Question about Baby Einstein Turtle Ocean Crib Soother
My einstien fish aquarium turns off after a few seconds. Is it on Demo Mode? How do I fix it?
3 Suggested Answers
SOURCE: baby einstein aquarium does not scroll
I had the same problem...call baby einstein customer service 1-800-328-0885 ext: 5 , they'll connect you to kids II- the company that manufactures the product for them and they should send you a replacement!!
Posted on Dec 04, 2009
  • 2926 Answers
SOURCE: only runs a few seconds.
Remove the batteries, then reinstall. Be sure the batteries are new or at least holding a full charge.
Posted on Dec 27, 2010
Can the Marina i25 be used in a small saltwater aquarium?
: You could but a few shrimps is all you could keep in there and it would be a very small marine tank .An experienced fish keeper could mange that but i always advice 30 gallons minimum for starting a marine tank .
Jul 27, 2015 | Fish
Always in Standby
Hi,your hifi is going into demo mode.Find the demo button on the remote and hold down for a few seconds.Should deactivate the demo mode.Goodluck
Nov 12, 2013 | Sony CMTEH10 Shelf System
Aquarium Heater instructions
Your going to need a thermometer, I suggest the simple kind that's just a sticker changing colors telling you the temp, in expensive and works. Most fresh water fish like 70-76Fdeg water, saltwater fish around 60F. if the thermometer reads too low, just plug it in, turn the temp adjustment knob just until the light comes on, wait for 10-20 mins, check your temp again and repeat steps if your still too low. once set, you shouldn't have to touch it again for a long time. Higher freshwater temps in the 80's stresses the fish out, and makes their metabolism run fast. They will live, but they will also require more feedings. Too low and they will become sluggish. Completely normal. Main thing is to keep them comfortable, don't try to change the temp to quickly. That stresses them as well. 5-10deg change over and hour is usually fine for most fish. The heater is primarily used to prevent a too low temp "below 60F" if you set it to 65, you should be just fine, you house will warm the tank up in the day time in most cases and the cycle in temp helps the fish to determine daytime and nighttime better.
Dec 21, 2017 | Fish
Why do I need a filtration system for my aquarium?
Aquarium filters are a necessary part of operating an aquarium. The fish are confined to a much smaller quantity of water in comparison to their natural habitat. Unlike in open waters, fish waste in the aquarium can quickly build up and increase toxic levels. Fish waste will in turn release ammonia which will kill your fish.
Aug 14, 2012 | Fish
Do fish grow relatively to the aquarium size?
No, this is a big misconception. Larger fish will soon need a larger aquarium to be healthy. Restricting them to a smaller aquarium may stunt there growth and result in physical deformities. Be sure to give the right environment to the fish you look after.
Aug 02, 2012 | Fish
My glass aquarium cracked. How can I fix it?
There are a few steps to take to fix a cracked tank:
  1. 1. b>Move the fish to a backup tank with cleanwater
  2. 2. Wipe the crack with white vinegarto clean the glass and let it dry completely. This will allow the silicone tostick.
  3. 3. Line the crack withaqua-marine safe silicone gel
  4. 4. Let the gel dry completely(usually overnight) before returning the fish to the water
May 13, 2012 | Fish
How do I change the water pump in my aquarium?
There are a few simple steps to follow in order to changeyour aquarium's water pump:
  1. 1. Turn off all electrical componentsof your tank including lights, filters, vacuums etc.
  2. 2. Remove all of the fish andplace them in ample fresh water
  3. 3. Remove all of thecomponents of the pump (some internal and some external, depending on yourmodel)
  4. 4. Familiarize yourself withthe different parts of the water pump. Obviously, the exact installation process will vary from product toproduct
  5. 5. Lay out and attach all newtubing
  6. 6. Build the small pieces ofthe pump and insert them in place
  7. 7. Install the filters andsump (if relevant)
  8. 8. Plug in and turn on allelectrical components. Ensure thateverything is functioning before returning the fish to the aquarium
  9. 9. Return the fish to the aquarium
May 13, 2012 | Fish
Stuck in demo mode
When you are in STANDBY mode hold the menu button for a few seconds and a special menu should pop up. In this menu you should be able to set the clock, turn off or on the beep, and take your unit out of demo mode. Good luck.
-Andrew Hawkins
Apr 13, 2008 | Pioneer FH-P4100 CD / Cassette Player
Kenwood KDC-MP635 STUCK IN DEMO MODE
Turn the unit onto standby then press and hold the menu button then scroll down to demo using the toggle switch on the right then press and hold the toggle switch for a few seconds and it will change to demo off. It's not too difficult but you are correct, it doesn't tell you correctly in the installation instructions.
Jan 25, 2008 | Kenwood KDC-MP635 CD Player
Unable to turn off DEMO MODE
1. Turn Radio On
2. Change Source input to Stand-By
( Puts radio in display only Stand By mode.)
3. Press Menu Button
( Gives you standby menu)
4. Toggle display with control knob until DEMO ON appears
5. Hold control knob in until DEM0 OFF appears
6. Press Menu Button
7. Change source back to music.
All done. same as other Fixes - Just step by step!
Sep 09, 2007 | Kenwood KDC-MP435U CD Player
Baby Einstein Turtle Ocean Crib Soother Logo
142 people viewed this question
Top Baby Einstein Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Einstein Baby Gear Expert? Answer questions, earn points and help others
