Looking for debris filter location. - Washing Machines
  • Washing Mach... Master
  • 2,287 Answers
There isn't any filters in washers like the older machines had
Posted on Apr 10, 2011
  • Sal DeAngelo Apr 10, 2011
    is this a front load washer?when you ask a question you have to send the brand name and model number off of the machine not the book,if it's a front load washer the center of the pump unscrews so you can clean it
    also on some machines you just remove the drain hose that goes to the pump,remove the hose and clean out anything in the pump, but send the model number
Filter has clean hoses and new sand, but water return is still low. valve cover has debris in non-removable housing.
Does not sound like a product failure. But more info would help so I'm making some assumptions. Double check the hose connections going into the filter are in the proper location. The hose from the pump will plug into the highest port and the return to the pool will be the lower port that does not have the sight glass. Make sure you are only vac'ing on the "filter" or "waste" setting. Never vacuum your pool on "backwash". If this is not your problem then look to the pump for an impeller blockage. Lining the pump basket with a nylon stocking will keep debris like cottonwood from making it through the basket and clogging impellers and filters.
Apr 10, 2014 | Blue Wave Sandman Above Ground Sand Filter...
Where is the cabin air filter location on a 1994 mercury capri
1994 Mercury Capri ac does not have a cabin air filter. Weak air flow and bad smell could be debris in the fresh air/ac inputs. Check under the hood for debris where the air enters, the area under the wiper, and behind the vents inside, they get clogged if you park under a shedding tree...Chris
Apr 05, 2014 | 1994 Mercury Capri
Samsung washing machine wf306law xaa where is debris filter?
I have a
WF306LAW/XAA Samsung, and no idea where this filter is! Any help?
Nov 13, 2013 | Washing Machines
How do I clean the drain filter assembly on may tag dishwasher mdb4651awb
Sometimes this can only be gotten to by unscrewing the bottom spray arm in the basin of the DW. First, look in the bottom of your DW to see if you can unclog the screen by hand. This is the Drain Filter Assembly. It screens the waste so the pump doesn't get clogged. If you swipe stuff on the bottom of the DW like that leaf lettuce and rice, this might help.
Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Nov 03, 2013 | Dishwashers
Fuel filter
looks like the actual filter may be under Your seat, You do have a filter in the tank, But its more for keeping large pieces of dirt and other large debris out of your fuel system, Check this link, It may help. http://www.moccsplace.com/images/filter/filter.htm
Oct 21, 2013 | 2005 Suzuki Boulevard C90
Where is the fuel filter located on a 1992 oldsmobile custon criuser
The fuel filter in the Oldsmobile Intrigue is located under the car in front of the fuel tank. The purpose of the fuel filter is to pull out any debris and sediment that may have been sucked up by the fuel pump in the tank. Harmful sediment and debris can be hazardous to the engine. Replacement of the filter should be done every 30,000 miles.
More read: OBD2 Diagnostic
Aug 05, 2012 | 1992 Oldsmobile Custom Cruiser
I have a portable GE Dishwasher that seems to be not doing its job like it used to, the dishes are not coming out very clean, What should be looking for?
You probably have a clogged filter. It's usually located in the sump area under the lower spray arm.
I cleaned mine (9 yr old Maytag) and it works like new. Debris like paper from labels, and sandy looking debris (I think coffee grounds) clogged my filter. Good luck!
Feb 02, 2010 | Dishwashers
I wonder why there is still water left inside my front load after draining. It used to be totally drained. But now as you turn the drum by hand you can hear water inside of it. My samsung is Wd 6102
Hi the likely problem is a blocked drain filter or a bad pump. Their will either be a small door at the front right or a removable panel under the door. gain access to the pump and beside the pump there will be what looks like a gas cap on a car. unscrew it and clean the filter. If you don't see too much that would block the filter then your problem is the pump replace it. If you have any other questions please feel free to comment. Mike
Dec 06, 2009 | Samsung Washing Machines
Where is the engine air filter located? Is there a manual I can look at?
It's behind your glove box. I just replaced mine and I was really glad I did. There was a huge amount of debris in it. When you buy a new filter, instructions will be in the box for your specific vehicle.
Jun 28, 2009 | 2005 Honda Accord
Error with 'Debris Filter' on Samsung WD-J1255 machine
remove pump and dismantled it,I don't think the rubber you found is off the machine,look for something caught in pump
Mar 21, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
