Question about Refrigerators
My GE Model#GSH25JFT side by side refrigerator stopped cooling (both fridge and freezer). There is no frost buildup on the coils, I replaced both the control board and the evaporator thermistor; still no dice. Please help.
  • 1 more comment
  • netfield Apr 10, 2011
    Thanks. I checked the compressor pins (R read 0); everything was fine. The compressor seems to start and the condenser fan continues to run the entire time. Also, at start-up, the copper pipe (~2" section) that is bonded to the aluminum pipe (evaporator coils) gets a little frosty before melting. Any ideas?
  • netfield Apr 12, 2011
    That's correct. I was referring to pipe at the evaporator. I have since replaced all three thermistors. A technician was just here and is heading back to his office to get a new relay. It was hot (but passed the shake test), so he's thinking that's the next likely suspect. We'll see.
  • Refrigerators Master
  • 2,605 Answers
Hello, Welcome to FixYa.
So to make sure I understand you correctly, you've replaced the thermistor on the evaporator and the control board at the back correct ?
Is there power going to the compressor ? Does it make any attempts to start ? (usually a good indicator is if the condensor fan is running, but not the compressor)
I would check the compressor itself if you answered yes to all these things...with any luck it may just be a faulty start relay and therefor tripping the overload.
Here's how you can check the compressor...I don`t know the age of your fridge, but I should mention,
** Most of the manufacturers of fridges ( including GE ) have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to.**
If you have a multi- meter you can check the compressor to see if the windings are ok. If you have a clamp-on you can check for amperage draw when trying to start which is good info to have as well.
**First, Unplug the fridge**
Remove the panel at the back down at the bottom. This should gain you access to the compressor.
On the side of the compressor will be the start relay/overload assembly such as this image...it may be enclosed in a black plastic cover as well.
Pull off the relay & overload and you'll see 3 pins in the form of a triangle...
With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin.
You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms.
On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good !
If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit.
i.e.
My GE Model#GSH25JFT side by - 775ec2d.jpgttp://i.fixya.net/uploads/images/775ec2d.jpg" alt="775ec2d.jpg" class="h_mi" />
The above package contains info and hardware on how to connect it.
NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relied on for long term reliability or safety, but rather thefactory replacemnet, double check with your model number.
Hope that help`s move you forward if nothing else. If so please take a second and rate the guidance and a testimony to your inquiry you received here at FixYa, either or all is appreciated.
Let me know if the compressor is indeed operating yet the fridge or freezer fail to cool and I'll continue to help in any manner I can. Good luck
Thank you for choosing FixYa today.
Regards,
Macmarkus :)
Posted on Apr 10, 2011
  • 1 more comment
  • Mark MacDonald
    Mark MacDonald Apr 10, 2011
    Hello again,
    OK so the compressor is running, that is good. I want to address this part of your last post...
    "at start-up, the copper pipe (~2" section) that is bonded to the aluminum pipe (evaporator coils) gets a little frosty before melting"
    The frost on the suction line at start up is typically a sign the unit has been slightly overcharged, has this unit had any system work done to it to your knowledge ? What about the discharge line coming out the other side of the compressor (smaller steel line) is it fairly hot and does it stay hot during operation ?
    The other curious point you made is the issue of the coils not having any frost on them. You are talking about the evaporator coils in the freezer correct ? Is there no frost on them at all after the compressor runs for several minutes ?
    Also, do you have a clamp-on amp meter or access to one ? If you could measure the amperage when the compressor is running it would be huge benefit to tell us if the compressor is pumping correctly as we could calculate the wattage via Volts x Amps (E x I = P)
    I'll watch for your reply.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    It just occured to me that you may have been referring to the pipe at the evaporator frosting up ( going from copper to aluminum ) and then disappearing, is that correct ?
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 12, 2011
    When the tech. returns ask him to put an ammeter on to check the power consumption or amp draw on start-up. It sounds to me like it is either an inefficient compressor or the system has a leak and therefor no gas...that is why I inquired about the frost pattern.
    Let me know if he provided an amp draw reading for you, both on start-up and once stabilized...running.
    I'll wait for your reply.
    Regards,
    Macmarkus :)
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
GE GTL21KBXABS refrigerator has heavy frost buildup and leaks water onto floor.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 10, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Side by side refrigerator stopped cooling. Temp was 55 degrees in fridge when I noticed. Vacuumed back and between coils underneath. Removed lining in freezer and melted heavy frost and ice build-up...
Sounds like the defrost timer/board may be hanging up....
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 24, 2011 | GE GSS22JFMWW Side by Side Refrigerator
My 5 year old GE GSH22JSRSS Stainless Steel Side by Side Refrigerator recently stopped cooling. I noticed a build up of frost on the freezer, so unplugged the fridge and let the ice melt away. After this,...
The problem you describe is that your defrost circuit has failed. The fridge should stop the compressor periodically and turn on the defrost heater to melt the frost buildup. Since the frost in building up on your coils, the fan can't blow the cold air into the fridge compartment. It defrost is controlled by a module that turns on the heater. Most of these failures have to do with the defrost heating element burning out. It can be replaced by someone who has some mechanical ability.
The coil and heater is located in the back of the freezer compartment behind the panel in the back. You can obtain parts from appliance repair outlet or online like appliancepartspros.com or repairclinic.com.
Dec 07, 2010 | GE GSH22JSRSS Stainless Steel Side by Side...
My ge refrigirator is getting warm on refrigirator side but freezer side is doing fuine. model #csh25jftaabb send answer to
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 02, 2010 | GE GSH25JFT
Have the GE GSH25JFT side by side fridge. It's
We had the same problem with our 2 year old GE GSH25JFT. Had a Sears technician come out and said it was the main circuit board. He also stated this would be $400 by the time the repair is completed. I just ordered the part myself from a Sears Service Center for $146 plus shipping. I believe the install is as simple as: unplug refrigerator, disconnect water supply, removing six screws, pull out the old circuit board and install the new one.
Oct 04, 2009 | GE GSH25JFT
No cooling
Both refrigerator and freezer operate from one system. Air from freezer cools refrigerator. Check back wall of freezer for frost buildup. If frost is evident on the back wall of the freezer it indicates a defrost system problem.
Aug 08, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Side by Side Refrigerator
Check for frost on the back wall of the freezer section. If no frost buildup is noted check that the condenser under the refrigerator behind a removable panel in back is clean and that the fan there operates when the compressor runs.
If you have frost buildup in the freezer section on the back wall you have a defrost system problem. These problems are not related to the cleaning ladies work unless some paper or other item may be stopping the fan from turning.
Jun 11, 2008 | Refrigerators
The fridge section of my LG GRB218JUDA has stopped working and the temperature indicator reads Err FF. Can you help
Side by side and other refrigerators are controlled or cooled by one system. Look to the freezer side for frost buildup on the back wall of the freezer. Frost buildup on the back wall of the freezer stops the air that cools the refrigerator from circulating. Frost on the back wall indicates a problem in the defrost circuit related to the timing device, heaters or defrost thermostat.
Jun 02, 2008 | LG Refrigerators
Frigidaire model # FRS26ZNHB2 side by side not cooling
T
From your description, you have a bad evaporator fan motor. The part number for a replacement motor is #5304445861.This is not a direct replacement but is more reliable.Remove everything in the freezer, take off the back panels and you will see the fan.
If there is a large frost buildup on the coils and the fan is turning you have a defrost problem. If that is the case, please call me at 334-347-0000 and I will walk you through it.
Jan 14, 2008 | Refrigerators
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
