Question about Western Digital Computers & Internet
Hello, I have plugged my 500gb Elements hard drive into my usb port on my computer. I have been using this drive successfully for many months. This time the computer recognised that i plugged something in but the drive is not showing up in Windows Explorer. Is this a software issue?
  • Western Digital Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Posted on Apr 10, 2011
Is this a plug and play drive?
In most computers that are encountered, devices that are plugged into the USB ports are "plug & play" capable. There are numerous scenarios that can turn this function off inadvertantly such as a virus, data corruption or driver changes. In order to fix the issue and make an external device, such as a Western Digital Passport Elite hard drive "plug & play" capable, a user will have to make a few system changes. Click "Start" and "Run," then type gpedit.msc Click on "Administrative Templates," from the tree then click on the "System" folder. Double click on "Turn off Autoplay." Select the "Disabled" option and ensure it applies to all drives. Hope this helps,
Dec 12, 2012 | Western Digital 500GB ELEMENTS 500 GB USB...
Toshiba store and gowont playon dvd player
Does the computer recognize the 500GB Drive when you plug it into your usb port?
Click Start/My Computer and see if your 500GB drive is listed as a device, if not that's a problem.
Try using a different usb port. Also try using the 500GB drive on another computer.
If it's gone belly up, it's not going to work.
Jun 05, 2012 | Toshiba Computers & Internet
External hard disk WD 500gb icon absent in my computer window?
Turn the computer off without the external hard drive being plugged in.
plug the external hard drive in a usb port, power up, the systems post boot up will find the drive and inform windows what hardware is installed.
When windows boots up, it will look at all the hardware and find the external hard drive, when windows finishes booting up you should be able to see the drive in my computer.
If you can't access your files,data recovery software can help.I used this one called Tenorshare Data Recovery to retrieve files off crashed HDD and it worked. Get it from http://www.any-data-recovery.com
If needed,you can download it and scan your hard drive for free to preview whether your files can be recovered.
Mar 29, 2012 | Western Digital WD Elements Portable...
My maxtor 500gb usb hard drive is not responding when I plug to my pc, so I can't access to any of my file
hello,
-make sure that the cables from the ext hard drive is properly connected like power if there is and USB -try other USB port -try other USB devices -try other USB cable for that Maxtor -try other computer
the reason why you are doing that is to know if the USB port is broken of if the ext hard drive is not responding.
cheers.
Feb 24, 2011 | Maxtor BASICS Personal Storage 3200...
I bought the Western Digital Elements External hard drive-500GB and it worked fine with my computer. I took it to my brother's house to download some data and his computer DOES NOT RECOGNIZE it when it's...
HI, YOU MAY WANT TO TRY, REMOVE SECURITY FROM WITHIN THE SMARTWARE, THEN AND AS ALWAYS, MAKE SURE THAT THE DRIVE, WHEN BEING CONNECTED/DISCONNECTED, THAT THE PC IS COMPLETELY SHUTDOWN.............. I HOPE THIS HELPS.........JEFFXC
Jan 25, 2011 | Western Digital Elements powered by WD 320...
I am using SuperDuper to clone my 160GB MacBook Hard Drive to a 500GB Western Digital Scorpio Blue. My problem is that I cannot determine why neither the SuperDuper program nor the MacBook itself...
The Western Digital Scorpio Blue 500GB hard drive is formatted for PC, not Mac. The simplest way to get your MacBook to recognize this new drive--and therefore copy the files from your old drive--is to plug it in to a PC and format the drive. I was advised to format with FAT 16, as this would be recognized by my MacBook. Fortunately, the process was not that involved, since the Vista-driven PC found the drivers for the WD Scorpio Blue automatically. Once formatted, I safely removed the drive and plugged it into my MacBook via a USB port using a BYTECC Drive Mate. Magically, it now appeared on my MacBook Desktop and was recognized by the cloning software I was using, SuperDuper. Three hours later, the files on my old hard drive were successfully cloned onto the Scorpio Blue--except now I had an additional 364GB of storage space. Swapping out the old drive and replacing it with the new was not a big deal at all--just make sure you have the right screwdriver for the last task--a Torx #6. Mission accomplished.
Oct 24, 2009 | Western Digital Elements powered by WD 320...
WD elements 500GB -
Had the same thing .... called them and they gave me a RMA for a new drive .....
Jul 22, 2009 | Western Digital Elements powered by WD 320...
Westen Digital 500 GB Element....
please repair the drivers of USB by the help of CD which come with the Motherboard and try again
Jan 23, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Computers & Internet Logo
54 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
