Question about Staples Office Equipment & Supplies
My Staples SPL-TXC10A shredder just stopped working. When plugged in none of the lights are on. Does it have reset button? If so, where is the reset button? Thanks Chuck
I have a Staples Shredder model SPL-TXC6A (serial 0809026807), which I have been using a lot lately. The auto and reverse buttons will not function, & neither will the forward button.
If you have used it a lot, it may have tripped the thermal fuse. Normally, these reset themselves. One thing to make sure of,, is that the safety switch under the machine is firmly on the pin in the basket under it.
This is a light duty shredder, you can only use it for two minutes!
6-sheet, light-duty, up to 25 uses/day
Runs 2 min on / 4 min off
http://www.snoopdeal.com/bargain/43085/Staples-SPL-TXC6A
Nov 21, 2016 | Office Equipment & Supplies
I have a Staples SPL-TXC8A shredder and the power will not come on...is there a reset button or something I can do?
ck the switch itself , try to bypass it with direct power , sounds like it is burned out that is what happens to most shedders
Nov 25, 2014 | Staples Office Equipment & Supplies
Staple Model SPL-XC200D Paper Shredder, During the
Fixya does not sell parts and cannot identify sources.
Jul 18, 2017 | Staples SPLXC200D Shredder
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Best regards...
Apr 13, 2011 | Office Equipment & Supplies
Staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
Sep 10, 2009 | Office Equipment & Supplies
869 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
