Question about RCA D61W20 61" Rear Projection Television
Rca d61w20b tv
Power button flashes 3 times but will not come on.
  • 2 more comments
  • eprew1 Aug 10, 2008
    my RCA D61W20 61" does not turn on when you depress the power button it will blink a green light three times in a row at about 3 to 5 seconds in between but will not come on then we wait 1 1/2 to 2 min. to try again and we keep trying until it does come on but it will take at least 10 to 15 tries to get it to come on so if you could kindly tell me at what kind of problem I'm looking at I would greatly appreciate it THANKS !!!!! eprew1@yahoo.com
  • dlp301 Oct 30, 2008
    I have the same problem, but what do you mean about capacitors - where do I find them, and how do I know what needs replaced, etc.?
    thanks
  • thefridge12 Dec 14, 2008
    I also have this problem. We try to turn it on and the light flashes 3 times and then quits. We repeat this process about 10-15 times and it finally works. Whats the problem??
  • multico1 Feb 09, 2009
    times and then quits. We repeat this process about 10-15 times and still doesn't work. Whats the problem??
    Problem Solver:
  • 11 Answers
Some set display this problem because of bad capacitors in the powersupply. Take a good LOOK at all large caps on the board.
Posted on Aug 06, 2008
I turn on the tv and just blink three times but dont turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 01, 2015 | RCA Televison & Video
Will not turn on RCA model D61W20B
the tv won't turn on with the remote or with the power button
Jan 30, 2010 | Televison & Video
MY TV RCA MODEL R52WH74 WHEN YOU PUSH THE POWER BUTTON ON IT FLASHES ONCE AND THEN FLASHES NINE TIMES
CK 3 capacitors on Deflection board bootom board to he left if cp150 2200uf 16v is puffed up it is bad other 2 are 220uf 35v cp114 cp120
Nov 12, 2009 | Televison & Video
My TV won't turn on.
If this is a RCA Picture Tube Rear Projection, the Deflection Board will cause this problem. I do not know though if it is available.
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
RCA 52inch HDTV (2004 model) green power light flashes 3 times
Replace the flyback 259296 and the cp150 You can get the aprts with detailed instruction on how to do the repair at the following link.
http://servicemanuals.vstore.ca/
Jun 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV does not turn on model RCA D61W20B
first check all fuses they are small, square ,RED and can be confused with the square small caps. the sizzling is prob. the flyback transformer (what the h.v. wires from each tube plugs into) if you are only getting green then tv shuts down or is dead now. i would replace any bad fuses and replace the flyback transformer. also make sure you do a very good visual inspection of all the boards.
Jun 21, 2009 | RCA D61W20 61" Rear Projection Television
RCA D61W20B WHEN YOU GO TO TURN ON GREEN LIGHT COMES ON FOR 3 SECONDS 3 TIMES, AND THERE ARE NO CLICKS OR OTHER NOISES, FOR AWHILE IT WAS HARD TO TURN ON. ANY HELP THANKS JIM
replace the flyback # 259296 and CP150 that should solve the issue. You can get replacement flyback and CP150 at the following link and they provide free instructions
Apr 02, 2009 | RCA D61W20 61" Rear Projection Television
RCA D61W20B
On the Deflection board CK capacitors cp150,cp114 cp120,If cp 150 is puffed up on top it is bad so replace all 3 capacitors 2200uf 16 use 25v and Two left are 220uf 35v Resolder pinns on flyback Transfomer and when re hooking board back up make sure you have second ribbon connector in good. Board next to Deflection is the SSB it has turners on it where you hook cable.
Jan 06, 2009 | RCA D61W20 61" Rear Projection Television
RCA RCR3273 3 DEVICE SNOWBOARD UNIVERSAL REMOTE
Answer for how to program the RCA RCR3273 3-DEVICE SNOWBOARD UNIVERSAL REMOTE:
Make sure the device is on. Hold down the tv (or whichever device you're trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly, letting it flash until the device turns off. Then press the stop button...and it is programmed.
phoenixx100@hotmail.com
http://www.angelfire.com/journal/archer/index.html
Oct 12, 2007 | Televison & Video
RCA D61W20 61" Rear Projection Television Logo
519 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
