Question about Dell SK8110 Keyboard
My laptop stuck up some letters of the key board how can I clean it to make contact, without suggesting buying a keyboard to be attached to usb? is there a cleaning liquid that can be bought?
    Sergeant:
  • 189 Answers
I'm not sure if this stuff will fix your problem, but it's relatively cheap: http://www.thinkgeek.com/computing/accessories/b88d/
Hope it helps!
Posted on Apr 10, 2011
Can't GET THE KEY BOARD TO WORK
use a usb key board which you can buy from any good computer peripheral store, just go and say why you want to bye a key board, I hope they will suggest a good one. now attach the keyboard with your laptop using USB port. not start your laptop, i hope it will work properly.
Electro Computer Warehouse Global source for Grade
Dec 27, 2014 | Computers & Internet
Key board letter stuck
Buy a can of compressed air, attach straw, slightly lift one side of key and give a few good blasts of air in the hopes it will loosen the key, repeat as needed. If no change! you can hook a external keyboard or replace the laptop keyboard.
Mar 24, 2012 | Toshiba Computers & Internet
Laptop keyboard not working
Usually in my experience most laptop keyboards are disposable. I have 2 suggestions for you.
1. buy a new same brand keyboard.
2. remove the flex connector, then use an external usb keyboard, or a bluetooth wireless keyboard.
hope it helps your problem.
Jan 03, 2018 | Acer TravelMate 5602WSMi Notebook
Question about liquid damaged dell inspiron 1545 keyboard
Just buy a new keyboard, should take care of the problem. You can buy a new key board on ebay for $10-13$. If you have any questions regarding keyboard installation, let me know. I can help.
Oct 01, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
LifeBook T4210, some letters ont the keyboard doesn't work
hello
Some of the letters stop working due to dust that stuck between the pad and board..Or due to degradation.
So you can try cleaning the keyboard with vacuum cleaner and clean properly between the keys.
If the keys still don't work you can replace the keyboard as it is replaceable.
Thank you
Jul 13, 2009 | Fujitsu Siemens LifeBook T4210 Notebook
Gateway ma3 keyboard problem
The problem seems to be that the pressure pad underneath the key is stuck on the "activated" position. Taking the keyboard out would not affect the position of the pressure pad. Also attaching a USB key board will not make any difference since the original keyboard is still electrically connected and has priority over any external plug n play devices. A new set of keyboard pressure pads should solve this. I suggest taking it to your local computer repair centre.
Nov 08, 2008 | Computers & Internet
M letter on gateway laptop not working
Start by taking the key off, be gentle and try to leave the retainer on the board. Check to see if the rubber depressor has shifted, is stuck in the depressed position, or has some dust/dirt in it or on the contact point. Cleaning the depressor or the contact point wouldn't hurt either. Check the contact point by pressing it with your finger or a pencil eraser. If the contact point works, then put the key back on and try it. If the depressor is good, then check the keyboard connection, they will sometimes work loose or get a little dirt/corrosion build up. If the connection is good, then I'm afraid a keyboard replacement is your only option.
Jul 22, 2008 | Computers & Internet
Help please tell me why my keys will not work on my laptop.
Try using an external USB desktop keyboard (or a PS2 keyboard, if you have a PS2 jack on the laptop).
If everything works then, your laptop keyboard is malfunctioning. This is usually due to one of three causes:
1. One key is stuck in the "down" or "depressed" position (collapsed/dented silicone cup beneath, or damaged flex legs under key). Look at the keyboard from the side, to see f any key looks lower than the rest (or higher than the rest) Be careful taking it apart to clean and reassemble.
2. Bad ribbon connector, torn, or merely corroded/oxidized keyboard cable connector. This requires opening the laptop to fix. Usually 2-3 screws under laptop labeled as keyboard, allow it to be pried off. Release the cable LOCK, and remove the thin ribbon cable. Reinsert it 5-6 times to clean off contacts, and LOCK the jack again once you are sure it is all snug. If the ribbon was TORN, you will need a new one. Good luck, not easy to find on old laptops.
3. Worst scenario... someone spilled coke (the worst) or beer/beverage inside the keyboard. This eats up the printed oxide connectors, and this cannot be repaired. you will need a new keyboard assembly.. Use a magnifying glass to look between keys, to see if there is stickey, gooey material there. This would be the bad news indicator for number 3.
Feb 10, 2008 | Toshiba Satellite A105 Notebook
3 KEYS OF KEY BOARD NOT WORKING AND S IS STUCK
You need to clean the keyboard. Blow it with air blower so that the paricles inside keyboard will be eliminated. If not work, then you disassemble the keyboard and clean the key one by one. afraid to do , then let the repairman do it for you or you can attach USB keyboard for the laptop.
Jan 16, 2008 | Toshiba Portege M400-S5032X Tablet PC
Acer Aspire 5610 - one key does not work
Laptop keyboard are semi-sealed circuit boards. This means that liquid can get into the contacts and can not be cleaned. Depending on how much liquid was spilled on the keyboard chances are that the liquid has seeped around the edges of the keyboard and down onto the mainboard of the laptop. My first suggestion would be to keep the laptop turned off until you can remove the keyboard and check for liquid damage to the mainboard. If there is no damage to the mainboard I would suggest buying a new keyboard before turning the computer back on as any shorts caused by the liquid damage on the keyboard can cause damage to the keyboard controller circuit on the mainboard.
Jan 03, 2008 | Acer Aspire 5100 Notebook
Dell SK8110 Keyboard Logo
137 people viewed this question
Alun Cox
