I plugged my Archos key into my computer in the 'off' position and a msg came onto the screen that read:"turn to 'on' when charging"..I turned it to the 'on' position with the archos key still plugged in, now i am not sure whether it is charging or not..I am afraid to unplug it because Im not sure if it will ruin the charge time of the device and make the charge not hold for as long as it has the potential to.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Stopping the charge and starting it again at a later point won't affect modern batteries.
To maintain your battery lifetime you need to use up all charge from time to time and then fully recharge it afterwards.
Posted on Jul 16, 2017
SOURCE: Archo AV700
Hi M8
Seems you have burned out your charging circuit.This is common on these units & you need to do one of two things,Either send it back to Archos & they will fix FOC if under warranty or buy a external charger which are a bit difficult to get hold of @ the minute.Can get them from Hong Kong - ebay.
Cheers
Boyce - Boyski1960
Posted on Aug 26, 2008
SOURCE: Frozen hard drive (disk reading error on Archos 104)
im havin the same dam problem with the lights and clickin nosie and it wont turn on im pissed
Posted on Sep 09, 2008
SOURCE: my archos av700 does not charge
The problem turned out to be the charger, problem now solved, thank you
Posted on Apr 19, 2009
issiahmurray
  • 5 Answers
SOURCE: archos charging the battery takes too long
I found that I have to leave my archos 605 powered on to get a full charge out of it, blinking light and all
Posted on Dec 03, 2009
  • 3 Answers
SOURCE: archos 704 wont turn on or charge
First, start with the easy stuff - remove the battery and press the reset button - hold down for about 10 seconds. replace the battery, attach your AC adapter and attempt to start the player. If it still won't start, you may have a damaged DC-In connector OR the charge circuit may be bad - a TI Chip on your main board sometimes goes bad - it can be replaced. Also, if the battery is absolutely dead - no charge left at all, the player will not start even with an AC adapter
Posted on Apr 02, 2010
I am not able to connect my achos to my pc or laptop. When I attached the cable from my achos to my system; it charges the battery but I cant access the hard drive and other files
If you plug the Archos when it is off, wait until main screen appears, press OK button when the message about charging pops up, then press MENu and scroll down to the USB options, select hard drive mode. Please read the manual you can download at Archos official site/support/downloads
Apr 05, 2010 | Archos 504 500870 Digital Media Player
My archos 605 [160gb ] not recognized on my PC
I recommend trying your archos on a different computer just to see if it is a pc or archos problem. Your pc should come right up and ask if you want to charge or use the usb port or both. Try another computer.
Jul 11, 2009 | Archos Internet Media Tablet MP3 Player
Getting a white screen with 102 error message
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 13, 2009 | Archos 605 WiFi Digital Media Player
Archos 5 frozen screen
I have found a solution for this issue, if you hold down the volume button and the power button for several seconds the Archos goes into a restore type mode. You then plug it into your computer and download the latest firmware update and cut and paste it onto the archos removable hard drive icon that appears in my computer. It will take a few minutes to update but then it will work perfectly.
Feb 03, 2009 | Archos Internet Media Tablet MP3 Player
Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Jan 21, 2009 | Archos 605 WiFi Digital Media Player
When I plug in the charger (i know its the right one) well it wont charge. Im not sure if its just the charging light but I cannot turn it on.
Hi
Friend
Dont worry .Insert your plug into archos charging line. On home screen of archos asked you to charged or enable option select charge only option and simly get charged yr archos within 3- 4 hrs of time.
I hope u understand this description.
bye
Nov 16, 2008 | Archos 605 WiFi Digital Media Player
Not recognised under USB
if you are having technical problem with your archos 605 just do this connect your USB with your computer and your archos device will pop up on the screen asking you if you want to charge your device or enaable usb that will automatically appear if your computer doesen't reconise the device then switch it off and on again if doesen't work then i suggest you look it up on the archos manual which is located on your device. if that doent work then i think you may need to update your computer it must have windows Core dual processor if that don't work and your archos device doesent appear then i think you may need to update your computer with a service pack 2 installation cd
Oct 01, 2008 | Archos 605 WiFi Digital Media Player
Archos 404 not charging
Dont use the USB to charge the 404. Use a wall charger that accepts USB. Wally world (Walmart) has one for 15 dollars that has 2 USB ports. It works for me. Also the docking station will charge the 404 in no time at all. It's 80 dollars. Make sure you get the generation 4 unit
Apr 25, 2008 | Archos 404 Digital Media Player
Archos 605 Recovery code 108
In order to fix this issue, we are going to need to force the unit into a
recovery application. In order to do this please make sure that the unit is
completely shut off. When the unit is off, you are going to want to press and
hold the TV/LCD button and the power button at the same time until a recovery
code 101 pops onto the screen. As soon as you see this, let the buttons go.
Once you got this screen up, you are going to want to repair the operating
system by arrowing down and clicking repair. After this is done it is going
to ask you to connect your device to the computer and install an update file.
In order to do this, you are going to want to go to www.archos.com and go to
downloads. You are going to want to download the firmware for your unit.
After the firmware is saved to your desktop, plug the unit into the computer
and open up "My computer" and you should see the Archos in the list
of drives.
Your going to want to copy the firmware onto the root directory and not in
any file folders. Once the firmware is on the Root directory, go ahead and
unplug the unit from the computer. It should still say Please plug your
device into the computer and install an update file. Click OK. After this is
done, it is going to tell you to please connect DC or USB in to continue with
the update. Go ahead and let the unit install and reboot. After this is
done, you should be able to use the unit properly. If the unit still does not
work properly, we are going to have to create an RMA for the Archos. If you
need anything else, Please feel free to contact us via Email or at
877.300.8879.
Jan 10, 2008 | Archos 605 WiFi Digital Media Player
Archos not recognised by both my computers
You must update the firmware on the archos.
Dec 07, 2007 | Archos 605 Digital Media Player
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
