Question about Lincoln Welding Tools
Wire melts ,more than it welds I have increased heat, and wire speed
  • 407 Answers
Hi:
You should reduce your heat only until you feel your gun kicking back due to the high wire speed feed, then adjust your heat pretty slow.
Posted on Apr 10, 2011
Testimonial: "Yes you are correct. I had tried this before and it worked for a few then acted up again. I am fairly new to this type wlding. thanks....Learning"
My Hobart 140 will not get hot enough to make a weld. It will feed out the wire, make a spark, and the flux core wire will melt on top of the thin rouaght iron square tube fence but it will not melt into...
Hi:
Sounds like you have the wrong polarity in your machine. If you are using flux core wire, make sure to connect your ground clamp to the positive side and your gun to the negative side. Dial the right voltage and wire speed according to wire size and metal thickness.Let me know if this help.
Regards,D.S.
Nov 18, 2011 | Hobart Handler 140 Mig Welder
I have a miller gold seal model 420 it always worked alright but now when i weld it welds wire right in the tip . i have changed the liner a couple of times and that doesnt do any good i have wrecked...
Hi:
If you are burning tips frequently, there's nothing wrong with your unit, it's just heat and wire speed fine tune you need. in order to avoid the wire/tip burnbacks, increase the wire feed to your unit, if you think this is too fast, then do the opposite, leave the speed as it is, but decrease your heat until you feel that the wire is kicking back the handle of your gun, then just increase the heat a little bit and that will be your ideal setting.
Hope this cure your probloem. Have a great day!
Jul 10, 2011 | Miller Welding Tools
My car has a horrible exhaust problem, makes noise. Even louder as the speed increases. Also it puts out mass heat. My trunk got so hot that the carpet inside of it started to melt. Im not sure if its...
Well it sounds like either the muffler itself has a rupture in the outer shell or the exhaust pipe going into the inlet may have a hole or a bad weld (or loose clamp if it's not welded in place) as to the heat shield you'ld just need to raise & support the vehicle and really inspect exhaust to pinpoint problem and see if the heat shield has been replaced too. I'd imagine the top of the muffler has blown out and all that heat is hitting the trunk pan and melting your carpet
Feb 05, 2011 | 2001 Mitsubishi Diamante
Copper end of wand and parts inside of wand have melted. Is there a replacement?
Melt?? well looks like you had a burnback problem. There are contact tips, nozzles and gun liner available. Go to your nearest welding shop and ask for them. Around 35 bucks for all three (if you need the gas mixer known also as tip holder add 10 buck more).
To avoid burnbacks, reduce your voltage or increase your wire speed.
Jan 11, 2011 | Clarke Power Products Clarke 130EN Mig 110...
Miller S-54D 115V digital wire feeder that does not weld right.
Hi Kevin,
Causes of poor penetration: Travel speed too fast, welding current too low,
poor joint design / and or preparation, electrode diameter too large,
wrong type of electrode, excessively long arc length.
Solutions: Decrease travel speed, increase welding current, increase root
opening or decrease rootface, use smaller electrode, use electrode with deeper
penetration characteristics, reduce arc length.
Mar 24, 2010 | Miller Welding Tools
Having problem with heat range.
Try keeping your heat setting hot, but increase your wire speed and regulate your welding speed accordingly. How does the weld look with your settings where you started?
Aug 07, 2009 | Welding Tools
Miller mp65e welder that burns too hot
try dipping the tip in some grease be fore welding or increase your wire speed a touch and see if that helps
Apr 01, 2009 | Welding Tools
How do i weld thin metal with out burnning holes
First make sure your work area is out of the wind
Get some of the same thin metal to practice with.
Use the thinnest wire you can get. Start on the lowest
Volt setting and wire speed start welding and increase
Your wire speed till it sounds frying bacon and use
Stitch welds about ½ long wait a few seconds then lay down
The next weld start at where you left off that way the metal
Has time to cool some dial it in and practice.
Mar 03, 2009 | Campbell Hausfeld RBWG202000 NA 70 Amp....
Trying to weld with Hobart 125 EZ
If you are using flux wire and not shielding gas, your clamp should be positive and the wire should be negative. Heat is provided by the electrical arc that happens between the wire and the material. Your welder by itself does not pre heat the material and with 3/16 material you should not need to preheat anyway.
The electrical arc is kept consistent by adjusting the wire feed rate and the current applied. You will need to experiment with these settings to find what works best with your welder. For this welder and 3/16 material, I would suggest you start at the upper end of the current scale and about a third of the way up on wire speed. The welder might have a chart for these settings in the manual or inside cover.
If the wire feeds too fast, it will push the probe around and you will feel pressure as the wire feeds out. If the speed is too slow you will get large spatters and intermittent arcs. When properly adjusted the arc will sound even and consistent. The arc gap should always be about 1/8 of an inch.
To maintain enough heat for good penatration, do not move the probe too fast, work in a pattern and watch the weld pool (melted metal) and not the arc. Watching the weld pool will clue you in if you are moving too fast or too slow.
I hope this helps.
-Scott
Feb 03, 2009 | Hobart Handler 125 Ez
Welding Tools Logo
162 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
