Brand new today ! It will not fill!! I have the hoses hooked up right, it acts like it want to work but does not fill then it starts flashing..
    Brigadier General:
  • 6,277 Answers
If you are certain that it has been installed correctly and that the water supplies are actually present- i.e. the taps are turned on and the hoses are not kinked or squashed behind the washer, contact the vendor immediately; do not attempt to do anything else for fear of negating the guarantee!
Please score this solution accordingly.
Thanks and good luck,
John C
Posted on Apr 10, 2011
Washing machine starts agitating before fill
Pressure switch stuck you can pop the hose off the switch and blow thru hose it may reset and fill correctly before agitation will eventually stick again.
Jan 12, 2014 | Maytag Washing Machines
Okay, my fisher and paykel gwl15 is almost brand new. i moved it into my new house tonight. I tried washing my laundry and it starts to fill but then stops at the light that says "wash" and wont...
Sounds like you have low water pressure or a blocked hose inlet screen. take the hoses off and check to see if there is any debris in the screen on the washer hose connection. Make sure the hoses are not kinked and the valves are turned up all the way. Also check to see if you have those special flood proof hoses with the automatic water shut offs. I have had those not work properly many times.
May 18, 2011 | Washing Machines
I had troubles with my washer going through a cycle and stopping when it got to the rinse cycle. I put in a new timer, the machine worked great through part of a cycle but again quit just at the rinse...
Verify that BOTH hoses are hooked up to the correct water inlet and they are TURNED ON and FLOWING. Your condition acts like hoses are reversed, and the hot (cold actually) is turned off, that will cause the machine to stop on the rinse cycle....
Mar 04, 2011 | Roper RAS6233KQ Top Load Washer
I am trying to hook my washer up to a laundry room valve, but it keeps leaking and giving a "NF" code... Is the valve faulty or does my washer need a new hose to hook up to a brand new home's valve?
try changing the washers in the hoses / don't use red outside hose washers/ but hi pressure for fill hoses . home depot should have them . and ck the valve screens at the washer side . clean screens good washers . ( water flow's and washer should work .. mm
Dec 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer Won't Fill, New fill Valve, makes humming noise
Check your water level switch it may be showing full. If it is it won't fill. If you can set it on spin and run for 2 or 3 min. it might clear the hose from the tub to the switch in case there is too much water in it. Or you could pull the hose off the switch and blow in it to be sure it is clear. Sometime if it gets too much in it it builds up too much pressure and shows full.
Jun 09, 2009 | Washing Machines
Compaq presario sr2150nx keyboard and mouse wont work
maybe the devices are both defective or you mistakaly plug it to the wrong ps2 port.check its pin.
May 05, 2009 | HP Compaq Presario SR2150NX PC Desktop
No water is coming to dishwasher
Check and see if you have 120 comming to the fill valve. if you do the start to loosen the hose you connected to make sure the valve actually opened when you turned the water back on
Nov 25, 2008 | Maytag 24 in. MDB4651A Built-in Dishwasher
Leaks water from soap drawer
could be a loose hose to the drum from the dispenser or a tape still in the dispenser not taken off.
please check it.
tnx 4 using fixya,
drcool
Oct 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Just hooked up new pxc yesterday was working fine today when i tryto open a favorite web site from desktop shortcut it just flashes and does not open . i can open if internet is already open or from...
i fixed this by doing a recovery back to the day before when it started acting up and since i really had nothing on the pc toworry about losing
Sep 14, 2008 | Computers & Internet
Washer
Insure all the transit packaging is removed from underneath
check drain hose for kinks...is the discharge end hooked into anything?..lay hose down into bucket and check..should siphon from machine... if not theres a problem with the machine
as its under warrenty i would'nt go any further than that. let me know how you get on
Jan 04, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
