Question about Bakers Pride BAK-DS805 Gas Single Oven
I have a bakers pride ds805 do i need to do more than change orfices to go from nat to propane. i did that and the pilot wouldnot stay lit and the burners never went on ? thanks doug
  • rock556 Apr 10, 2011
    Problem with the Bakers Pride BAK-DS805 Gas Single Oven
    i have a bakers pride ds805 do i need to do more than change orfices to go from nat to propane. i did that and the pilot wouldnot stay lit and the burners never went on ? thanks doug
    one guy said i needed a conversion kit. as far as i could tell all i needed to do was chance ofices do i need to make any adgastments or do i need a coversion kit if so what kit or part no.
    Brigadier General:
  • 4,736 Answers
Yes, you also need to change the gas regulator. You can't burn Propane Gas with a Natural Gas Regulator. You may also need to make an adjustment to the flame height control knob(s).
Posted on Apr 10, 2011
  • 4,323 Answers
Hi
There are conversion kits available that you can use to convert your oven. Hope this helps...please post back for further assistance.
Daniel
Put in new valve and thermal couple but pilot stays lit , but when thermostat is turned on everything blows out after a few minutes
Check your exhaust does the flame on the burner look like it is starting to float after a few minutes if so you are starving for secondary air
Feb 01, 2014 | Bakers Pride Y-600 Gas Single Oven
Pilot light still going out
If this oven has a "stack" (where the hot gases & heat vent to your hood) air could be blowing down the stack affecting the pilot. Simple test, Bic lighter lit at the top of the stack in the middle of the opening. If the flame is being sucked down the stack, then you have air blowing the pilot out. How old is the thermocouple on this unit ? Pilot flame heats this up to send a signal to your main gas valve to open up so the burners light. A weak t-couple could be your problem. Hope this helps
Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
Bottom oven pilot light goes out intermitantly.
adjust the flame so that it stays on the thremal couple and keeps it hot if it is off by 1/4 inch it will not work.
Jul 22, 2009 | Bakers Pride FC-616 Gas Single Oven
Pilot, controler and gas knob needed replacement
If you have the older Bakers pride manufactured more then 20 years ago and it has never had service, it sounds like the safety valve is defective, that's the red button you push in the light pilot, if the pilot is lit and when you turn the manual gas valve on for the main burner to lite and still it does not you problem still may be the safety and/or a failing thermocouple.
Apr 02, 2017 | Bakers Pride CO11-G2 Gas Double Oven
I ran out of propane...so now truck is filling us up..how do I get the oven working again..how to light the pilot light?
Hi there, hope this helps. On the front of the oven, usually on the left side, where your thermostat is, has a red button sticking out, that is your pilot safety. To light it, you need to open the lower door, and aprox. in the center of the area, is your pilot, has a small pipe going to it, you have to hold the red button in, and light the pilot in that lower chamber, and most of the time, once the pilot is lit, you must hold the button for 60 to 90 seconds. If it does not stay lit when you let go of tthe button, you may have additional problems, let us know. And thank you.
Feb 20, 2009 | Bakers Pride Y-600 Gas Single Oven
Pizza oven does not light
thanx for the email reply .oven lighting problem was caused by the pilot light not quite touching the flame tubing
Dec 17, 2008 | Bakers Pride Y-600 Gas Single Oven
Bakers pride pizza oven not lighting
Hello. Usually this problem is related to the pilot being dirty, and not heating the bulb for the safety device properly/hot enough to fully open the valve. If you have a general purpose mini torch you can heat the metal bulb near the pilot with it, if this is the problem, the safety will open, and the main burner will come on. CAREFUL, you are not on/around the main burner, as it will allow gas to come on to the main burner, and if your pilot is not working properly, might not light the gas. Get the pilot cleaned and adjusted.
or... :) I know... your safety has failed, allowing gas to the pilot, but internally is not opening, this requires replacement. Last though, it could be your thermostat, its last in line, and would require replacement. The safety, and the thermostat are mechanical valves, open or closed depending on its function.
If you have a more current type, they will have a combination valve, and thermopile/thermocouple that are electromechanical, your thermostat at this point can be either mechanical, or electromechanical. This system has a few more possible causes for your symptom.
You can tell which you have by how you light the pilot, have a red button on the front of the unit, by the on/off valve? this is the first type.
Have to open a small door to access a knob, turn it to pilot, and hold in? this is the latter type.
ask if you need more help.
Hope that helps, and thank you.
Thermo coupler on all the time, push in button, shuts off gas
Bad Safety valve. (valve w/red button). Thermocouple keeps the magnet open to keep pilot and so gas can flow to burner. Make sure pilot is clean and strong and hitting thermocouple. If it doesnt stay lit replace Safety Valve.
Dec 17, 2008 | Bakers Pride FC-616 Gas Single Oven
Pizza oven bricks need to be changed
You must use a long crowe bar lift the brick and pull it out need the size of the brick to let you know how much and where to get it if it a 2inch thick they are no longer sold most lilkely it 1 1/2 inch
Oct 16, 2008 | Bakers Pride BAK-DS805 Gas Single Oven
Door on my bakers pride y600 pizza oven
Theses are called 3/4 door busings and should be changed when you replace the left side door rod (complete)and are available from any parts depot that sells bakers pride parts
Jan 20, 2008 | Bakers Pride BAK-DS805 Gas Single Oven
Bakers Pride BAK-DS805 Gas Single Oven Logo
66 people viewed this question
Top Bakers Pride Ovens Experts
ashburton
Paul Carew
Craig Butler
Craig Butler
Are you a Bakers Pride Oven Expert? Answer questions, earn points and help others
