Question about LG 37LC2D Television
Need 4 replacement bolts for stand assembly for 37LC2D-AA model Lost them in move. Thread spec on bolts would suffice, as could source from local generic bolt supplier (Melbourne Australia).
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Need mounting bolts
lg company or go to hardware store and get the biggest bolts that will fit in the holes. Otherwise you may be able to purchase them on ebay.
Posted on Jul 09, 2009
I have a 83 Bronco 351w I am doing the brakes and the passenger side rotor needs to be replaced can someone walk me through this thanks
Personally I would replace both rotors to prevent a future brake imbalance.
* chock rear wheels, raise front of vehicle and place on stands.
* remove wheels, remove brake calliper and bracket assemblies.
* remove bearing hubs from axles, via removal of bearing adjustment nut
*remove hub seals, clean and inspect bearings, repack with HT bearing grease.
* the brake rotor bolts to the rear of the hub, you will have to remove and replace rotor to hubs, make sure all bolts are thread locked with loctite 263 and tensioned to spec.
* pack hub with grease, install seals, fitt hub assembly and adjust wheel bearing preload, install new split pins.
* fitt brake calliper and brackets, fit new brake pads,
* fitt wheels lower vehicle, test brake for function
Hope this helps..
Aug 02, 2016 | Cars & Trucks
I lost the screws of my table top stand of my toshiba tv model 32cl00u2 where can i find replacements
Take the part of the stand where the screws go in and go to a home improvement store. Check there for the proper thread pitch and length of the screw/bolt. If they don't have the correct screws, go to a local hardware store since they usually carry a wider assortment of screws/bolts, plus they usually can tell you which is the best for your problem.
Also, I believe that character after "32c..." is an L. Listed here it could almost pass off as the numeric one.
A good idea since screws/bolts are rather inexpensive, buy the parts you need that look like they are the correct length. This way you only make 1 (one) return trip to the store to return the unused screws/bolts.
Oct 19, 2014 | Televison & Video
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
Jul 17, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Required needle for 4oz bonded nylon thread "high-Spec"
a ball point needle size 14 or 16 should suffice
Mar 29, 2014 | Euro-Pro Sewing Machines
Proscan 32 lcd tv stand
Not so easy but try to call customer service for the brand (Proscan used to be RCA-GE-Thompson) to with the model number find the number, length, and thread type of the bolts.
Apr 30, 2012 | Proscan 32LB30H LCD TV
Need Vizio E321VL TV Stand Screws
I have a M420VT Vizio TV. I used (4) M6-1.0 x 16mm screws to attach the stand to the TV stand adapter. The screws I used to attach the adapter to the TV were (3) M4-0.7x12mm. It worked out perfectly!
Feb 19, 2012 | Insignia Televison & Video
I need the torque specs for a 96 grand cherakee 4.0 motor
Hello, different size, grade, thread size, application will always have something to do the torque specification of bots, nuts, plug etc.
Remember, to get the proper torque specification on bolts, nuts and threaded holes. If these have been used on an engine and it being repaired/overhauled. To get the proper torque spec these items will be need to cleaned inside and out, threads on bolts need to be straightened, and the same for nuts and bolt holes in the engine block, head, timing cover----all bolts, nuts, threaded casting holes all need to be rework to presence condition... Almost new in shape. Now, once this is done you can get the proper torque requirement and to get these spec. all bolts, nuts, threaded holes need to be oiled first. They the torque can be set properly as to the manufactures specifications. Also, there are not set standards for torquing head bolts on a 265 cu/in Chevy and compared to a Ford 265 cu/in engine, they will be totally different.
If you don't the torque spec. go to your local library they have many American Auto Maintenance Manual that will give the all the information that you need. So, just remember all bolts, nuts, machined holes with thread need to cleaned and resized the threads. To torque any bolt will need to oiled--not much.... I hope this helps you and I wish lot of luck. GB...stewbison
Sep 24, 2011 | Jeep Cherokee Cars & Trucks
Replacing head gasket how, do the bol;ts need replaced? are they stretch bolts
it is always a good idea anyway to replace the head gasket bolts. sometimes they will come with the thread too that is needed for the application. the bolts must be tighten in a sequence using 4 steps. I can give you the specs if you give me your engine model, (4 cylinder or 6)
Jul 07, 2011 | 1991 Dodge Dynasty
Need torque specs for 83 chevy 350 cylinder head bolts.
Hello there
Torque Specs
These specs may not be correct for your application.
Verify your engine specs with a service manual for your year and model.
always torque bolts in three equal increments
Bolts or Parts Lube or Sealer Torque to: 7/16 Main Caps (2 bolt) Engine Oil 70 ft-lbs. 7/16 Inner Main Caps (4 bolt) Engine Oil 70 ft-lbs. 7/16 Outer Main Caps (4 bolt) Engine Oil 65 ft-lbs. 3/8 Outer Main Caps (4 bolt) Engine Oil 40 ft-lbs. Warning!!! If you are using ARP bolts, you MUST use
their specs. Click Here! 3/8 Connecting Rod Bolt Engine Oil 45 ft-lbs. 11/32 Connecting Rod Bolt Engine Oil 45 ft-lbs. Cylinder Heads
Engine oil
(blind hole)
Sealer
(water jacket)
65 ft-lbs.
Rocker Studs (screw-in) Engine Oil 50 ft-lbs. Oil Pump Engine Oil 65 ft-lbs. Oil Pan Engine Oil 12 ft-lbs. Cam Sprocket (upper gear) Thread Locker 20 ft-lbs. Timing Cover Engine Oil 6 ft-lbs. Intake Manifold
(Cast Iron Heads)
Non- Hardening Sealer 30 ft-lbs. Valve Cover Engine Oil 3 ft-lbs. Exhaust Manifold Anti-Seize Lubricant 25 ft-lbs. Spark Plugs No Lube or Sealer 20 ft-lbs. Flexplate (Automatic)
Flywheel (Clutch)
Thread Locker 60 ft-lbs. Clutch Pressure Plate Thread Locker 35 ft-lbs. Centerbolt
(Harmonic Damper)
Engine Oil 60 ft-lbs. Bellhousing
(Transmission to Block)
Engine Oil 25 ft-lbs. Head Bolt Tightening Sequence
Apr 16, 2010 | 1983 Chevrolet Chevy
How to replace front wheel bearing on 2003 GMC ENVOY
Jack up vehicle and support with jack stands
Take off wheel
remove brake caliper
remove caliper bracket
remove rotor
remove axle retaining nut cotter pin
remove axle from output flange
pull axle out of vehicle
hub and bearing assembly held in by 4 bolts
installation is reverse of removal. You will need to find out the torque specs for the axle retaining nut.
Jan 14, 2009 | 2002 GMC Envoy
Televison & Video Logo
113 people viewed this question
Computer Repairing
Computer Repairing
