Question about Cycling
The front derailleur (shimano st ct15 will shift down nicely thru each of the 3 chainrings....it shifts up from the smallest to the middle one nicely....but does not click in and make it back to the large ring withpout multiple efforts. I suspect this is an easy fix with a minor adjustment....and am looking for a little advice before I attempt it. I am not overly savvy with tuning derailleurs.
    Brigadier General:
  • 8,546 Answers
How to Adjust Shimano Altus SL-M310 3-Speed Rapidfire Lever
Put chain on smallest chainring, loosen deraileur cable, set lever to lowest setting (usually cable has the most length at that point). pull cable tight through derailleur set screw( may be a 5mm hex or a 8mm nut). Test to see if shifting is accomplished. There is a U-tube video on this subject and a how-to web site is Sheltonbrown.com
Dec 05, 2014 | Shimano Cycling
Shimano alivio front derailleur doesn't shift from intermidiate chain ring to the smallest chain ring in a inclined riding
There is typically not a single cause or solution to a specific shifting problem. The most common way to resolve your problem is to let off a bit on pedal pressure as you shift. The derailleur has to move the chain sideways off the teeth, and that is more difficult when the chain is under high pressure.
Apr 17, 2017 | Shimano XT M772 Shadow 9-Speed Rear...
My chain occasionally comes loose when I hit a bump. How can I make adjustments to prevent the chain from coming loose. I have a Shimano tourr.ey gear mechanism. If I could obtain the instruction manual...
For the wide range of gearing on a MTB, the rear derailleur has to be able to adjust a large amount. If you shift into the smallest front chainwheel and the smallest cog on the rear (position 1), you'll probably see the chain is very loose and the rear derailleur is pointed back horizontally. Conversely, if in the largest front chainwheel and the largest rear cog, the derailleur will be pointed forward (position 2)
Couple things to do: 1) Avoid the gearing combination of the smallest cogs. Instead, use the middle chain ring and a larger cog (you'll have the same net gear ratio). 2) You can remove a link from the chain. A chain tool is about $10.00. You push the pin out through all but the last plate on two links, bend the chain slightly to pop those 2 links out (2 links = a wide link + a narrow link), then put the chain back together. This is only advisable if in position 2 there is some additional travel for the derailleur and in position 1, the derailleur has no additional travel. 3) Make sure your chainrings aren't bent, straighten (use a open-end wrench and gently pull the chain ring back to flat). This isn't likely b/c you don't indicate the chain falls off while shifting. 4). If the chain falls of the inside, screw in about 1/4 turn the inner limit screw on the front deraillleur. If the chain falls off the outside, screw in about 1/4 to 1/2 turn the outer limit screw on the front derailleur.
Mar 02, 2011 | Shimano XTR Hollowtech II Mountain Bike...
Hi, Just bought a new bike with shimano tiagra gearing. However the gear shifters doesn't seem to work. There is no movement in the cables when I try to shift gears. Do you have any idea for a quick fix or...
You don't mention which shifter(s) malfunction or if you're even pedaling the bike while shifting (I make NO assumptions).
If you operate the inner shift lever (NOT the brake lever) on each side through several clicks that should RELAX any tension in the shifter cables. Then if you pick the bike up and pedal it forward a couple of turns the front shifter should drop the chain the the lowest chainring and the rear derailleur should shift out the the smallest cog.
With the bike suspended (say, hanging from a low tree branch by the tip of the seat) you should be able to turn the cranks and manually pull sideways on either exposed shifter cable where it runs down along the downtube then release it.
This should cycle each respective derailleur through its entire range. If the cables don't travel sufficiently in this manner, the shifters will never make them do it either.
Perhaps you could CALL the Bike Shop and they would talk you through a quick operational check.
Apr 27, 2010 | Shimano 24 Speed Road Racing Bike Bicycle...
Shimano Deore LX Chainring alignment
The large ring should be a no-brainer. There should be a nub on the outside surface that aligns with the crankarm to keep the chain from dropping between the crank and the arm.
The rings also have their tooth counts etched into them. They all line up.
Mar 29, 2010 | Shimano Deore LX Mountain Bike Front...
Deraileur adjustment/tuning
Yeah you will run into that at some bike shops. When they see older components like that, they often refuse to adjust them for fear of breakage and liability. Try a different bike shop if you can, or if you are confident in your mechanical abilities, try it yourself, instructions here:
http://www.ehow.com/how_6086607_adjust-shimano-rear-derailleur.html
Good luck.
Mar 27, 2010 | Shimano Xtr Mountain Bike Dual Control...
Why the derailleur shift automatically while climbing
you need to reset the front Derailleur. there are 2 screws that set the limits. one screw is for all the way one way, and another screw for all the way the other way. when you begin shift to the smallest gear. you want the metal part of the Derailleur to be close to the chain while its on that small gear. then shift all the way to the 3rd cog and set the outer limit with the other screw and your done!
Oct 18, 2009 | Shimano 105 Triple Braze On Front...
What is the adjustment procedure on a shimano deor front derailleur. it will not shift into high gear.
Try this first:
Shift into the small ring and release the cable. Pull it tight (with pliers) and re-tighten the cable. It should shift now. If it doesn't, the solution is a little time consuming, so i apologize in advance.
First, flip your bike onto the bars and saddle. Now shift into the small chainring and your lowest cassette cog (the largest in number of teeth). Release the cable from the front derailleur and set the adjustment knob for the front derailleur to its center point. You should find it on your shifter. Now adjust the "L" setting on the derailleur while turning the crank so that its stop sets it in a position where it just skims the chain but does not touch it. Now pull the cable taut and re-clamp the cable. Shift into the middle ring and shift the rear derailleur to its highest and lowest gears, making sure the chain does not rub the front derailleur. If it does rub (it will be in either the lowest or highest cog on the cassette), adjust the front derailleur by way of the adjustment knob to clear the rub. Then shift into the big ring and you should have no problem. Set the "H" stop if necessary.
Sep 04, 2009 | Shimano Deore LX Mountain Bike Front...
I'm trying to adjust the shimano gearing on my trek bike and am having a little trouble
Front or rear? What is it doing?
Flip the bike over onto the handlebars and saddle and let us fix it.
Here is how to adjust the rear (first):
-Set your front gear to its middle position.
-Shift the rear into the highest gear.
-Disconnect the derailleur cable.
-Screw the barrel adjuster on the shifter (or down tube if it is a road bike) to fully turned in clockwise.
Screw the barrel adjuster on the rear derailleur to its halfway point.
-On the back of the rear derailleur you will see two screws. One will be marked "H" and the other "L". These mean high and low. Adjust high to get your jockey wheel on your derailleur perfectly centered over the smallest cog on the cassette. Manually shift by pushing the derailleur (while cranking the pedals) to the largest cog (1st gear) and set this stop on the derailleur "L" where the jockey wheel is over the cog, but past it where it would be touching the outside of the cog if they were side-by-side.
-Pull the derailleur cable taut and re-tighten it.
Shift the rear to the middle gear and adjust the derailleur using the barrel adjuster to center the jockey wheel directly over the cog it should be.
-Now shift up and down the cassette, cranking as you go and in every gear, back-pedal to make sure there is no problem with the gears hopping. If they do, adjust as necessary with the barrel adjuster.
Here are some tips for the front:
-Shift into low gear on the front and rear derailleurs. Make sure the chain is not rubbing on the front derailleur. If it is, adjust the screw marked "L" until the chain just clears the derailleur but does not touch it.
-Now shift the front into the middle gear and while it is still in the low gear in the back, crank to make sure the chain is not rubbing on the front derailleur. If it does, adjust the tension of the cable with its barrel adjuster.
-Shift the front into high gear and shift the rear to the highest gear, cranking as you shift. If the chain is not rubbing, you are all set.
Sep 02, 2009 | Cycling
On my bike with shimano ultegra shifters and 105 front deraileur, I can't shift onto the big chainring. The deraileur is not at the stop, but I can't move it any farther. How do I fix that.
Try this first:
Shift into the little ring and release the cable. Pull it tight (with pliers) and re-tighten the cable. It should shift now. If it doesn't, the solution is a little time consuming, so i apologize in advance.
First, flip your bike onto the bars and saddle. Now shift into the small chainring and your lowest cassette cog (the largest in number of teeth). Release the cable from the front derailleur and set the adjustment knob for the front derailleur to its center point. You should find it on your down tube. Now adjust the "L" setting on the derailleur while turning the crank so that its stop sets it in a position where it just skims the chain but does not touch it. Now pull the cable taut and re-clamp the cable. Shift into the middle ring and shift the rear derailleur to its highest and lowest gears, making sure the chain does not rub the front derailleur. If it does rub (it will be in either the lowest or highest cog on the cassette), adjust the front derailleur by way of the adjustment knob to clear the rub. Then shift into the big ring and you should have no problem. Set the "H" stop if necessary.
Jun 23, 2009 | Shimano 105 Triple Braze On Front...
Cycling Logo
712 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
