Question about Apple MacBook Pro Notebook
Notebook my mac notebook will start up but will not load desktop can you explain problem please
  • Paul Burrows
    Paul Burrows May 11, 2010
    Hi John
    Just need to know a couple of things.
    Can you describe what you see in the screen up to the point where the desktop does not load?
    For example. Apple logo, revolving gear and so on
  • 33 Answers
Have you tried to boot to the factory disks???? If not try to boot from Disk 1 and press and hold the C button on power up and if you get to the screen that asks for language. If this boots up to that point it appears you have an OS issues and you can do an archieve install which will allow you to keep your old users and settings let me know if you get to this point.
Posted on Nov 07, 2008
If nothing happens when you press the power button then the computer is most likely out of power - plug a charger in and it should work. If it still doesn't you might want to get it checked at a service provider. If something happens when you press the power button but the computer doesn't turn on, then please provide more information, explaining exactly what happens so that I can help you.
Dec 05, 2013 | Apple iBook G4 Mac Notebook
Mac Notebook
Start by doing a system restore, then, if that doesn't work, run a repair with your recovery or operating system disc.
Aug 06, 2008 | Apple MacBook Pro Notebook
Won't come up on the Mac desktop when plugged into
your drive is simply has a file system called NTFS which is developed by Microsoft and sometimes can not be read by Mac OS.
All you need to do is reformat it to FAT32, a file system that will work on both PC and Mac. It will also remove all your data, so do this only if you want to delete all your data. Here is a video that explains how: (in the video he converts his drive to a Mac format, all you need to do is change the "format" drop down to "FAT32" or "Windows"
There is a more complicated way of doing this without deleting all the data. So here is a video that explains how to do that: If you would like me to explain the second option the please let me know
hope this solves your problem :)
Jun 23, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
I have a apple G4 book and when I start it up it will not go past the apple sigh and the screen stays blue?? Help Please
Hello and thank you for contacting Fixya Support, I am glad to assist.
I recommend you boot your Mac into Safe Mode, to see if you can remove a possible folder(s) which may be affecting your Mac's start up function.
Try these steps:
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
I hope this helps. If you have more questions, please feel free to reply back to this post.
Sep 27, 2010 | Apple iBook G4 Mac Notebook
My dell lap will not load windows up please help
explain ur issue in detail...
where does it stop....after u power on the lap
Dec 14, 2009 | Computers & Internet
Mac notebook
The most likely cause is a bad hard drive or a corrupted file. Start up the computer in safe mode. (Hold down the shift key while starting) that will force the macbook to run extended tests on the startup drive. If it finds any errors it may be able to correct them. If that fails use the startup disk that came with your laptop and start from it (hold down the C key during start up) that will allow you to use disc utility to try repairing your hard drive.
If the macbook fails to boot to the DVD or into safe mode. Try reseating the RAM chips. Hope some of that helps.
Aug 06, 2008 | Apple MacBook PC Notebook
Mac notebook
IF you selected the BOOT CD option in the options are any other removable bootable media as a boot disk then it will not boot, otherwise your os hdd gone faulty then it will not boot
To resolve for wrong selection of boot disk press option button while u started your system that will show you the booting option there you must to select the OS HDD
Aug 06, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
This is a copy of a previous post of mine -
Fixya - Mac Won't Start
Here are a few things that might help you
Try to start your computerfrom the system CD, if this fails, you may try to start it from theDisk Warrior CD, if this won't work also, I would check the PRAM.
Play movie ???
Can you please explain your problem with some extra words that states your Mac issue.
Thank you, Apple Care Technical Support
New Apple iPhone 3G Coming This Friday July 11!
Jul 03, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook Pro Notebook Logo
93 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
