Question about Aluratek 12-inch Hi-Res Digital Photo Frame - ADMPF312F
How do I change the main menu background image?
Why is my samsung xe3o3c12 keep changing colour when i open it
This is just the background. It's set to dynamic or "live wallpaper"
To change follow these steps.
Step 1 Press the "Home" button to return to the main screen.
Step 2 Press the "Menu" button and tap "Wallpaper."
Step 3 Tap "Wallpapers" or "Live Wallpapers" to access the selection of preset wallpapers. Live Wallpapers are simply animated images, such as bubbles, clouds or smoke.
Step 4 Tap a thumbnail and then "Set Wallpaper" to apply it to the Home screen's background.
Nov 21, 2014 | Samsung XE303C12-A01US Chromebook Silver...
Tip
How to change your computers background into something cooler
<li> <p>Click on the Start menu button. Then click on Settings and then on Control Panel.<br /></li> <li> 2 <p>Double-click on the Display icon or text link. This will open a window named Display Properties.<br /></li> <li> 3 <p>Click on Background if that tab is not selected. Click on one of the items that appear in the box labeled Wallpaper.<br /></li> <li> 4 <p>Inspect the preview that appears above the Wallpaper menubox. Use the Display menu to the right to experiment with tiling, stretching or centering the picture that you are previewing.<br /></li> <li> 5 <p>Click on Browse to use an image stored elsewhere on your <a href="http://www.ehow.com/how_5177_change-background-picture.html#">hard drive</a>. Locate the image and click Open.<br /></li> <li> 6 <p>Click OK to change your background, or wallpaper. Click Cancel if you decide to maintain your current settings.<br /></li><br /> <span>Tips & Warnings</span> <ul> <li> For background pictures, you can use scanned or digital photographs, an image downloaded from <a href="http://www.ehow.com/internet/">the Internet</a>, or perhaps some original artwork that you created in a graphics program. Graphics files suitable for use typically end with extensions of .bmp, .gif, .jpg, or .tif.</li> <li> Wallpaper consisting of large image files will consume memory and system resources. Consider using a small image and tiling it if resources are scarce.</li></ul><br />
on Jan 04, 2011 | Computers & Internet
Tip
How to change the desktop background image.
There are two ways in which to set your desired image to your desktop background.
Option 1
1) Fistly locate the picture you want as your desktop background.
2) Then double click the image to take you into Windows Picture and Fax Viewer as the default picture viewer. Once there right click anywhere on the picture and click Set as Desktop Background from the pop up menu.
And there you have it. The image is now your new desktop background.
Option 2
1) Fistly locate the picture you want as your desktop background.slasher_x.gif
Then right click on the image and select Set as Desktop Background
Option 2 is a slightly quicker way of doing it as you don't really need to view the entire image in Windows Picture and Fax Viewer as long as you can see the thumbnail of it or you are in Filmstrip view.
To enable the thumbnail or filmstrip file view
In the picture folder click on the menu view and then click on the option Thumbnails or Filmstrip from the drop down menu. Or you can find the view icon on your tab menu.
NOTE: Just remember that if your image is in a 4:3 aspect ratio, such as 800x600, 1024x768, 1280x1024, it will be distorted and stretched if you are using as a background on a widescreen monitor.
Older 4:3 monitors (square monitors) use sqarish image resolutions such as 800x600, 1024x768 and 1280x1024.
Newer widescreen monitors use widescreen image resolutions such as 1152x864, 1600x900, 1680x1050 and 1920x1080.
on Nov 10, 2010 | Computers & Internet
How to change wallpaper on HP windows 8
After you click on the desktop app and can see your desktop (don't confuse it with the apps background, you can't change that), right click on it, chose "personalize" then in the window that comes up you'll see "Desktop Background" at the bottom and click it.
From there you can use the "Browse" button on the top to find images you want to use. You can choose multiple images to load and set how often they can change.
Aug 26, 2014 | HP Computers & Internet
Desktop background doesn't show
I get this too. (Love using the solid blue background)
1. Check if there are any other users logged in on the Mac.
2. Log off all the users including yourself
3. Log in only on your user account and change the background
If that doesn't work, restart first and repeat.
If even that doesn't work, change to another solid background first and then change it back to the picture.
Dec 18, 2013 | Apple Mac Mini Desktop
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Oct 03, 2012 | Microsoft Windows XP Home Edition for PC
The desktop background is not change
Changing the background on your desktop can be very satisfying once you've grown tired of Microsoft's standard options.
Right click on the background and select Properties. A menu will come up with all the options you're looking for. If it's a change of Theme, or the the image on the Desktop, or perhaps the installation of a Screen Saver, you'll be all set once you get to this menu.
Good luck! William
Feb 28, 2011 | ASUS Eee 4G Notebook
I want to change my desktop background.
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
Jan 30, 2011 | Computers & Internet
5
Click on Browse to use an image stored elsewhere on your hard drive. Locate the image and click Open.
6
Jan 27, 2011 | Computers & Internet
Aluratek 12-inch Hi-Res Digital Photo Frame - ADMPF312F Logo
41 people viewed this question
Top Aluratek Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you an Aluratek Photography Expert? Answer questions, earn points and help others
