nut for the rocker arm to 70 inch pounds.
Jan 10, 2017 | John Deere Garden
John Deere high performance technology g4 crankshaft OHV twin 23 gross horsepower manufactured by Briggs and Stratton whenever I run over big weeds the mower dies once it dies it will not start for 20...
if the engine is a briggs and Stratton then check the valve clearance as B&S engines have a history of the valve stems stretching early in use and when hot hold the valve partially open until cooled down
Sep 16, 2014 | Cars & Trucks
I have a 737 john deere zero turn ztrac mower. It doesn't feel as if I'm getting a full throttle (the power sounds as if it's muffled) this happens at times once the blades are engaged and I try to move...
Depending on hrs used and with all ohv engines check valve clearance. If they are hydraulic valves then no need. I don't understand why the owner manual doesn't always tell the customers that needs to be done. That will cause loss of power and other issues.
Jan 01, 2018 | John Deere Garden
Steering is very sloppy on John Deere L111 42 inxch riding lawn mower
Parts for that model can be found on amazon, here: Amazon com john deere l111 parts. Have a nice day. Colin
May 07, 2012 | Garden
My 13 hp ohv 5 speed 38" cut tractor dies after mowing for 10 or 15 minutes and will not restart until it cools off. i have changed fuel filter and cleaned the air filter and have also made sure my gas cap...
Just maybe, since this is an OHV engine, the valve lash needs adjusting. Your are possibly seeing the results of poor clearance when the machine heats up and the metal valve train expands, Then after cooling, the train is within tolerance again, allowing the engine to start and run. Check into adjusting those valves.
Sep 20, 2010 | John Deere Garden
L111 Auto 20 hp OHV Tractor will not go in gear
check that all belts are intact or not burnt looking
May 06, 2009 | John Deere Garden
Garden Logo
152 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
