Question about Canon PIXMA MP600 all-In-One InkJet Printer
Lights flashing says print head is incorrect,install correct print head,but it was the same print head,it just appear..canon pixus mp 600,what can I do plse
    Guru:
  • 352 Answers
Hi. Unplug the printer from its power and try this.1. Pull the cartridges out 2. Remove the print head, and re-install making sure the metal contacts on the side line up with the ones in the printer. it can appear to be in OK but use a strong light to make sure it is lined up correctly. 3. Re-Install the cartridges and try again.
This can also happen with some compatible cartridges or ones that have been re-filled and re-set too many times. The black cartridge is usually the issue in this case.
I hope this helps Regards GM
Posted on Apr 10, 2011
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
What is the difference between pixus and pixma?. I can"t find driver for pixus MP 500. tnx
Hi there, i understand that your having trouble finding the driver for your pixus mp 500.. just to let you know something pixus and pixma are the same, because in japan they are calling the pixma as a pixus for them to say it in an easier way.
now here's the link on where you will be getting the driver for your printer...
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp500#DriversAndSoftware
hope that it will help you a lot to install your printer to your computer..Good Luck!
May 30, 2011 | Canon Office Equipment & Supplies
Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error) What can I do?
Refer to Canon documentation
Five flashes: Print Head is not installed./ Print Head is defective
please check correct placement with your cartridge, maybe it's not installed properly
May 09, 2011 | Canon Pixma iP4500 InkJet Printer
MP 760 Display " the
That means the printhead is defective, and you need a new one. If it is under warranty, Canon will replace it, otherwise a new one is around $65.00
Mar 24, 2011 | Canon Office Equipment & Supplies
U052 error - The type of print head is incorrect. I have not changed the print head from new, and have done all that was suggested in the on screen help list. It would appear that I have to replace the...
u Can Follow this step :
http://support-sg.canon-asia.com/contents/SG/EN/8200986100.html
if that reference can't solved, in other reference i found this statment
http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/MP620.aspx?faqtcmuri=tcm:14-610963&page=5&type=faq#Print%20head%20is%20not%20installed.%20Install%20the%20print%20head.%20U051/The%20type%20of%20print%20head%20is%20incorrect.%20Install%20the%20correct%20print%20head.%20U052
" Print head is not installed. Install the print head. U051/The type of print head is incorrect. Install the correct print head. U052 Follow the directions given in your setup sheet to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it."
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
The type of print head is incorrect. install correct print head
That happens when the printhead goes out, you'll need a new printhead,QY6-0075-000 around $50.00
Aug 11, 2009 | Canon MP610 Photo All-In-One Printer
Incorrect printhead
It just means that the printhead is defective, All of the Canon machines say that when the printhead goes out.
Jul 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
The type of print head is incorrect, please install the correct print head
patchiepoops,
make sure everything clicks. canon is known for their ''slide and click fittings''
don von gideonberg
May 28, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon Mp 610 error u052 incorrect print head
Hi I have U051, and U052 coming up, I did what it said to do press ok if that doesn't work turn it off, now it is continuously going to these problems. What do I do.
Nov 21, 2008 | Canon MP610 Photo All-In-One Printer
CANON MP510 NOT WORKING
Hi, does your printer have enough ink? If enough still blink. need to down load a reseter from canon web site inquire if they have free download printer reseter.
Jan 22, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
155 people viewed this question
old marine
old marine
